C13 vs. C15 ? - TheDieselGarage.com
Thread Details Posted by niceguypmp3, this thread has received 28 replies and been viewed 9983 times.
Old 03-09-2010, 01:04 PM   #1
niceguypmp3
C13 vs. C15 ?
We were looking at buying a couple more tractors and most of the used tractors that we were looking at have 430 hp C13's. We already have 2 C15's that we haul with that are rated 435 hp. I realize the C13 is a smaller engine. At those ratings for each engine and the trucks being '03 freightliner columbia's for the c15 and '05 columbia's for the c13 and both 10 speeds, would there be much difference in pulling power/torque if we are at 80k gross with a 12'6" high steel gondola trailer behind it? any info would surely be appreciated. Thanks guys!
niceguypmp3 is offline   Reply With Quote
Old 03-09-2010, 01:11 PM   #2
Jfaulkner
Just assuming the '03 C15's are MBN's (single turbo "bridge" engine)and not Acerts?
Jfaulkner is offline   Reply With Quote
Old 03-09-2010, 01:23 PM   #3
niceguypmp3
yes, the c15's are single turbo.
Old 03-09-2010, 02:37 PM   #4
Jfaulkner
Personally I'd buy the C15's and have the ECM's reflashed to an older flash file. (like 6NZ) We've got both an '03 C15 MBN and an '04 C13 and while we've had no problems out of either you can't beat the power and torque of the larger engine.
The reflash can't be done at Cat or any dealer, it's got to be done by a few people on here.
The Following User Says Thank You to Jfaulkner For this addition to TDG:
niceguypmp3 (03-09-2010)
Old 03-09-2010, 05:33 PM   #5
niceguypmp3
Why would you have the C15's reflashed to an older flash file? Just curious.
But yea, I finally got my dad talked into not listening to the salesman who said the C13 would pull just as good as the C15 (the same salesman that last year sold us a freightliner with the ism cummins with 300 hp who said it would pull as hard as a 465 hp n14 that we had. dad believed him and we bought it. we had to make them let us return it because it damn near killed the truck and driver pulling 80k from southern iowa to st. louis. at which point he said "you asked if it could pull it and i said yes.... you just didn't ask how fast! it has no where near the power of the n14" 2 headed !@$%$# Sorry for the rant. Thanks for the info though.
Old 03-09-2010, 07:01 PM   #6
legend10
legend10's Avatar
C15.
legend10 is offline   Reply With Quote
The Following User Says Thank You to legend10 For this addition to TDG:
Old 03-09-2010, 09:50 PM   #7
black_dog106
Originally Posted by legend10 View Post
C15.
.... these guys are giving you excellent info...
black_dog106 is offline   Reply With Quote
Old 03-09-2010, 10:36 PM   #8
Mack427
I would think it would take a C-13 rated at 470 to match your C-15'S max hp on a stock 435 is already 455hp the question is what will being able to haul another 600lb of scrap every load worth to you and how much fuel would you save going back empty, those open top Gondolas pull just about as hard empty as they do full so I'm told
Mack427 is offline   Reply With Quote
Old 03-09-2010, 10:44 PM   #9
black_dog106
true... I suppose one could pull a 5.9 out of his dodge p/u. Think of the weight savings. Could carry another ton of net weight...
And think of the milage gain on the deadhead return trip.......
Old 03-09-2010, 11:06 PM   #10
sulltran
sulltran's Avatar
Talking
I don't care who you are....that's funny right there.
2003 KW W900L Caterpillar C-16 ,6TS injectors(+100hp), C18 1000 HP cam, Pittsburgh Power box, CAT 600 brake saver file, Borg Warner 318883 S586 turbo off Perkins Ind. engine ,turbo boot, oversized Duralite charge air cooler,Mr. Haney's fuel temp wire and a custom 5500lb Lipe clutch.
sulltran is offline   Reply With Quote
