13spd transmission problem - TheDieselGarage.com
Thread Details Posted by zx12guy, this thread has received 4 replies and been viewed 953 times.
Old 12-08-2009, 03:03 PM   #1
zx12guy
Hi all, I have a 13spd rto-14613 and for some reason it will only split the last gear (9th) and does nothing when trying to split 6,7,8th. any ideas?
zx12guy is offline   Reply With Quote
Old 12-08-2009, 03:49 PM   #2
379Longhood
379Longhood's Avatar
Check the air pressure AFTER the regulator on the transmission .is this a new problem or did it start with the cold weather? Here where it gets cold a lot we run alchohol "injectors" after the air dryer Also might want to see when the dessicant in the air dryer was changed
Eaton has a good site there is a link on some of the other trans trouble posts
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 12-08-2009, 04:35 PM   #3
zx12guy
It occurs warm or cold weather. I will check the dessicant in the air drier though I dont see any moisture when draining the tanks. I kinda thought if it were an air pressure problem then I wouldnt be able to split any gear whatsoever?
88 T600,BCIII,13spd,3.42s
totin a dump wagon
99 378, 2ws, 13spd,4.33s
Stick hauler
Old 12-08-2009, 07:18 PM   #4
ynot
The other guy
My tranny guy says it's an inlet or outlet from slave problem, and update to the new slave valve (plus clean the system with air tool oil). Hope that does something for ya!!
ynot is offline   Reply With Quote
Old 12-08-2009, 11:42 PM   #5
ktw900
ktw900's Avatar
i would prolly guess the splitter valve to.but being it only shifts in the big hole check that none of the lines are kinked,it dont take much of a kink to lose some air psi.
ktw900 is offline   Reply With Quote
Big Cam Cummins & 13spd do aggar Medium and Heavy Duty 22 09-07-2010 09:22 PM
Transmission Problem roostmoose 5.9L Cummins (1998.5-2002) 3 05-05-2008 11:55 PM
Transmission Problem ChrisP24 Duramax 07.5-2010 (LMM) 10 02-26-2008 02:33 PM
Transmission Problem? kdkjglo 1994-2003 7.3L Power Stroke 10 06-19-2007 04:16 AM
ANOTHER transmission problem.... dondiesel444 Medium and Heavy Duty 6 12-11-2006 09:22 PM
