EGR delete, or replace - TheDieselGarage.com
Thread Details Posted by buldog, this thread has received 4 replies and been viewed 3200 times.
Old 03-13-2010, 11:06 PM   #1
buldog
I have an '05 6.0 PSD with 111,000 miles. I am the third owner, and to my knowledge nothing has been done to the motor, that being major repairs, or tuning.
I am going to put on a coolant filter kit, and was wondering if you guys think that the delete kit is the way to go for the EGR, or there is a company which makes a replacement for the EGR that is built considerably better, and is said to last as long as the truck.
If the EGR can be deleted, what good does it do, and why is it there in the first place?
thanks Mike
buldog is offline   Reply With Quote
Old 03-14-2010, 01:01 AM   #2
lilpooh
lilpooh's Avatar
This could depend on where you live,and how strict you state is on the new emission laws. Alot of the members are just welding the cooler ends shut. when reinstalled the cooler looks stock,but you won't have the issue of the cooler failing and dumping coolant into the motor.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA.
"Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine
lilpooh is offline   Reply With Quote
Old 03-14-2010, 01:10 AM   #3
lilpooh
lilpooh's Avatar
here is a link with pics of the welded egr cooler.
http://www.thedieselgarage.com/forum...ht=Weld+washer
Old 03-14-2010, 03:24 AM   #4
ralphinnj
Got Torque?
ralphinnj's Avatar
Images: 80
thanks Mike
Mike,
I agree with lilpooh on the state laws. Obviously, if that is a concern, then that takes precedent. BUT....if not, I will answer your question:
The EGR is an exhaust gas recirculator. It may sound utterly ridiculous, but there actually is a benefit to taking "spent" exhaust gases and popping them back into your fresh air for use in the combustion chamber. I know, WTF!
Here is what is happening. Nitrogen oxides, or NOx (where x can be 1 or 2) are produced at higher combustion temperatures and are pollutants that the EPA and others have defined as "bad." They can cause "acid rain" in the form of nitric acid. Bottom line is that because they are perceived as bad, the automotive industry has been forced to reduce their emissions. One way to do so is to cool the temperature of combustion through dilution with inert gas. Well, what better source that spent exhaust? Well, it's hot for starters, so it you want to recirculate (the "R" in EGR), you will have to cool the hot exhaust 1st. That is why there is an EGR cooler. So, a portion (not all) of the exhaust gas is redirected back to the intake air after being cooled with a small (and not so well designed) cooler (it uses coolant on one side and hot gas (exhaust) on the other).
When running right, the EGR system (it really is a system consisting of the computer, an EGR valve and the EGR cooler that all work in concert, sensing throttle position and many other variables and then deciding how much to open the EGR valve to reach an optimal level of exhaust gas recirculation) actually does reduce NOx emissions, but as you can imagine, it is at the expense of pure performance. Some may argue otherwise, but less air (because you have spent exhaust gas in there) means less oxygen, which means you can't burn as much fuel, which means less power. No one will convince me otherwise. Ever see a diesel sled puller or dragster with EGR????
Ok, so, why remove it other than a little performance gain? Good question. On many engines, the EGR system does not reduce power levels to a large extent, so if it is running right, it is not a big deal. Maybe up to 10% power loss or so (maybe more, I am guessing). Not the end of the world. The real problem is that many EGR systems don't keep working right. The EGR valve can foul and force you to have EGR flow even when the engine computer does not want it (because the valve gets crudded up and can't close). Worse, the EGR cooler can fail (which can cause "puking" which is when your coolant boils and overflows the coolant reservoir). In the case of the 6.0, the coolant that flows to the EGR cooler first goes through the oil cooler. Same coolant. The oil cooler on a 6.0 has narrow passages that may be fouled (and it is a good idea that you are planning a coolant filter; that is one of the best things you can invest in for a 6.0). If the coolant filter passages get fouled, coolant flow rate is diminished. Now that coolant, already starting to get hot from a long stay in the oil cooler, flows down to hang out with really hot exhaust gas. Guess what? Time to boil! That is a very common result for the 6.0 (and leads to puking). Oil cooler-induce flow reduction leading to coolant boiling in the EGR cooler.
The overall fix is to add a coolant filter (and flush the hell out of your current system) and to remove the EGR system completely. That solves a lot of issues.
Ralph
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline   Reply With Quote
The Following 2 Users Say Thank You to ralphinnj For this addition to TDG:
Powerstroke85 (03-14-2010), shafer171 (03-14-2010)
Old 03-14-2010, 12:59 PM   #5
buldog
thanks all. Thank you Ralph for the explanation, it makes more sense now.
Mike
96 CPS replace Burner718 1994-2003 7.3L Power Stroke 3 02-26-2009 03:42 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
6.2 to replace 5.7 gas roger5-5 Diesel Conversion 17 04-06-2007 03:31 PM
need to replace oil pan deangelof250 7.3L and 6.9 IDI (Pre 1994) 2 03-27-2007 10:57 PM
Replace cat or not lilgsx 2003-2007 6.0L Power Stroke 8 11-28-2005 02:18 PM
