Common rail / P-pump conversion - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by chrisnjane1199, this thread has received 9 replies and been viewed 7949 times.
Old 11-27-2009, 02:53 AM   #1
chrisnjane1199
Greetings All,
I am new to the site, been doing some research. I am looking to confirm with Y'all a possibility.
I have a 04.5 Cummins ISB common rail. I am looking to put said motor in my 1942 Dodge Carryall project without the electronics package. i want a vehicle that will be reliable and not dependant on a computer to survive.
So, question is; Can a 2004.5 Common rail be converted to a P7100 mechanical injection without major problems? Obvious would be the timing cover, gears, pump, injectors. Anything I am overlooking?
Thank you much
chrisnjane1199 is offline   Reply With Quote
Old 11-27-2009, 04:28 AM   #2
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
wouldnt a 12v be a much easier and simpler solution?
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
Old 11-27-2009, 07:15 PM   #3
chrisnjane1199
Well, perhaps it may be. However, I happen to be in possesion of an 04.5 Cummins with new pistons, rings, bearings and valve job. If I can create a decent product with that base I may be ahead. Maybe not.
I was thinking that I may end up with a stronger, free flowing motor with the 24 valve head.
I just don't want anything to do with electronics in my project. A simple reliable mechanical pump I can work on myself.
Would I be better off to just put a 12 valve head on the short block? But then what about valve clearances, compression, etc. with the later model block?
Old 11-27-2009, 08:46 PM   #4
Sledpuller500
Inline Junky!
Sledpuller500's Avatar
Images: 121
your biggest problem is going to be the head/injectors. On a common rail the injectors are located under the valve cover beneath the rockers, and are feed from the side through a pilot tube from the common rail and the injector is fired electronically. A 12 valve p-pump makes the injector fire. And the injectors are much different and located on the passanger side of the motor and come in on an angle from the outside of the head. I dont think you gonna find a 12 valve style injector to fit in a common rail head and work. And the piston bowl design is different on a common rail to that of a 12 valve or a 24 valve. So if you were to install a 24 valve head you might have a better chance of getting it to work but your not gonna have the proper spray angle on the piston and it will have a poor burn and sooner or later damage something...hope that helps!
Sledpuller500 is offline   Reply With Quote
Old 11-27-2009, 08:49 PM   #5
Sledpuller500
Inline Junky!
Images: 121
Your best bet maybe to sell that 04.5 and build a P-pumped 24valve!
Old 11-27-2009, 09:16 PM   #6
chrisnjane1199
Thank you for the concise explanation Eric. So it sounds like mixing anything older with the common rail stuff is out of the question. I thought I had a nice base to build from, but I guess thats not gonna fly.
Old 11-28-2009, 04:45 AM   #7
Sledpuller500
Inline Junky!
Images: 121
I personally never heard of it being done! I know ya got a good platform but there are just to many things that wont match up!
Old 11-21-2010, 12:41 PM   #8
DieselSchlepper
What everyone seems to ignore in their understandable desire to modify the new technology is that the CR makes more power and less pollution because it is an engineered package that relies totally on multiple sensor inputs and computer control at a very high level. The only potentially satisfactory adaptation I can see is to isolate all the functions dealing strictly with power and develop a package for performance. In the CR, economy, emissions, and performance are closely tied together and computer control is utilized at a very high level. Old thread I know.
DieselSchlepper is offline   Reply With Quote
Old 11-22-2010, 12:33 AM   #9
BriteWhiteRam
CRAZY CANUCK
EFI live is coming soon to provide cheap computer control without going for a $$$$$$$ bosch stand alone controller
Ridin Dirty Club #5
TDG TOTQ
Old 11-24-2010, 03:30 AM   #10
estrada5.9
http://www.phdperformance.com/
P-pump CR
1997 dodge with a cracked dash
estrada5.9 is offline   Reply With Quote
Need some common rail input... CumminsTorq 5.9L Cummins (2003-2007.5) 11 08-14-2009 04:36 AM
new to common rail dangerous196 5.9L Cummins (2003-2007.5) 14 02-20-2008 07:30 AM
Common Rail Fuel Pump Location???? Still Strokin 2008-2010 6.4L Power Stroke 3 02-05-2008 01:25 AM
common rail? uh oh, 6.0 2003-2007 6.0L Power Stroke 13 11-28-2007 11:28 PM
Common rail in a Superduty!! diesel_ram_man Diesel Conversion 1 01-24-2007 02:55 AM
