Rotella T5 Synthetic Blend? - TheDieselGarage.com
Thread Details Posted by NCfarmboy, this thread has received 51 replies and been viewed 21790 times.
Old 02-28-2010, 09:24 PM   #1
NCfarmboy
Haulin' Hay
NCfarmboy's Avatar
Has anyone tried the Rotella T5 Synthetic Blend? It's a 10w40.
I've been running regular Rotealla for a long time. I'd like to go full synthetic, but for the price, my truck seems to run fine on regular Rotella.
The T5 might be a good compromise.
[IMG][/IMG]
NCfarmboy is offline   Reply With Quote
Old 02-28-2010, 09:30 PM   #2
njneer1
Needs more mod money !
njneer1's Avatar
You can make your own blend....1/2 regular and 1/2 full syn.....synthetic lets you run longer between changes....I use full syn Rotella.....change it every 10k.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, EGT/Boost/ Trans temp
njneer1 is offline   Reply With Quote
Old 02-28-2010, 09:37 PM   #3
Bcarriveau
********* and Mafia #90
Bcarriveau's Avatar
Send a message via AIM to Bcarriveau Send a message via Yahoo to Bcarriveau
Full Syn has proven very good over the last few years on the 6L!.
10K mile intervals are a bad idea unless you are having your oil tested regularly!
Bill Carriveau OFFICIAL POO HAULER
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
ARP studs, sct, Leveling kit,Airdog set at 62psi with no factory pump, leveling kit,5" stacks, under cab lights, Large in the way Fan shroud Removed, bed Lights being Re-did. Large Alternator(250amps)(130 amps was so 2003). On 3rd set of Hgs(soon to be 4th), 2nd set of heads, 2nd tubro, egr cooler, FICM and more. When i Turn the Key it does return a Favor, not always in MY Favor.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
We had a deal. You were supposed to make me sexier, smarter and a better dancer. But I saw the video. And I think we need to talk..
How you name your Thread is Important. Read Here
The TDG TOTQ
Bcarriveau is offline   Reply With Quote
Old 02-28-2010, 09:49 PM   #4
njneer1
njneer1's Avatar
I know lots of guys that succesfully pull 10k or more change intervals on full synthetic .....especially Amsoil folks......with no adverse effects.
I would totally agree with Bill if your duty cycle includes alot of off road or heavy pulling most of the time.
Old 02-28-2010, 09:54 PM   #5
69cj
69cj's Avatar
The 6.0 shears oil like no other engine on the market. You are playing Russian roulette with your engine and injectors. 5,000 miles recommended and 7,500 max with UOA's to back it.
69cj is offline   Reply With Quote
Old 02-28-2010, 10:03 PM   #6
05PSD
05PSD's Avatar
The 7.3 is not as hard on the oil as a 6.0 so you cant compare your 7.3 to it.
With Rotella T 5W40 @ 5000 miles, my oil sheared to a 30W 4 different times. What do you think that oil will shear to after 10K?
05 F350 CC SB Lariat, Silverline exhaust, SCT tuned by Spartan,Inaccurate QZ Commander, deleted EGR, coolant filter, blown headgaskets
05PSD is offline   Reply With Quote
Old 02-28-2010, 10:06 PM   #7
Bcarriveau
Bcarriveau's Avatar
Lol amsiol. Again. 10 is way to much unless regulalry(every) testing the oil every change threw a company like blackstone
And not to mention that your oil will break down faster with little to no load on the motor.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Old 02-28-2010, 10:17 PM   #8
69cj
69cj's Avatar
Back to the OP. I have never seen the T5 oil. Is it CI4+ or CJ rated for diesels?
Old 02-28-2010, 10:54 PM   #9
teamroper60
SLAPS President
teamroper60's Avatar
Images: 9
Very true.. I have seen 7.3's run even further than 10K between oil changes.
Amsoil's "best" oil, the 5w-30HDD sheared to 20W in 8K miles in my truck.....
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; Silverline turbo-back dual exhaust; 155's from Full Force Diesel (Casserly); Di-Pricol gauges; ARP studs; Dfuser regulated return; AFE PG7;Tunes by Tony Wildman & IDP; B&W hitch; DIESELSITE Coolant filter; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT radio; JL Audio 275w amp w/ 12" sub; Alpine door and rear seat speakers. pics
#43
Dually club member #76
SLAPS President and Webmaster
If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen. - quote by Samuel Adams
Political correctness is a doctrine fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end
teamroper60 is offline   Reply With Quote
Old 02-28-2010, 10:56 PM   #10
Bcarriveau
Bcarriveau's Avatar
Shell Rotella T5 Synthetic Blend Technology
printable version THE PROTECTIVE POWER
The combination of synthetic blend base oils and advanced additive system delivers excellent protection, even at low temperatures where the enhanced cold-flow properties help protect your engine.
Shell RotellaŽ T5 is formulated and designed to energize the oil's performance and provides fueleconomy benefits*, improved low-temperature flow, and delivers an advanced "Low-SAPS" formulation which helps control the blocking or poisoning of exhaust after-treatment devices.
* Compared with conventional Shell RotellaŽ T Triple ProtectionŽ 15W-40 engine oil.
TECHNOLOGY LEADERSHIP
Shell RotellaŽ T5 Synthetic Blend Technology is an innovative heavy duty engine oil designed to deliver fuel-economy savings, extended-drain capability, enhanced engine cleanliness, and excellent wear protection.
Shell Lubricants is one of the first companies to offer synthetic blend SAE 10W-30 and SAE 10W-40 viscositygrade products that meet some of the most stringent heavy duty engine oil specifications globally, such as API CJ-4, ACEA E9, and Volvo VDS-4. Shell Lubricants is committed to being the technical leader in heavy duty engine-oil-product innovation.
FUEL ECONOMY BENEFITS
Shell Lubricants continues to be a leader in the development of fuel-economy-lubricants. In 2009, we conducted a large-scale trial of medium-duty trucks based on city and highway driving patterns. Shell RotellaŽ T5 demonstrated fuel-economy savings of up to 1.6% in 2009 on-the-road field testing in medium-duty trucks. (For 10W-30 viscosity-grade-only, highway cycles, compared to Shell RotellaŽ Triple ProtectionŽ 15W-40.) These fuel-economy savings can help lower operation-and-maintenance costs.
MAINTENANCE SAVINGS
Optimize Oil-Drain Intervals
Shell RotellaŽ T5 provides protection against acid buildup that can contribute to corrosive wear, as demonstrated through TAN (Total Acid Number) increase and lead corrosion in several industry-standard engine tests. By controlling TAN increase, Shell RotellaŽ T5 can help equipment owners optimize oil-drain intervals.
Low-Temperature Performance
At lower temperatures, using Shell RotellaŽ T5 10W-30 or 10W-40 can help your engine start more easily than using a 15W-40 viscosity-grade product. Shell RotellaŽ T5 10W-30 or 10W-40 can help protect the durability of the starter and battery during harsh winter climates. (Anti-idling laws in some states force more usage of Auxiliary Power Units and shutting engines off.)
WEAR PROTECTION
Shell RotellaŽ T5 provides excellent wear control, particularly in preventing bore polish in the cylinder liners. Bore polish in the cylinder liners can result in a loss of fine manufactured honing lines, which can lead to excessive liner wear and an increase in oil consumption. Control of bore polish is measured through the stringent Mercedes OM611LA, OM646LA, OM501LA, and Volvo D-12D engine tests. Shell RotellaŽ T5 does an excellent job controlling bore polish in these engine tests.
Shell RotellaŽ T5 provides better low-temperature flow than conventional SAE 15W-40 oil.
CLEANLINESS /DEPOSIT CONTROL
Shell RotellaŽ T5 provides exceptional piston cleanliness and sludge control, exceeding the MB 228.51 requirements in the demanding OM 611LA, OM 501LA and OM 646LA engine tests.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Rotella 5-40 synthetic FFRyan 2003-2007 6.0L Power Stroke 33 11-12-2009 01:27 PM
synthetic for Diesel VS synthetic that can be used in diesels jethrow General Ford Truck and Excursion 8 12-08-2007 06:35 PM
Rotella/Amsoil Synthetic? HTRDDSL 2008-2010 6.4L Power Stroke 3 07-26-2007 12:13 AM
WVO blend??? diesel spaz 5.9L Cummins (1998.5-2002) 37 07-15-2007 03:42 PM
Rotella Synthetic jennamax 2003-2007 6.0L Power Stroke 12 06-11-2007 01:14 AM
