DURAMAX Index.
If you are in the market for a Duramax-equipped Light-Duty Pick-up you should read this.
All models utilize Aluminum heads and weigh roughly 835 pounds dry. Allison 1000 transmissions weigh roughly 330 pounds.
LB7: ’01-‘04
LLY: ‘04.5-‘06
LBZ: ’06-‘07
LMM: ’07.5-09
LML: ’11+
Duramax Engines in Chronological order:
Years offered: 2001-2004
Engine Code: LB7
8th Digit VIN Identifier: 1
Specifications:
Engine type: 6,599 cc (6.599 L; 402.7 cu in) V8 turbo
Bore x Stroke: 4.06 in (103.1 mm) x 3.90 in (99.1 mm)
Block / Head: Cast gray iron / Cast aluminum
Aspiration: Turbocharged & Intercooled
Valvetrain: OHV 4-V
Compression: 17.5:1
Injection: Direct; Bosch High Pressure Common-rail
Power / Torque: 300 HP @ 3100rpm / 520 LB-FT @1800 rpm
Engine Changes from previous model: First Year of production. First Common-Rail injected diesel in light-duty vehicles. The LB7 is known for fuel mileage as it had the least emissions control equipment and programming.
Transmission Model & Gears: Automatic: Allison 1000 5-Speed; 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 Rev.-4.49. Manual: ZF-6 ZF S6-650 6-Speed; 1st-5.79 2nd-3.31 3rd-2.10 4th-1.31 5th-1.00 6th-0.72 Rev.-5.23
Transmission Changes from previous model: Introduction of Allison LCT-1000. First Allison transmission in light-duty vehicles.
Transfer Case: NP263XHD Electric Shift; NP261XHD Manual
Transfer Case Changes from previous model: First year of production
Known Motor/Transmission/Transfer Case issues:
Recall for faulty glow plugs from the factory; warranty is 10yrs/200K miles.
Recall Gauge cluster for faulty backlighting; warranty is 7yrs/75Kmiles.
Injector Failure. Valve covers must be removed to R&R injectors.
Injector Harness issues caused by wires rubbing against mount
Transfer Case pump rub issue due to faulty/poorly designed wear indicator retaining clip. The clip rubs a hole in the magnesium case, 246/261/263-series.
Changes to Vehicle from previous model: First GMT800 platform. Model Year 2003 marked with body changes; significant changes to front clip.
Known Major Vehicle Issues:
Tie-rod failure due to 4WD boosted launches or off-roading
Popular Mods:
Aftermarket intake
Programmer/Tuner/Custom Tuning
Turbo-Back exhaust
Resonator removal and block.
Lift Pump
Transmission Upgrades
HD Tie-rods/Sleeves
Years offered: 2004.5-2005/ 2006 LLY is basically a de-tuned LBZ
Engine Code: LLY
8th Digit VIN Identifier: 2
Specifications:
Valvetrain: OHV 4-V
Compression: 17.5:1 / 16.8:1 (2006)
Injection: Bosch High Pressure Common-rail
Power / Torque: 04.5-06; 310 HP @3000rpm / 605 LB-FT @1600 rpm.
Garrett Variable Geometry Turbocharger (VGT)
EGR Valve added
PCV now routed back through Turbo Air Intake (mouthpiece)
Redesigned Valve Covers, eliminating removal to R&R injectors and prevent fuel from pouring into crank-case
Grid Heater removed
High Idle Feature added
Early 2006 LLY model has LBZ updates including Bosch ECM and internals.
Transmission Model & Gears: Automatic: 2004.5-05; Allison 1000 5-Speed 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 Rev.-4.49. 2006; Allison 1000 6-Speed 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 6th-0.61 Rev.-4.49. Manual: ZF-6 ZF S6-650 6-Speed; 1st-5.79 2nd-3.31 3rd-2.10 4th-1.31 5th-1.00 6th-0.72 Rev.-5.23
Transmission Changes from previous model: None
Transfer Case: NP263XHD Electric Shift; NP261 XHD Manual
Transfer Case Changes from previous model: None
Over-heating issues commonly reported
http://www.thedieselgarage.com/forums/forumdisplay.php?f=217
Restrictive mouthpiece
Transmission overheating in cold temperatures, resolved with a TCM reflash (2006 Allison)
Transmission lines leaking at crimped couplers
Changes to Vehicle from previous model: Higher Hood-line signifying Model Year 2005+
Popular Mods:
Aftermarket intake
Cat-Back exhaust
Turbo-Back exhaust
LBZ/LMM/Kodiak or aftermarket mouthpiece upgrade
PCV Re-Route
EGR Blocker Plate & Finger Stick
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Years offered: 2006-2007
Engine Code: LBZ
8th Digit VIN Identifier: D
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Power / Torque: 360 HP @3200rpm / 650 LB-FT @1600 rpm
Cylinder block casting and machining changes strengthen the bottom of the cylinder bores to support increased power and torque
Upgraded main bearing material increases durability
Revised piston design helps lower compression ratio to 16.8:1 from 17.5:1
Piston pin bore diameter increased for increased strength
Connecting rod “ I ” section is thicker for increased strength
Cylinder heads revised to accommodate lower compression and reduced cylinder firing pressure
Maximum injection pressure increased from 23,000 psi (1,585.8 bar) to more than 26,000 psi (1,792.6 bar)
Fuel delivered via higher-pressure pump, fuel rails, distribution lines and all-new, seven-hole fuel injectors
Fuel injectors spray directly onto glow plugs, providing faster, better-quality starts and more complete cold-start combustion for reduced emissions
Improved glow plugs heat up faster through an independent controller
Revised variable-geometry turbocharger is aerodynamically more efficient to help deliver smooth and immediate response and lower emissions
Air induction system re-tuned to enhance quietness
EGR has larger cooler to bring more exhaust into the system
First application of new, 32-bit E35 controller, which adjusts and compensates for the fuel flow to bolster efficiency and reduce emissions"
Grid Heater Standard again
Transmission Model & Gears: Allison 1000 6-Speed 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 6th-0.61 Rev.-4.49.
Transmission Changes from previous model: Change to 6-Speed and upgraded C2 Apply took place in Model Year 06. Different TCM and NSBU, no longer uses Torque Converter speed in management strategy, instead uses ECM RPM. Shifter is now triangular and has a + and – button to manipulate shifting while in manual mode.
Transfer Case Changes from previous model: Pump-Rub issue resolved in Model Year 07 when the case went back to Aluminum.
Pistons are prone to failure when subjected to extreme fueling and injection timing due to aggressive programming and not maintaining a high enough rail fuel pressure.
Minor updates to interior dash/waterfall
Popular Mods:
Airbox mod or aftermarket intake
Cat-Back exhaust
Turbo downpipe-back exhaust
PCV Re-Route
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Years offered: 2007.5-09
Engine Code: LMM
8th Digit VIN Identifier: 6
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Injection: Bosch High Pressure Common Rail with CP3.3 Injection Pump
Horse Power / Torque: 365 HP @3200rpm / 660 LB-FT @1600 rpm
Additional combustion control, including an even more efficient variable-geometry turbocharging system, cooled (enhanced) exhaust gas recirculation (EGR) and closed crankcase ventilation to reduce nitrogen oxides (NOx)
Additional exhaust control, including oxidizing catalyst and new diesel particulate filter (DPF) to reduce soot and particulate matter
Increased-capacity cooling system
New engine control software
Use of low-ash engine oil (CJ-4)
LMM DPF and tuning do not mix well. Regeneration issues may occur and many have been reported. Generally DPF-deleted and tuned LMM trucks experience 1-2MPG better fuel economy than DPF-equipped LMM trucks.
Introduction of GMT-900, new body and interior. Silverado and Sierra have more distinct body differentiation. Two dash layouts; Luxury dash that closely mimics the dash in their GMT900 SUVs, and a Pure Truck dash that is more upright to make way for a passenger seat in place of a center console. Integrated Trailer Brake Controller (ITBC) is now optional.
Known Major Vehicle Issues: Numerous rattles and nit-picks. Frequent accidental 4WD engagement due to location of new 4WD knob and lack of 4WD indicator LED in Dash.
Snow in the air box leading to CEL. There is a TSB to mod the box and grill opening.
http://www.thedieselgarage.com/forums/showthread.php?t=83253
Popular Mods:
Air Box Mod or aftermarket intake system.
DPF-back exhaust (aesthetics only)
DPF/CAT delete with tuning and Turbo downpipe-back exhaust
PCV Re-Route
EGR Blocker Plate
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Years offered: 2011+
Engine Code: LML
8th Digit VIN Identifier: ?
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Injection: Bosch High Pressure Common Rail with CP4.2 Injection Pump
Horse Power / Torque: 375 HP(EST.) @3200rpm / 700 LB-FT(EST.) @1600 rpm
Injectors are now piezo controlled
Urea injection aftertreatment (DEF) to meet ’11 EPA standards
Dual Loop EGR system
DPF system now has a 9th injector behind turbo
B5 and B20 compatible with new fuel lines, fuel system heater element and latest coalescing filter
General Info on ancillary parts:
Allison 1000
http://www.allisontransmission.com/servlet/DownloadFile?Dir=publications/pubs&FileToGet=SA5521EN.pdf
AAM 9.25 IFS front axle(4WD) and AAM 11.50 rear axle, with optional G80 RPO Code Eaton locker availability retained.
http://www.eaton.com/EatonCom/Markets/Automotive/ProductsandSolutions/Differentials/index.htm
<font face=""">http://www.youtube.com/watch?v=KbMZ9vcYVSg</font>
DURAMAX Performance & Tuning
Programmers/Tuners
Intake
Intercooler
Exhaust
Turbo
Fuel
Transmission
Steering
Engine
Swap/Conversion
Programmers/Tuners
There are different types of Programmers/Tuners
Portable/Hand-Held tuners that program the ECM through the OBDII port.
i.e. EFILive & PPE Xcelerator
Vehicle-Mounted tuners that program the ECM through the OBDII port. Most feature a remote display to adjust power levels and gauges.
i.e. Edge Evolution, Evolution CS & CTS
Vehicle-Mounted In-Line tuners that control certain parameters and install between the ECM and engine/FICM?MAF/MAP harness. Most feature a remote display to adjust power levels and gauges. Many believe these do not leave a foot print or are not detectable.
i.e. Edge Juice w/Attitude, Banks & TS MP8.
Programmers & Tuners:
Portable/Hand-Held;
PPE Xcelerator (Four models but each works with all Duramax models)
http://www.pacificp.com/chevy-xcell.php
6-10 levels, Speedo correction, Speed limiter removal, +2-3 mpg, DTC code reading/clearing, Gear Ratio Adjustment and Defueled Shift Option. Hot and Hot+2E.T. can be used to DPF delete an LMM Duramax
+425 HP / +620 LB-FT MAX
EFILive w/ FlashScan V2 Scan & Tune w/2 VIN Licenses (Custom Tuning available from numerous sources)
http://www.efilive.com/index.php?page=shop.product_details&flypage=flypag e_EFILive.tpl&product_id=63&category_id=11&option= com_virtuemart&Itemid=56
Infinite Tuning and Diagnostic Capability, Data Logging and more….
Bully Dog Triple Dog/Triple Dog E3 and Power Pup
http://www.bullydog.com/categories/index/category_page/56
+120 HP MAX
DiabloSport Predator LLY/LBZ/LMM
http://www.diablosport.com/index.php?module=htmlpages&func=display&pid=3
+120 HP MAX
H&S XRT LMM
http://www.hsperformance.com/store/index.php?p=product&id=53&parent=13
+180 HP MAX
HyperTech Max Energy Power/Economy
http://go.hypertech.com/hypertech/products-max-energy-diesel.aspx
http://go.hypertech.com/hypertech/products-max-energy-econ-diesel.aspx
+113 HP / +185 LB-FT MAX
Quadzilla Stealth2 LMM Model can program for DPF Delete
http://www.quadzillapower.com/products/index.cfm/p/Stealth2
+215 HP / +415 LB-FT MAX
Superchips Flashpaq, Mileage Max and Cortex
https://www.superchips.com/#pn=home
+119 HP / +206 LB-FT MAX
Vehicle-Mounted OBDII;
Edge Evolution or Evolution Race 2.4” LCD
Edge Evolution CS (CS Race) 2.5” Color Screen or Evolution CTS (CTS Race) 4.3” Color Touch Screen
http://www.edgeproducts.com/products.php?car_motor_key=75&category_key=all
7 Levels, DTC code reading/clearing Displays up to 8 parameters at a time in digital display mode, Monitors and displays DPF status (LMM), (Race versions can program for DPF delete on LMM)
+180 HP / +395 LB-FT MAX (Modest)
Bully Dog Power Management Tool or Triple Dog GT
+140 HP / +200 LB-FT MAX
DiabloSport Trinity
http://www.diablosport.com/index.php?module=htmlpages&func=display&pid=151
+120 HP MAX
H&S Black Maxx/Active Maxx LMM
http://www.hsperformance.com/?page_id=1315
+175 HP MAX
HyperTech HyperPAC
http://go.hypertech.com/hypertech/products-hyperpac.aspx
Vehicle-Mounted In-Line;
Edge Juice w/Attitude 2.4” LCD
http://www.edgeproducts.com/view_all_products.php
5-6 Adjustable on-the-fly levels, DTC code reading/clearing Displays up to 4 parameters at a time in digital display, Monitors and displays DPF status (LMM)
+150 HP / +350 LB-FT MAX
Banks EconoMind or 6-Gun/6-Gun w/Speed Loader available with Power PDA (Palm Tungsten-Discontinued) or IQ Display unit (5+” Touch Screen)
http://www.bankspower.com/app/index/1#
6 Adjustable on-the-fly levels, DTC code reading/clearing Displays up to 4 parameters at a time in digital display (PDA)
+100 HP / +233 LB-FT EconoMind MAX
+155 HP / +385 LB-FT 6-Gun w/SL or PDA Max
TS Performance MP8
http://www.tsperformance.com/Power_Play.html
3 Levels, Fueling box (Very popular for stacking)
+100 HP MAX
Quadzilla Adrenaline with Pulse Monitor LB7/LLY Only
http://www.quadzillapower.com/products/index.cfm/p/Adrenaline-Chevy-01-04
Intake
Intake Modification or Aftermarket Intakes
Mods
PPE Intake Mod
http://www.pacificp.com/pdf/2006-2007 Airbox Modification LLY-LBZ.pdf
Aftermarket Intakes (In order of popularity)
aFe Power (Offers both Oiled and Dry filters)
http://afepower.com/shop/application_searchnew.php?diesel=true&searchtype=m ake&make=gmc
S&B (Offers both Oiled and Dry filters)
http://www.sbfilters.com/Cold-Air-Intake-Kits/Duramax
Banks Ram-Air (Optional Super-Scoop to draw from under the bumper)
Volant (Optional under-bumper scoop)
http://volant.com/diesel_intake.asp?modelType=Duramax
K&N
http://store.knfilters.com/kits.htm
AEM Brute Force
http://www.aemonly.com/search/results.html?keywords=duramax&submitted=true
Airaid
http://www.airaid.com/Default.aspx
Injen (Available through Amsoil)
http://www.injen.com/docs/typeofvehicle/diesel.asp
Aftermarket Intake Manifold/Turbo Inlet (Mouthpiece)
aFe Power
http://afepower.com/shop/details_ne...&diesel=true&searchtype=make&make=gmc&&brandI D=25
Kodiak MP GM PART # 98011736
LBZ MP GM PART # 98011738
(Search for Part # here) http://www.gmpartsdirect.com/
Aftermarket Intercooler Tube
aFe Power
Banks
Intercooler
Banks
PPE
http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_41&produc ts_id=143
Turbonetics
http://www.turboneticsinc.com/content/intercooler-kits
BD
http://www.dieselperformance.com/index.php/product/index/179P
Exhaust
MBRP (Single & Dual side-exit, Cat/Turbo-back, and Stacks)
http://www.mbrp.com/?section=Automotive
Magnaflow (Single & Dual side-exit Cat/Turbo-back)
http://www.magnaflow.com/02product/02catback.asp
Banks (Single & Dual side-exit Cat/Turbo-back)
Silverline/Ansa (Single & Dual side-exit, Cat/Turbo-back, and Stacks)
http://www.silverlineexhaust.com/Silverline/
aFe Power (Single side-exit Cat/Turbo-back)
Power Flow Exhaust & Grand Rock Stacks
http://www.grpipes.com/powerflow.asp
Diamond Eye (Single & Dual side-exit, Cat/Turbo-back)
http://www.diamondeyeperformance.com/products.asp?cat=exhaust&subcat=chevy/gmc
Turbo
Aftermarket Turbo
PPE (Singles listed, but Twins in the works)
http://www.pacificp.com/store/index.php?main_page=index&cPath=2_41
MPI (Twins)
http://www.maximizedperformanceinc.com/pricing.htm
ATS
http://atsdiesel.com/ats2/products_GM/use/2024314
High Tech Turbo
http://www.htturbo.com/chevy.htm
Industrial Injection (Singles & Twins)
http://www.industrialinjection.com/id54.html
http://www.turbobygarrett.com/turbobygarrett/products/turbo_kits.html
BD
http://www.dieselperformance.com/index.php/product/index/95P
Aftermarket Exhaust Manifolds/Headers & Up-Pipes
BD (Manifold only)
http://www.dieselperformance.com/index.php/product/index/101P
RDL
http://profabperformance.com/jm/
PPE
http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_7&product s_id=216
ATS
http://atsdiesel.com/ats2/product/2044248
Fuel
Lift Pumps/Fuel Systems
AirDog
http://www.pureflowairdog.com/products.html
FASS
http://www.fassride.com/Home/tabid/37/Default.aspx
PPE
http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_7&product s_id=141
Holley
http://www.holley.com/types/Electric Pumps - Carbureted.asp
Edelbrock
http://www.edelbrock.com/automotive_new/mc/fuel_pumps/fuel_pumps_main.shtml
Aftermarket CP3 Injection Pumps
PPE
http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_7&product s_id=105
ATS
http://atsdiesel.com/ats2/product/7014290
http://www.industrialinjection.com/id86.html
Aftermarket injectors/Nozzles
http://www.industrialinjection.com/id87.html
Dynomite Diesel Performance
http://www.dynomitediesel.com/prod_display/Injectors/22/GM-Chevy+Duramax/0.php
ATS
http://atsdiesel.com/ats2/product/7034314
Transmission
Aftermarket Transmissions/Torque Converters/Shift Kits
Suncoast
http://www.suncoastconverters.com/gmc/gm_products.html
ATS
http://atsdiesel.com/ats2/products_GM/use/3094308
http://atsdiesel.com/ats2/product/3024248
PPE
http://www.pacificp.com/store/index.php?main_page=index&cPath=2_15
Precision Industries (PI-ML) Page is not accurate
http://www.converter.com/index.htm
Trans-Parts
http://www.allisontransparts.com/index.php?option=com_virtuemart&page=shop.browse&c ategory_id=9&Itemid=55
TransGo/SK
http://www.transgo.com/sk_generalmtrs.php
Bulk Parts (Trans-Go and other parts)
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Cod e=Allison-1000
Clutch (For those lucky enough to have a ZF6)
South Bend Clutch
http://www.southbendclutch.com/chevy_catalog.html
Steering/Traction
Steering Components
PPE
http://www.pacificp.com/store/index.php?main_page=index&cPath=2_16
Super Diesel
http://www.superdieselperformance.com/
Cognito Motorsports
http://cognitomotorsports.com/store/page144.html
FabTech
http://www.fabtechmotorsports.com/applications/gm/4wd01-06-gmk2500hd.html
Crank It Up
http://www.crankitupdiesel.com/store.htm
ReadyLift
http://www.readylift.com/c-131-tie-...sic-6-lug-2500hd-2000-2010-8-lug-2wd-4wd.aspx
Traction Aids
Cal-Tracs
http://calvertracing.com/cart/ymm.php?year=2006&make=CHEVROLET&model=SILVERADO+2 500+HD
Engine
Head/Main Studs
ARP
http://www.arpdiesel.com/
Connecting Rods/Cranks
Crower
http://www.crower.com/misc/whatsnew.shtml
Carillo
http://www.carrilloind.com/Products/tabid/60/Default.aspx
Swap/Conversion
PPE Duramax Wiring Harness
http://www.pacificp.com/store/index....922f5abdec4b94
Destroked Allison 5-Speed Stand-Alone Kit
http://www.destroked.com/parts/electronics.shtml
Duramax Long Blocks
LBZ-$6873 (2007>Chevrolet/GEO>Silverado 2500 Classic)
LMM-$6832 (2008>Chevrolet>GEO>Silverado 2500)
Thanks to BriteWhiteRam, Merlin5577 and New 0mega! As well as hccumminsmoke and squeeky for helping with pics. I'm posting this without pics right now because this post is huge!
I hope others will also assist here.[/size][/font]
LB7: ’01-‘04
LLY: ‘04.5-‘06
LBZ: ’06-‘07
LMM: ’07.5-09
LML: ’11+
Engine Code: LB7
Specifications:
Valvetrain: OHV 4-V
Compression: 17.5:1
Popular Mods:
Aftermarket intake
Turbo-Back exhaust
Lift Pump
HD Tie-rods/Sleeves
Engine Code: LLY
Specifications:
Valvetrain: OHV 4-V
EGR Valve added
Grid Heater removed
Popular Mods:
Aftermarket intake
Cat-Back exhaust
Turbo-Back exhaust
PCV Re-Route
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Engine Code: LBZ
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Popular Mods:
Cat-Back exhaust
PCV Re-Route
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Engine Code: LMM
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Popular Mods:
PCV Re-Route
EGR Blocker Plate
Race Fuel Valve
Lift Pump
HD Tie-rods/Sleeves
Engine Code: LML
Specifications:
Valvetrain: OHV 4-V
Compression: 16.8:1
Allison 1000
Programmers/Tuners
Intake
Intercooler
Exhaust
Turbo
Fuel
Transmission
Steering
Engine
Swap/Conversion
Programmers/Tuners
Portable/Hand-Held;
+120 HP MAX
+120 HP MAX
H&S XRT LMM
+180 HP MAX
DiabloSport Trinity
+120 HP MAX
+175 HP MAX
HyperTech HyperPAC
TS Performance MP8
+100 HP MAX
Intake
Mods
PPE Intake Mod
K&N
AEM Brute Force
Airaid
aFe Power
aFe Power
Banks
Intercooler
Banks
PPE
Turbonetics
BD
Exhaust
Turbo
Aftermarket Turbo
MPI (Twins)
ATS
High Tech Turbo
BD
BD (Manifold only)
RDL
PPE
ATS
Fuel
AirDog
FASS
PPE
Holley
Edelbrock
PPE
ATS
ATS
Transmission
Suncoast
ATS
PPE
Trans-Parts
TransGo/SK
South Bend Clutch
Steering/Traction
Steering Components
PPE
Super Diesel
Cognito Motorsports
FabTech
Crank It Up
ReadyLift
Traction Aids
Cal-Tracs
Engine
Head/Main Studs
ARP
Crower
Carillo
Swap/Conversion
Duramax Long Blocks
