code isx egr - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by pichu2, this thread has received 4 replies and been viewed 6052 times.
Old 02-15-2010, 03:33 AM   #1
pichu2
pichu2's Avatar
code isx egr
i have the new ride this is a isx st egr 06 volvo 610 but starting to had some troubles the firth is ENGINE mid128sid251 fmi2 , "password" i put in 1234, an it worked and it switched me to a new screen. And what i saw was that it said, TRANSMISSION mid130 pid168 fmi4,BRAKES mid136 sid 254 fmi8,TEMPERATURE,mid 140 pid 110 fmi9,SPEED mid 144 pid 84 fmi2,ECU CLIMATIC,mid 146 sid5 fmi4,ECU LIGHT mid 216 sid 254 fmi2, now the truth is i don't really know what that means, but in the mornings when i start it up, it sounded like a sneeze with up an down rpm's(clack,clack,clack,!!!! sound like the old cat model A) and the cruse control doesn't work neither does the j brakes.but after warming and drive 20 miles averything is work fine, but check light is there, i push reset the ligth is gone!!!someone know how ican fix that, tanx
pichu2 is offline   Reply With Quote
Old 02-15-2010, 03:47 AM   #2
dirty mech
FukeneH
dirty mech's Avatar
turbo is ran with air pressure,so in the morin if tanks are empty you will get up and down rpm's, if i go into work tomorrow i check the other codes
dirty mech is offline   Reply With Quote
Old 02-16-2010, 12:10 AM   #3
bmoeller
bmoeller's Avatar
EGR valve is a common replacement item.
"Obama = Hoax and Chains"
Old 02-16-2010, 11:09 PM   #4
tc2
MID 128 SID 251 FMi 2 engine real time clock power lost
MID 130 PID 168 FMI 4 LOW VOLTS
MID 136 SID 254 FMI 8 Datalink lost at ABS controller
MID 140 PID 110 FMI 9 Instrument cluster reports that engine coolant temp is updating at an abnormal rate
MID 144 PID 84 FMI 2 Road speed-erratic reading according to volvo body ecu
MID 146 SID 5 FMI 4 A/c controller something or other volts low.
MID216 SID254 FMI 2 Outside light controller incorrect data
Looks like you could have some voltage problems...
Useful links:
http://www.volvo.com/NR/rdonlyres/71...ser_manual.pdf
http://www.macktrucks.com/assets/mac...nuary_2007.pdf
http://www.heavydutypowertrain.com/md200codes.pdf
tc2 is offline   Reply With Quote
The Following User Says Thank You to tc2 For this addition to TDG:
pichu2 (02-17-2010)
Old 02-17-2010, 03:04 AM   #5
pichu2
pichu2's Avatar
oh!!!!!! tc2 the truth is i really thank you very much if u need a manuals i have than 150 just tell when an i can see if i can give it to you thank you again i appreciate it
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
B code ?s Psd715 1994-2003 7.3L Power Stroke 31 12-06-2007 03:52 PM
where is the key pad code DETROIT6.0HD General Ford Truck and Excursion 3 02-06-2007 01:42 AM
sct and kam code Adam 2003-2007 6.0 Tuner Forum 13 06-02-2006 08:22 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
