How do you know if you have bad injector - TheDieselGarage.com
Thread Details Posted by jkdank, this thread has received 3 replies and been viewed 3402 times.
Old 12-14-2009, 07:13 PM   #1
jkdank
I have a 2005 F-250 with 75,000k on it and my 5 year factory warrenty just ran out I'm trying to decide whether I should trade up or gamble on the motor. How do I know if I have bad a bad injector and what should I do? When its warm outside the truck seems to start and run fine but when its cold below 35 degrees it sputters and coughs and sounds like the motor is coming apart. What are the typical symptoms of a cold 6.0 L starting up? Also, is it dangerous to get a chip because I've heard about alot of problems with the motor?
Thank you
james
jkdank is offline   Reply With Quote
Old 12-14-2009, 07:57 PM   #2
ebusa
ebusa's Avatar
Thank you
james
I have an 05 as well and my warranty is over in Feb. I can't comment on how to determine if an injector is bad.
I did have cold start issues like you are describing and I took my truck to the dealer and got the lastest reflash strategy calibrations.
Also, turned out my FICM was bad. Now it starts awesome even on the Street Canned tune on my X3. Last week I started it every moring without problems and it was 15-18 degrees after sitting overnight. Started up quick and smooth.
Has your truck been reflashed? How's your batterys?
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
Toyo 35'' MT's on Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tunes -Strat: VXCF9
Powemax Turbo
PHP FICM tuner
ebusa is offline   Reply With Quote
Old 12-14-2009, 09:45 PM   #3
Bcarriveau
********* and Mafia #90
Bcarriveau's Avatar
Send a message via AIM to Bcarriveau Send a message via Yahoo to Bcarriveau
I injector Buzz test along with a Cylinder contribution test should tell you if you have a bad injector...
Bill Carriveau OFFICIAL POO HAULER
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
ARP studs, sct, Leveling kit,Airdog set at 62psi with no factory pump, leveling kit,5" stacks, under cab lights, Large in the way Fan shroud Removed, bed Lights being Re-did. Large Alternator(250amps)(130 amps was so 2003). On 3rd set of Hgs(soon to be 4th), 2nd set of heads, 2nd tubro, egr cooler, FICM and more. When i Turn the Key it does return a Favor, not always in MY Favor.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
We had a deal. You were supposed to make me sexier, smarter and a better dancer. But I saw the video. And I think we need to talk..
How you name your Thread is Important. Read Here
The TDG TOTQ
Bcarriveau is offline   Reply With Quote
Old 12-14-2009, 11:15 PM   #4
scotty2280
scotty2280's Avatar
why is your warranty up? if your an 05 with 75,000 u should still be under the 5yr 100,000
04 6.0, studs,dj fuel +,isspro gauges,sct by eric,4in silverline w/o kitty,HID's, and other odds and ends
scotty2280 is offline   Reply With Quote
Injector ? rsjohnsn 2003-2007 6.0L Power Stroke 2 07-16-2009 01:50 AM
can u re-o ring an injector without replacing injector? bigswede Medium and Heavy Duty 1 06-15-2009 02:01 AM
Injector help 8yourv8 5.9L Cummins (2003-2007.5) 4 02-18-2009 10:33 PM
Injector/injector tip specs? Moulder 1994-2003 7.3L Power Stroke 2 01-21-2009 04:35 AM
Injector ??? 4cstr 1994-2003 7.3L Power Stroke 10 04-16-2006 01:24 PM
