| Thread Details Posted by DM1, this thread has received 39 replies and been viewed 12702 times. |
#1 |
7.3 with a low compression on cylinder #5, is this common?
I'm new here and I just ran into a big problem with my 01 7.3 diesel. only has 77k miles and I'm the original owner so I know its been well maintained.
As I was townig the trailer down the Hwy, the motor started shaking and smoking. Towed it to the neares dealer and they're telling me I need a new motor cause #5 cylinder lost compression (about 60 psi). Is this common and how expensive is it to fix. The dealer wants LOTS of money to fix it. Can it just be the an injector or a valve? It still starts and drives but engine doesnt idle well and has loss of power. Thanks for your input. Last edited by DM1; 11-28-2009 at 10:58 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 |
What tests has the dealer done to confirm the extent of the problem? They certainly should not tell you that you need a new engine without a fair amount of work. There are a number of things that could cause the problems you talked about.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body 2001 F350 SRW flatbed, 4x4, crew cab 1978 International F2275 Dump Truck 1996 NH LX665, steel tracks on foam filled tires 2005 Tackeuchi TB145 2003 Takeuchi TL150 Case 850B Highlight, 4 way bucket |
#3 |
First they told me I need an injector then they did a compression check and said that I need a new motor. Its only $12900 parts and labor. They said I got dirt in the air intake and now I need new rings. Funny thing is I had them do a recall and a checkup 150 miles before and everything was perfect. Lol
01 F350 4x4 |
#4 | |
if you have low compression it is either going by the valves or the rings. either way the engine has to be torn down. It probably wouldn't be a bad idea to get a second opinion or at least a price of haveing the engine rebuilt and installed somewhere else.
Ross Show-ME Smokers 2.6 modified street pulling truck "The Lone Stroke" My Videos 1996 f350, powerstroke, 4x4, 5-speed, 4.56 gears, Swamps 450/600 injectors, Swamps BFH turbo, Swamps Idm, Swamps tunes, BTS oil, SBC clutch, studs, springs, tubes, air to water intercooler, fuel system, factory rods! ![]() Tow Rig 1997 f350, srw, reg cab, 4x4, 5 speed, 4.10 gears, 3in down pipe, straight pipe, mystery chip. Becker Brothers Enterprises |
#5 |
Super Moderator
![]() Join Date: Dec 2008
If you got dirt in it, the COMPRESSOR BLADES would be ruined! I know, I've seen it enough times.
I will *guess* that the injector has failed allowing a massive compression leak, or you have a bad valve (bent, lifter bad etc). GOOD low-miles used engines are 1/3 of that, INSTALLED!
'93 F-250 HD, 7.3L IDI, 5spd - FARM TRUCK I Support: Trailer brakes an every axle over the towing vehicle's GVW; CDLs for RVers; Safety inspections for ALL vehicles and 6 axle trucks (97K GVW proposal). Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin I vote for LIBERTY! |
#6 | |
01 F350 4x4 |
#7 |
So has the dealer you took it to done any work on it yet? If not, I would check the compression on the #5 myself. If it's low, swap the #5 injector with another and see if the problem moves with the injector. If so, like John G. said, you got a bad injector causing some problems. Like John also said, check out the blades on your turbo and see what they look like because if you've pulled enough dirt to wreck a piston, the compressor blades will probably be wrecked too. It seems like if you pulled that much dirt it would have damaged all cylinders and you'd have low compression at all cylinders.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters. |
#8 |
rock removal technition
could be as simple as a bent pushrod, or as bad as a broke ring.
even a possibility of a bad injector cup. or even a loose injector
1996 psd 5speed 4x4 cc 8' bed, 3" body lift, 35's swamped, dp-tuner, intercooled, custom fuel system, no fan, and a few other goodies, 263k. 349.2hp sold 2003 7.3 4r100 4wd sc 8', xlt 20th anniversary edition stock cept for duals. 260k sarted out as a 2wd xl work tk Early 99 CC dually 4x4 4r100 dark lights, dark windows, stainless simulators 99 v-10 4x4 sc sb auto 275hp gas guzzler |
#9 |
you werent using a drop in K&N air filter were you? they have been known to let dirt get by.....
but definately DONT LISTEN TO THE STEALERSHIP....... they just want to replace the entire engine instead of fixing the problem. if changing 1 injector fixes the problem.... your going to be saving a TON of money. just their quote implies how willing they are to rape you.
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo. Last edited by biz; 11-30-2009 at 12:21 PM. |
#10 | |
01 F350 4x4 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Low compression???? | SledMan | 2003-2007 6.0L Power Stroke | 2 | 09-07-2009 09:20 PM |
| Low compression in one cylinder? | SledMan | 2003-2007 6.0L Power Stroke | 4 | 07-23-2009 12:54 AM |
| No compression on #1 cylinder? | WHITEPOWERstrok | 2003-2007 6.0L Power Stroke | 19 | 02-28-2009 08:21 AM |
| 06-24-4 6.0l - Service Remanufactured Engine, Cylinder Block, And Cylinder Head Ident | Squatch | Ford Oasis requests | 0 | 03-22-2007 02:52 AM |
| No COMPRESSION in #4! | Matty69 | 1994-2003 7.3L Power Stroke | 3 | 04-21-2006 12:19 AM |
| New To Site? | Need Help? | TDG Specials |
