What is correct way to lengthen/shorten truck frame? - TheDieselGarage.com
Thread Details Posted by INT_MAN, this thread has received 30 replies and been viewed 49010 times.
Old 11-28-2009, 11:45 PM   #1
INT_MAN
what is the correct way to shorten/lengthen a truck frame?
reason being , I am looking to lengthen a IHC 8100 tractor into a straight truck length.
what is standard way to do this, weld,fish plate etc? I will probably run double frame just to make sure it has enough strength.
truck will probably be registered at 33-39k
any insight?
INT_MAN is offline   Reply With Quote
Old 11-29-2009, 12:44 AM   #2
ktw900
ktw900's Avatar
what we always do is cut it with a cut off wheel,then grind the edges to a v and weld your way out.keep grinding it after each weld so you keep good penatration.then we get 1/4 inch steel broke for fishplates and bolt em in.never had a problem yet.hope that helps a little.
ktw900 is offline   Reply With Quote
The Following User Says Thank You to ktw900 For this addition to TDG:
Duke (11-29-2009)
Old 11-29-2009, 01:53 AM   #3
broncobob
I have done more of both(shorter & longer) than I can remember.ktw900 reply is very good. If the frame is doubled already, you will have to stagger the cut. If it is a single frame rail, you can make your cuts with a torch, cut off wheel, plasma or whatever you have to work with, clean up your cuts and "V" both sides of rail to be welded. Then I fab a large diamond fishplate that is a little less than the width of the frame rail and approx. 10 inches to either side of center. NEVER weld straight up & down from top to bottom as the frame will crack beside the weld. Use 7018 if your welder will, or mig if you have one. The welded joint will be as good as your preparation . Good luk
broncobob is offline   Reply With Quote
The Following User Says Thank You to broncobob For this addition to TDG:
Duke (11-29-2009)
Old 11-29-2009, 02:28 AM   #4
ktw900
ktw900's Avatar
we have welded top to bottom everytime,never had a problem yet with crackin.i prefer a cut off wheel,least amount of heat transfer but thats just me.different strokes for different folks i guess.
Old 11-29-2009, 02:59 AM   #5
PGM
Fleet Owner
PGM's Avatar
I have done dozens of extensions and shortenings, and you guys are all spot on.
I usually cut the rail on a 45deg angle and i reverse it on the other side. Just habit i guess, but it works well, and havent had one fail yet.
I use a Bevel Gauge to make sure i get the angle right on all the cuts, (nothing more annoying that finding the angle on your new rail is a little out of angle), and I always use new rail.
We have a fabrication shop nearby, and i have the new rail sections pressed up from 350 grade high tensile. I never use old/recycled rail, its old for a reason and usually becomes brittle after welding.
I fit a "liner" inside the rail, and usually about 4' long, which is just a smaller section of chassis rail. If the extension is only a small distance, (2-4') I usually just line the whole section to a few feet beyond the joins.
Best way to get it all straight it to find a common point in the old chassis and diagonally measure past the new section to another common point in the old section.
I also tend to put a very small amount of positive camber in if possible so make sure you support it all well and keep it straight whilst welding it together.
If your extending a long way you will also need to put a few more crossmembers in, and fit a center bearing in your tailsahft assemblies, perhaps even 2.
All in all, not a hard job, and as my dear ol dad the engineer taught me...
..... "Measure Twice, Cut once"....
PGM is offline   Reply With Quote
Old 11-29-2009, 06:11 AM   #6
379Longhood
379Longhood's Avatar
Cool
Lots of good info here I just have a couple of addons . when you park the truck move it back and forth a few times to make sure you don't have any scrub stress on the frame . and when ever I strech or shorten a frame I make a set of centerpunch marks exactly 1 foot from the cut/joint for a double check reference , makes you a lot more comfortable when you start to weld to be able to recheck your measurements, I also always make all my cuts 45 degrees but have seen many straight joints also. 45s give you more weld area
have fun
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 11-29-2009, 01:08 PM   #7
bmoeller
bmoeller's Avatar
I'd prefer a plasma cutter over a cutting wheel, and over a torch. Cutting wheel can make plenty of heat its self.
"Obama = Hoax and Chains"
Old 11-29-2009, 01:30 PM   #8
dodgefarmer2
dodgefarmer2's Avatar
heat from the cutting wheel does not compare to the welding heat, using a guide to make a precision cut would help.
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline   Reply With Quote
Old 11-29-2009, 03:06 PM   #9
SmokinCAT
SmokinCAT's Avatar
I agree, but it takes a pretty good plasma cutter to get through frame.
Personally I would have bought a longer truck, anytime you hack a frame and peice it back together I think you lose integrity, but thats just my opinion.
Cody.
79 KW W900A 3406B, Holset HC5 turbo, RTO12513,
4.11 SQHP rockwells
79 KW K100C 400BC1, Holset HT4B hybrid, custom
injectors, RTO12513, 4.33 eaton DS380s
00 Freightliner Classic XL C15
83 KW K100C 400BC3
SmokinCAT is online now   Reply With Quote
Old 11-29-2009, 05:49 PM   #10
Phantom 309
TDG capo dei capi
Phantom 309's Avatar
I,ve only lengthened 3 trucks over the years,. 'Z' cuts to the frame,. beveled edges, rose bud to heat up 6" either side of the weld,. fishplate on the inside,.cross member every 36" or so,.
the one truck is now a 260" 'tri axle' dump with the lift axle in front of the drives,. its been on plenty of mud jobs hauling evil amounts of weight,. never had any issues,.
and for folks that think you're compromising the integrity of the original frame by stretching it,. well mebbe you oughta go look at how they build ships,.
Nick
Phantom 309 is offline   Reply With Quote
Correct optima batteries for truck dayusex 2003-2007 6.0L Power Stroke 42 11-07-2009 08:15 AM
OOpps...this is the correct VIN kidder Ford Oasis requests 2 03-08-2008 02:24 AM
Ford F350 73 79 4x4 truck frame Lonesome7.3 Whats Been Sold 6 07-24-2006 07:45 PM
Need to correct speedo worktruck 2003-2007 6.0L Power Stroke 7 05-23-2006 02:53 AM
