Boost seems low after EGR Delete - TheDieselGarage.com
Thread Details Posted by mbm450, this thread has received 18 replies and been viewed 5138 times.
Old 04-02-2010, 01:16 AM   #1
mbm450
Send a message via Skype™ to mbm450
I have an 06' F-250, I just did a River City Diesel EGR Delete along with a rebuilt 03' turbo. The truck runs great but the boost seems down a little. I used to pull right at 30psi WOT and now it's max is 22-23psi. I have never chipped this truck and is all stock. I also noticed that it has zero smoke when you get on it. I used to see a little smoke if I got on it from around 30mph. Not that his is a bad thing but I was wondering if anybody has noticed the same thing after an EGR delete. The boost just seems to flatten out at half throttle, anything past half throttle and it just wont build anymore pressure, but the power still increases.
Thanks, Brad
mbm450 is offline   Reply With Quote
Old 04-02-2010, 01:31 AM   #2
Bigking
Bigking's Avatar
I would start looking into that turbo. I did the same EGR delet about a month ago. Mine runs great.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline   Reply With Quote
Old 04-02-2010, 01:36 AM   #3
mbm450
I dont think its the turbo because it spools up really fast and has an absolutely awesome whistle. Even when i shut the truck off you can hear the turbo spin down for about 7-10 seconds. It sounds like a cop siren off in the distance. lol
Old 04-02-2010, 02:13 AM   #4
skippy
HalfAst Racing
skippy's Avatar
Images: 1
you possibly have a drive pressure leak or cold side leak.check the up pipes and bellows on the y and all the boots first.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline   Reply With Quote
Old 04-02-2010, 02:24 AM   #5
mbm450
I was kinda wondering about that, Is there any certain way to check for leaks other than visual inspection?
Old 04-02-2010, 03:25 AM   #6
6.0superduty
Powerstroke Puller
6.0superduty's Avatar
is your egr valve unplugged? I think with stock tuning and the egr unplugged, it may be reverting to different fueling and boost tables? I may be wrong though... mine has always been tuned...
07 Classic LBZ 4x4
Efi
leveled out
Suncoast stage 4 w/ 1056
22" Fuel wheels
04 6.0 CC SRW (Sold)
Some pullin goodies
B & B Pulling Team
Troyers Diesel Performance
6.0superduty is offline   Reply With Quote
Old 04-02-2010, 03:39 AM   #7
pstrang
You don't have a problem. That is normal for boost to be much lower without the EGR system. My boost numbers exactly match yours.
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, Dieselsite coolant bypass filter, Frantz oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete, wrapped headers and turbo, ARP studs, OEM gaskets, ported heads and manifolds to match, Hot FICM w/ ID Flash, 08+ tranny pan/filter.
pstrang is offline   Reply With Quote
Old 04-02-2010, 03:40 AM   #8
SICKS-O
Slow 6.0
it is normal to see less boost with an EGR delete kit vs stock
2006 F350 XLT 4x4
ARP Studs, Blocked EGR Cooler, MBRP 304SS Cool Duals, 03 Turbo, Coolant Filter Kit, PCM Flashed Back & Innovative Extreme Tunes - 13.3 @ 99
SICKS-O is offline   Reply With Quote
Old 04-02-2010, 02:50 PM   #9
LokiWolf
LokiWolf's Avatar
Why? Please explain.
2006 F250 CC SB 4x4
4.5 Icon 4-Link, TEI Spacers, and 5 Inch rear Springs.
Farmboy Fabrication Traction Bars.
SCT XCalII tuned by GoGoDiesel, DJ's, and Spartan...
LokiWolf is offline   Reply With Quote
Old 04-02-2010, 03:28 PM   #10
pstrang
I don't know the physics behind it, but it is normal and expected. Before I deleted my whole egr system, I could unplug my egr valve and boost WOT to 22-23 instead of 29-30. I lost 7# on average. Very repeatable.
I'm not sure if it's physics, programming, boost tables, etc. Hopefully someone can answer the question better.
EGR cooler delete + new oil cooler= no boost barnbridge 2003-2007 6.0L Power Stroke 4 11-06-2009 03:28 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
Raising Boost, Meth Injection, Boost controllers, etc.... Stinger23 1994-2003 7.3L Power Stroke 14 04-15-2008 09:35 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
EGR delete and boost control 760 PSD 2003-2007 6.0L Power Stroke 3 07-29-2006 06:59 PM
