2004 turns over, wont start - TheDieselGarage.com
Thread Details Posted by 3AE F350, this thread has received 12 replies and been viewed 5488 times.
Old 11-28-2009, 07:35 PM   #1
3AE F350
High on diesel fumes
Send a message via Skype™ to 3AE F350
The ol lady emailed me with this problem about a half hour ago, I am on a ship on the other side of the world. Truck has 73,000 miles, ran yesturday, turns over fine, 40 degrees F out, block heater is plugged in, plenty of fuel, oil is fine. She said it just cranks and cranks, no smoke, nothing. Anything anyone can think of that she can check before I have her call the wrecker?
His: 2000 F250 XLT crew cab, 6" lift, too many miles, banks big hoss bundle
Hers: 2004 F350 Lariat super cab, stock, 73,000 miles
3AE F350 is offline   Reply With Quote
Old 11-28-2009, 08:15 PM   #2
teamroper60
SLAPS President
teamroper60's Avatar
Images: 9
Without a scan tool, I am afraid there is nothing that can be looked at from home.. Call the hook....
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; Silverline turbo-back dual exhaust; 155's from Full Force Diesel (Casserly); Di-Pricol gauges; ARP studs; Dfuser regulated return; AFE PG7;Tunes by Tony Wildman & IDP; B&W hitch; DIESELSITE Coolant filter; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT radio; JL Audio 275w amp w/ 12" sub; Alpine door and rear seat speakers. pics
#43
Dually club member #76
SLAPS President and Webmaster
If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen. - quote by Samuel Adams
Political correctness is a doctrine fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end
teamroper60 is offline   Reply With Quote
Old 11-28-2009, 11:16 PM   #3
3AE F350
here's where it gets real screwy...
It just started fine, no check engine light, and the computer didnt pull any codes. Hope this doesnt become a regular thing.
Old 11-30-2009, 12:48 AM   #4
StrokerDude
StrokerDude's Avatar
I had same symptoms (but never did start) dealer says its blown HPOP quick connect fitting.
Alex C.
R.I.P. 2006 F-250 CC SB Fx4. w/ 500 RWHP *stolen 7/15/2010*
1990 F350 CCLB 4x4 -- 24V Cummins, 200hp DDP's, SuperB over S475-sx3, Cam and valvesprings, Spe-rite Convertor, Billet input.
www.JeffersonStateDiesel.com --- http://en.wikipedia.org/wiki/State_of_Jefferson
Singles Club # 182 - B.O.M.B Squad # 14 - American Club #23
StrokerDude is offline   Reply With Quote
Old 11-30-2009, 01:47 AM   #5
powerstroke90
proud 'stroker
powerstroke90's Avatar
had an ambulance at work do the same thing. it's a 2004 also with the 6.0l. not sure what the outcome is yet. havent gotten the truck back from the shop. it is pretty embarrasing having to call a tow truck to the hospital to tow you back to the station though lol.
powerstroke90 is offline   Reply With Quote
Old 11-30-2009, 02:46 AM   #6
brentos
I Wanna Go Fast!
brentos's Avatar
icp sensor?
Just another 6leaker Thanks to RCD
http://www.youtube.com/watch?v=tzVhcfZN3jw
brentos is offline   Reply With Quote
Old 11-30-2009, 04:58 AM   #7
dmilkman
dmilkman's Avatar
Had the same thing on my '07..Dealer replaced STC fitting and "D" ring on fuel rail plug. Starts like new again..good luck
2007 F250 CC SB FX4 Diesel, 4.5 DR lift, Bilstiens, 325x60x20 Hankook Dynapro AT on 20" KMC Diesels, N-Fab side steps, Oasis Diff cover, deep tranny pan, Dieselsite coolant filter kit, Volant intake, CFM intake elbow, Dr Performance Triple Play module, Ford fuel spring upgrade, 6.4 liter Banjo bolts upgrade RBP 4" turbo back straight piped w/6" tip, DDM 6000K HID's, tinted tails, International Badges, acetoned emblems, Ford Escape "HYBRID" emblem to piss off the greenies
dmilkman is offline   Reply With Quote
Old 11-30-2009, 11:56 AM   #8
3AE F350
Come to find out she didnt have it plugged in after all, thought I'd be mad at her for not trying that first. A few hours later she went into town and the idiot light came on at startup, she took it to the family mechanic to have the code pulled, code 22 missfire/glow plug?? (i'm relaying this from emails she texted me from her phone) Mechanic said hes seen this before on these, and that the harnass connections on the glowplug control module collect moisture and the connections get fouled and that she just needs to unplug the connections and clean them up. Sounds like its worth a try.
It makes sense that it started hard (at 40 degrees) with no glow plugs then started fine once it was plugged in for a while. I just hope her father didnt drench it with ether in the process.
Old 11-30-2009, 12:17 PM   #9
Bcarriveau
********* and Mafia #90
Bcarriveau's Avatar
Send a message via AIM to Bcarriveau Send a message via Yahoo to Bcarriveau
should not have to plug it in at 0*
Bill Carriveau OFFICIAL POO HAULER
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
ARP studs, sct, Leveling kit,Airdog set at 62psi with no factory pump, leveling kit,5" stacks, under cab lights, Large in the way Fan shroud Removed, bed Lights being Re-did. Large Alternator(250amps)(130 amps was so 2003). On 3rd set of Hgs(soon to be 4th), 2nd set of heads, 2nd tubro, egr cooler, FICM and more. When i Turn the Key it does return a Favor, not always in MY Favor.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
We had a deal. You were supposed to make me sexier, smarter and a better dancer. But I saw the video. And I think we need to talk..
How you name your Thread is Important. Read Here
The TDG TOTQ
Bcarriveau is offline   Reply With Quote
Old 11-30-2009, 12:28 PM   #10
hhrecovery
MAFIA #8
hhrecovery's Avatar
Images: 1
could be the problem... it isn't the STC like everyone said cause that is only 05+
Aaron - 2004 F350 "Offroad Edition"
2003 F250 "Pulling Truck"
hhrecovery is offline   Reply With Quote
dt466e turns over but won't start ffclassic Medium and Heavy Duty 3 04-17-2008 01:35 AM
wont start doob51 5.9L Cummins 12 Valve (1994-1998.5) 3 05-06-2007 01:05 PM
7.3 PS turns over but wont start? fastlane5 1994-2003 7.3L Power Stroke 12 08-08-2006 06:33 PM
