n14 oil pressure - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by BSouth, this thread has received 18 replies and been viewed 15399 times.
Old 01-23-2010, 01:10 AM   #1
BSouth
Dump Truckin SOB
BSouth's Avatar
n14 oil pressure
Whats normal oil pressure for an n14 cummins?
BSouth is offline   Reply With Quote
Old 01-23-2010, 01:32 AM   #2
ktw900
ktw900's Avatar
well i happen to have an n14 service manual in front of me so....10 psi low idle minimum,30psi at 1300 minimum,45-55psi at 2100.
ktw900 is offline   Reply With Quote
The Following User Says Thank You to ktw900 For this addition to TDG:
BSouth (01-23-2010)
Old 01-23-2010, 02:10 AM   #3
SledMan
SledMan's Avatar
What he said.....Cummins after 1985 were not famous for having decent oil pressure. I had one...1998 model....8-10 at idle, and never more than 37-38 at road speed.
Cummins claimed high oil pressure robbed horsepower.....not that it would help anyway. Damn...did I say that?
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
The Following User Says Thank You to SledMan For this addition to TDG:
BSouth (01-23-2010)
Old 01-23-2010, 03:50 AM   #4
BSouth
Dump Truckin SOB
BSouth's Avatar
Thanks guys! Sounds like I have nothing to worry about then. I just bought the truck and it ran great just was a little worried about the oil pressure.
Old 01-23-2010, 04:07 AM   #5
CumminsISXpower
CumminsISXpower's Avatar
hey NOW!!!! If you dont like the oil psi,shim the pump which is a hell of alot nicer to work on than pulling the pan!!!!!!
CumminsISXpower is offline   Reply With Quote
Old 01-23-2010, 06:34 AM   #6
PGM
Fleet Owner
PGM's Avatar
My rule of thumb has always been 20/40 with an N14 when COLD.
20 Idle, 40 at full noise.
94 Kenworth K100E Detroit 470hp.
94 Kenworth T650 Cat 3406C 425hp.
96 International S3600 N14 460hp.
09 Sterling LT9513 MBE4000 450hp.
08 Sterling LT9513 Detroit 575hp.
07 Sterling LT9513 Detroit 500hp.
07 Sterling LT9513 MBE4000 450hp.
07 Freightliner Columbia 120 Cat C15 550hp.
06 Sterling LT9513 ISM 425hp.
05 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 Detroit 500hp.
03 Sterling AT9513 Detroit 470hp.
___________________________
PGM is offline   Reply With Quote
Old 01-23-2010, 11:23 AM   #7
CumminsISXpower
Min 10,throws codes and dumby light at 8.
Old 01-23-2010, 06:36 PM   #8
Johnp3
If you have a N14 that had say 12 lbs oil preasure and then drops to 10, or lower, then I would be looking at the piston cooling nozzles. If one breaks it can damage the kit. If you have one that will not get oil preasure above say 5 lbs then the gears are slipping on the drive shaft. I have seen lots of them do that, to confirm that you remove the pick-up, and take a large screw driver and turn the gear. I had one that the shaft walked forward enough, that it would disconnect the PS pump coupling. This is a minor problem with a great engine below 500 hp.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 01-23-2010, 07:50 PM   #9
CumminsISXpower
I have also done a few with the gear walking on the shaft. I have to say though not affraid of any N14 525 HP,we have lots and I mean lots of them around here,one in particular has a bullrack fleet of 17 trucks that do not live easy lifes and they have all ran a million plus except one that had injector cup issues. They all run 110,000 plus a year.
Old 01-24-2010, 10:58 PM   #10
Johnp3
Engines are like real estate location location location. Here at 525 we had a lot of broken head bolts blown head gaskets, and when you took off the head you could see where the head was squirming on the block giving you a worn pattern on the block, a perfect imprint of the head gasket.
How do I change the pressure of the tire pressure sensors? Klutch 2008-2010 6.4L Engine Tuner Forum 3 11-23-2009 03:09 AM
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 07:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-10-2009 12:35 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 03:25 PM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 03:42 PM
