parking brake Help - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > General Ford Truck and Excursion
Thread Details Posted by Superstroker123, this thread has received 10 replies and been viewed 915 times.
Old 01-02-2010, 10:12 PM   #1
Superstroker123
Superstroker123's Avatar
parking brake Help
how is the easiest way to adjust the parking brake on a 2000 f 350 i failed my inspection cuz the brake does not hold the truck
thanks
Gib
" Your Truck was Reported Blowing Excessive Black Smoke" Salt Lake County Health Department
Some Jackass Turned Me In For Excessive Smoke
Superstroker123 is offline   Reply With Quote
Old 01-02-2010, 11:25 PM   #2
brendonv
brendonv's Avatar
There is a star nut on the inside of the backing panel on the rear brakes. Look for a slit, then turn it with a screw driver/or the brake tool a little at a time.
I wish someone would come up with a drive line brake for these things, I've got a new pedal assembly, and adjust the rears and it works when it wants.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline   Reply With Quote
The Following User Says Thank You to brendonv For this addition to TDG:
Superstroker123 (01-03-2010)
Old 01-03-2010, 12:13 AM   #3
Superstroker123
do you have to pull the rear tires off or is it like to older trucks with drums with a little plug that you pull to get to the adjuster on the inside of the wheel assembley
Old 01-03-2010, 12:26 AM   #4
trackspeeder
trackspeeder's Avatar
It's like the old drum brakes. Pull the plug and play with the adjuster.
01 F250 4X4, 7.3.
90 F350 4X4, 7.3
85 F250 4X2 6.9
08 Arctic Cat 700 4X4, Diesel
Easy button for photos
trackspeeder is offline   Reply With Quote
The Following User Says Thank You to trackspeeder For this addition to TDG:
Old 01-03-2010, 01:33 AM   #5
brendonv
brendonv's Avatar
I see your in North Branford trackspeeder. I live in Seymour, I have family out your way.
Old 01-03-2010, 04:05 PM   #6
Superstroker123
got the parking brake tightened went to test it and it only hold the truck when its in drive not in reverse or neutral is this normal
Old 01-03-2010, 04:10 PM   #7
brendonv
brendonv's Avatar
Hmm.
Mines a stick, when it holds it'll hold in neutral. Maybe try a new pedal assembly? I got one from powerstrokeshop.com for around $70.
I've seen and been in dozens, and I've yet to see one that'll hold on a significant hill.
Old 01-03-2010, 04:15 PM   #8
Superstroker123
ok well im going to see if i can get it to pass today if not ill replace the pedal and go from there thanks for your help
Old 01-03-2010, 04:25 PM   #9
brendonv
brendonv's Avatar
Did you raise the rear and check the drag while you were adjusting them?
Old 01-03-2010, 07:11 PM   #10
Superstroker123
yeah i went and got my inspection and it passed so i will keep an eye on it my cousins truck does the same so i think thats what they do it holds in drive and neutral but not reverse which seems strange but it passed so im pleased thanks for you help
topkick parking brake magnumtow Heavy Duty 7 06-17-2012 01:53 AM
07 w/ABS and parking brake light on honda_guy4 5.9L Cummins (2003-2007.5) 10 01-08-2010 03:48 AM
Parking Brake Help neeltburn 1994-2003 7.3L Power Stroke 6 10-08-2009 12:19 AM
parking brake SmokeyMtnKid 1994-2003 7.3L Power Stroke 3 07-19-2007 12:21 AM
Parking brake adjustment? ACC inc. General Ford Truck and Excursion 2 02-26-2006 07:32 PM
