NSBU switch leaking fluid? - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Thread Details Posted by Dux2bux, this thread has received 5 replies and been viewed 2487 times.
Old 03-10-2010, 06:20 PM   #1
Dux2bux
Has anyone experienced the NSBU switch leaking transmission fluid? I either have a bad transmission pan gasket (is getting replaced this week) or the NSBU gasket or seal is leaking. Those are the only 2 things I can figure out that is leaking cause of the location of the leak. It isn't leaking very much fluid and only when I am moving.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline   Reply With Quote
Old 03-10-2010, 08:14 PM   #2
New 0mega
Pardue the Traveler
New 0mega's Avatar
Send a message via Yahoo to New 0mega
Have you checked the lines going to the cooler, I know they leak on newer trucks not sure on a '03.
Smoke!!! Smoke!!!! Are you Smoking yet?
2007.5 Sierra 2500HD SLE 6.6L Duramax Extended Cab Long Box Z71 Fass 150/95, Rare Parts G2 hd tie rods, EFi Live, DSP5 a tune from Duramaxtuner.com, MBRP 4" Downpipe back, Edge CTS Insight, Cognito Idler/Pitman Arm Braces, PPE Deep Transmission pan, deep pan filter, Transgo Jr kit
Canadian Club member #2 http://www.thedieselgarage.com/forum...light=Canadian
Singles Club member #250
http://thedieselgarage.com/forums/image.php?type=sigpic&userid=23125&dateline=124580  0528
For those whom are looking at a Duramax check this thread out.http://www.thedieselgarage.com/forum...ad.php?t=92868
New 0mega is offline   Reply With Quote
Old 03-11-2010, 12:34 AM   #3
merlin5577
Gone Fishin...
merlin5577's Avatar
Send a message via AIM to merlin5577 Send a message via Yahoo to merlin5577
The LB7s arent known for leaking cooler lines, i'd bet its your pan gasket.
-Robert.
My Fleet;
2011 Volkswagen Jetta TDI 2.0L 6A
2010 Chevrolet Malibu LT 2.4L 6A
2003 Chevrolet Silverado LS 6.6L 5A
1997 GMC Suburban SLT 5.7L 4A
If you dont stand behind our troops, feel free to stand in front of them.
Thinking of buying a Duramax? You need to click this link;
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline   Reply With Quote
Old 03-11-2010, 02:34 AM   #4
thefermanator
That guy
thefermanator's Avatar
Mine has a small leak there as well. It's the shift shaft seal. I've replaced mine 3 times now and it still leaks. I ended up putting 2 seals into it and it just barely drips now every once in awhile.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline   Reply With Quote
The Following User Says Thank You to thefermanator For this addition to TDG:
Dux2bux (03-12-2010)
Old 03-12-2010, 08:38 PM   #5
Dux2bux
Thanks for all the suggestions and comments, I have replaced the seal and am waiting now to finish my transfer case rebuild to fill it up. I also noticed that there had at one time a leak from the top of the transmission, guessing there is an overflow of some sort up there or breather, but that is all dirty and not clean. That or the PTO cover has had a leak. I will keep replacing a seal at time till she stays dry I guess. Thanks again guys. don't feel it is coming from the cooling lines, it is coming from the other side of the transmission.
Old 12-08-2010, 04:45 AM   #6
LilMax
Did you ever resolve this? I seem to have the same problem on my 05 2500, ATF looks to be coming from behind the NSBU switch, and pooling all around the lip of the transmission oil pan before dripping off the back. Sure would like to hear about how it turned out.
LilMax is offline   Reply With Quote
Truck leaking clear fluid Skiedwhite250 2003-2007 6.0L Power Stroke 8 03-11-2009 10:30 AM
Oil leaking bad : 01blkf250 1994-2003 7.3L Power Stroke 16 01-30-2009 05:41 AM
Fluid leaking? Rigwelder25 2003-2007 6.0L Power Stroke 13 03-01-2008 04:09 AM
Tranny fluid leaking lilgsx 2003-2007 6.0L Power Stroke 2 08-05-2007 05:06 PM
Leaking again Betaracer 2003-2007 6.0L Power Stroke 2 10-07-2006 06:03 PM
