Cat C12 Fuel Pressure? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by nceaglene, this thread has received 3 replies and been viewed 1994 times.
Old 02-26-2010, 04:38 PM   #1
nceaglene
Anyone know what the pressure should be @ idle and @ high idle? Hard starting but runs ok otherwise
nceaglene is offline   Reply With Quote
Old 03-03-2010, 08:41 PM   #2
nceaglene
ok so new fuel pump, new fuel filter head assymbly. reading good prusse at crank. slightest whiff of ether and its off and runnin. kill it and let it sit for more than 1 minute and it will not crank.
Old 03-03-2010, 08:42 PM   #3
nceaglene
determined fuel pump was bad, batteries-junk. problem still remains. no codes.
Old 03-04-2010, 03:02 AM   #4
ynot
The other guy
If you have another one there, swap cam sensors and see if it sparks. Also make sure it spins over 350rpm or it won't fire (sensors won't read). If neither try checkin pulse width (or voltage) on the ECM for the TPS...
ynot is offline   Reply With Quote
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
