Deutz in F-250 - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by AGFR, this thread has received 19 replies and been viewed 16658 times.
Old 02-15-2010, 04:17 PM   #1
AGFR
Deutz in F-250
Kindly visit:
http://www.magirusdeutz.co.uk./images/F250-1copy.jpg
AGFR is offline   Reply With Quote
The Following User Says Thank You to AGFR For this addition to TDG:
nevrenufhp (02-15-2010)
Old 02-15-2010, 04:39 PM   #2
plainredtruck
plainredtruck's Avatar
Images: 11
Interesting.
Not much on the entire build/conversion process, but it sure sounds like a dependable rig.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline   Reply With Quote
The Following User Says Thank You to plainredtruck For this addition to TDG:
AGFR (02-17-2010)
Old 02-15-2010, 05:18 PM   #3
AGFR
Originally Posted by plainredtruck View Post
Interesting.
prt
A bit more info is available at:
http://www.iowahawk.typepad.com/iowa...Em-If-You.html Scroll to bottom of post.
Drivetrain: BF4L 913/ZF S5-42/NP 205. Fuel system and other items are proptietary. Its extremely economical to operate.
Old 02-15-2010, 07:49 PM   #4
nevrenufhp
Super Moderator
nevrenufhp's Avatar
Do you have any fuel economy numbers? Considering a gasser 400 in a 78 would get about 10mpg. Possibly some more specs on the engine itself, besides being air cooled. Like hp/tq figures, years of production, size, etc
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
The Following User Says Thank You to nevrenufhp For this addition to TDG:
AGFR (02-19-2010)
Old 02-15-2010, 11:10 PM   #5
AGFR
Deutz manufactured the engine as a "special BF4L 913" for GMC a little over three decades ago. I "discover" the engine sitting in Deutz's Richmond, IN warehouse. It was inferred to me the engine was destined for a UPS delivery van that GM was going to produce. However, the union(s) were protesting the use of a German manufactured engine and the project was discontinued. Apparently they forgot GMC was making Deutz's BF6L 913 available in their medium duty trucks about that time. Deutz was most generous in making the engine available to me.
I perfer not to disclose engine output data as it differs from that published by Deutz. The engine, along with the transmission and transfer case, was tested on our dynamometer for base line data and torsional vibration before being installed in the truck. Needless to say, the truck manages to keep up with most traffic.
I consider the truck's fuel economy to be exceptional, although one always wishes it was greater. I hesitate to offer data as we measure test fuel burn in "miles per pound" (some have suggested "miles per barrel") and that's confusing to most. The fuel we use has a wide API gravity (density) variation and the BTU's per pound can differ further complicating things. I offer the follwing link as a glimpse to what the truck can obtain under favorable conditions. Kindly use it and scroll down to the tenth "Update."
http://www.iowahawk.typepad.com/iowa...-cruisein.html
As the fuel temperature in the tank had stabalized I think the fuel burn given is accurate.
Thanks for the inquiry and thank you for the "Thank You."
Old 02-16-2010, 03:04 PM   #6
AGFR
In reviewing my reply to your inquiry I realize I might have been short with respect to the truck engine's output. As configured it has a maximum BMEP of 120 psi when tested to DIN 70020 which is modest for 4.1 liters of displacement. With charge air cooling and other changes a BF4L 913 has reached a BMEP of 225 psi and CHT stayed within limits. However, our goal has been maximum fuel economy and longevity with a wide range of raw well oils as fuel. Currently the truck is undergoing a 600,000 mile inspection.
Click image for larger version
Name:	High Plains Fuel Stop 1998.jpg
Old 02-22-2010, 09:14 PM   #7
Big Stroker
http://www.diesel-engine.cn/deutz/bf4l913-industry.htm
[center]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline   Reply With Quote
Old 02-26-2010, 03:34 PM   #8
navistar45
very cool conversion. back around 87' or so, i came across a 82 model gmc one ton someone left ideling outside one of the local auto parts stores. there was no mistakening is was a duetz. i waited around and asked him about it, claimed he took it out of a gm medium. i have only seen 2 in the medium line, what i learned they were an excellent engine.
navistar45 is offline   Reply With Quote
Old 02-27-2010, 01:05 AM   #9
acesneights1
acesneights1's Avatar
Nice. Hope you never need parts for it. My azz is still sore from the cracked head on my Skidsteer. Deutz parts are INSANE. Simple engine to work on but definitely need the manual.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP.
1998 GMC 2500 Burb 6.5td 4inch ex Autometer fullsweeps.
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline   Reply With Quote
Old 02-28-2010, 03:00 PM   #10
AGFR
Thanks for the compliment
For more information on Deutz powered trucks, visit Roland Sparling's excellent web site:
http://www.magirusdeutz.co.uk/
or
http://www.hcvc.com.au/forum/YaBB.pl?num=1266078916/0
Name:	GMC Deutz Page 3.jpg
ID:	24840   Click image for larger version
Name:	GMC Page 2.jpg
ID:	24841   Click image for larger version
Name:	GMC Deutz Page 1.jpg
ID:	24842   Click image for larger version
Name:	GMC Deutz Page 4.jpg
Deutz diesel, cracked head acesneights1 Medium and Heavy Duty 26 03-21-2010 12:48 PM
Need help, Deutz f4m1008 keeps konking out Glenn4 Utility & Farm Tractors 9 04-28-2008 04:28 AM
how to turn up the feul on a deutz 7085 91/2 7.3idi Utility & Farm Tractors 1 09-16-2007 02:55 PM
