battery/alternator/charging system - TheDieselGarage.com
Thread Details Posted by strokin6L, this thread has received 37 replies and been viewed 5742 times.
Old 11-18-2009, 07:23 PM   #1
strokin6L
strokin6L's Avatar
Well ran into a little issue. Tried putting the 64/71/70 turbo on today and well, when i was installing it i somehow rubbed one of the wires that goes to the connector on the alternator and it sparked and smoked a little. Now i have a battery light on my dash. I didn't check any fuses or tested the alternator yet. but just wondering what anyone thought.
2004 F-350 XLT SC 4x4: SCT, AFE stage II, autometer gauges(pyro, boost, tranny, fuel), edge insight, CFM large mouth intake elbow, spearco, snow performance water injection, 5" stacks, ARP's, fluidampr, hypermax fire rings, LIPD regulated return, FASS, fuelab, casserly 190's, 64/71/70 turbo(polished compressor housing)modded FICM(ID), Hellmann's sump, electirc fans
strokin6L is offline   Reply With Quote
Old 11-18-2009, 07:53 PM   #2
DevilDocTater
Member Since Sept 2007
DevilDocTater's Avatar
Hmmmm hard to say, does the truck start and run Ok?? Might try disconnecting both batteries and turn the lights on for a bit then hook it back up and see if it throws the light again???
Just a pure guess......i know just enough to get me into trouble.....
-Wade
"The best Battlefield Medicine is firepower superiority and overwhelming violence!"
SLAPS Member #193
Singles Club #212
3rd Degree Master Mason
2004 F-350 6.0 6" suspension lift sitting on 35's 6spd MANUAL 4" Turbo Back Exhaust, AFE Air Box, (ARP Studs, New HG's and Complete EGR Delete by Josh at River City Diesel) Coolant Filter from Dfuser, Stainless Steel Up-Pipe from RCD, 4 gauge pillar with Autometer Phantom Series 1 gauges. Boost, Pyro, Fuel Pressure and Oil Temp. Shimmed FPR. Improved Banjo Bolts. Fabtechs all around with a Procomp steering stabilizer from RCD. SCT X3 tuned by RCD
DevilDocTater is offline   Reply With Quote
The Following User Says Thank You to DevilDocTater For this addition to TDG:
strokin6L (11-18-2009)
Old 11-18-2009, 08:01 PM   #3
teamroper60
SLAPS President
teamroper60's Avatar
Images: 9
I'd be looking for a blown fuse first.....
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; Silverline turbo-back dual exhaust; 155's from Full Force Diesel (Casserly); Di-Pricol gauges; ARP studs; Dfuser regulated return; AFE PG7;Tunes by Tony Wildman & IDP; B&W hitch; DIESELSITE Coolant filter; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT radio; JL Audio 275w amp w/ 12" sub; Alpine door and rear seat speakers. pics
#43
Dually club member #76
SLAPS President and Webmaster
If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen. - quote by Samuel Adams
Political correctness is a doctrine fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end
teamroper60 is offline   Reply With Quote
The Following User Says Thank You to teamroper60 For this addition to TDG:
Old 11-18-2009, 09:15 PM   #4
69cj
69cj's Avatar
I 2nd the blown fuse and make sure that the wire or connector wasn't damaged and is still grounded. Then if you still have the light and the vehicle runs try resetting the codes with a scanner if there are any.
69cj is offline   Reply With Quote
The Following User Says Thank You to 69cj For this addition to TDG:
Old 11-18-2009, 09:57 PM   #5
strokin6L
strokin6L's Avatar
connector is fine there was a bare spot on one of the wires to it. I just put some electrical tape on it. I'll look for a blown fuse.
Old 11-19-2009, 01:01 AM   #6
UpstateDieselGuy
UpstateDieselGuy's Avatar
If the fuses all check out get the multimeter out and start checking for power with all associated connections. Make sure that you are getting power out of the alternator, etc. Chris
I'm a little more country than that...
2011 F-350 Extended Cab Short Box Lariat
SOLD
2004 F350 Regular Cab Long Box XLT; FX4, 6.0L and TorqShift; Manual Transfer Case and Hubs; Dark Shadow Grey Metallic; Keyless Entry; Factory Idle Control; 8 1/2' Fisher MMII; Factory 18" Wheels painted black with 305/70R18 Mickey Thompson ATZ's in the summer and XL Steel Wheels painted Black with 285/75R16 ProComp A/T's in the Winter; Rough Country 2.5" Leveling Kit; Isspro Pyrometer, Boost, and Transmission Temperature Gauges in an Overhead Pod; SCT by Innovative Diesel; Innovative Moderate FICM Tune; ARP Head Studs; '03 Turbo screaming through a 4" Turbo Back 409 MBRP System with both Deletes and 6" Tip.
UpstateDieselGuy is offline   Reply With Quote
Old 11-19-2009, 02:16 PM   #7
strokin6L
strokin6L's Avatar
fuses are all good. as for using a mulitimeter, haven't a clue what one of them are or even what to check for. i noticed in the manual that there is a relay for trailer tow/battery relay. i'm just not sure i'll hafta have my buddy check power at the alternator. truck runs and starts just fine other than a batter light on the dash.
Old 11-19-2009, 10:03 PM   #8
105vegas
105vegas's Avatar
i woul guess you fryed the voltage reg in the alt have it checked
05 f250 cc
RCD egr delete, SCT with RCD tunes
03 turbo
magana flow 4" no muff
105vegas is offline   Reply With Quote
The Following User Says Thank You to 105vegas For this addition to TDG:
strokin6L (11-20-2009)
Old 11-19-2009, 10:05 PM   #9
dbennett48
Old Fart
dbennett48's Avatar
Your alternator is not charging. It throws a battery light to indicate this.
Dave
dbennett48 is offline   Reply With Quote
The Following User Says Thank You to dbennett48 For this addition to TDG:
Old 11-20-2009, 01:38 PM   #10
strokin6L
strokin6L's Avatar
ok guys this is what i found. I tested the battery with the mulitmeter and it read 10.5. I then tested the alternator and it read 10.2. So maybe i fried the alternator then.
charging system powerstroke3 1994-2003 7.3L Power Stroke 3 11-08-2009 01:53 AM
Battery Charging thompsd 2003-2007 6.0L Power Stroke 10 01-09-2009 01:13 AM
battery charging question Super Limo 1994-2003 7.3L Power Stroke 4 12-03-2007 12:58 AM
battery not charging steve s Duramax 2001-2004 (LB7) 2 06-11-2007 11:20 PM
Charging the trailer battery cdooguy Towing and Hauling 7 02-17-2006 06:06 AM
