DPF Delete? - TheDieselGarage.com
Thread Details Posted by prenn, this thread has received 61 replies and been viewed 24635 times.
Old 04-04-2010, 04:23 PM   #1
prenn
Real Trucks Have 2 Sticks
prenn's Avatar
DPF Delete?
I've got a new 389 pete coming with a 600hp c-15 is there anyway to program it so it doesn't regenerate? i ultimately want to keep it stock but just gut the dpfs out. so it sounds good and so i can put normal straight stacks on it because it wouldn't have the high egts. and it would get better MPG. i don't know why we couldn't do this, all the pickup guys are doing it?
2008 GMC 2500hd duramax cc sb 4 linked solid axle, 38'' toyos on 20" novakanes
www.renntransportation.com
prenn is offline   Reply With Quote
Old 04-04-2010, 06:18 PM   #2
keydl
All the pickup guys don't cross the scales and get suspected.
93 Dodge /CTD, IC, 518, club cab LE, BHAF, KDP fixed, kelderman air ride
81 Isuzu /C223na, 5spd
keydl is offline   Reply With Quote
Old 04-04-2010, 07:24 PM   #3
prenn
prenn's Avatar
thats why i want to leave the dpf under there and gut it out (scales wont be able to know the difference). just need to flash the ecm so it doesnt regen. anyone able to do this?
Old 04-04-2010, 11:00 PM   #4
pichu2
pichu2's Avatar
you should wait until the new engine comes out the maxforce and see what is the difference its a cat custom and dont come to CA if you do this
pichu2 is offline   Reply With Quote
Old 04-05-2010, 02:13 AM   #5
chadk66
Is there anybody knowledgeable enough to get this done. I have an 08' PX80 in a peterbilt that is on a water well drilling rig. This thing is an absolute nightmare. The rig runs at an idle pretty much all day drilling holes. It doesn't travel more than 150 miles from our shop and is out in the middle of nowhere in western ND and eastern MT. Never goes through a scale and is on gravel roads 95% of the time. I absolutely cannot run with this DPF any longer. It is going to kill us financially. If anybody knows how to work around this and eliminate the DPF I really need to know.
chadk66 is offline   Reply With Quote
Old 04-05-2010, 02:58 AM   #6
josh G
Some one correct me if i am wrong but if the ecm does not see high back pres it will not want to do an active regen. If you leave all the sensors intact it sould work. The delete kits for the pick ups just look like a piece of pipe with bungs welded in for the temp and differental pressure sensors.
josh G is offline   Reply With Quote
Old 04-05-2010, 03:10 AM   #7
prenn
prenn's Avatar
the truck was built friday and should be on its way out here. I am in Ca and i'm not scared. how would the scales ever know the difference if the DPF is gutted out?
Old 04-05-2010, 03:11 AM   #8
prenn
prenn's Avatar
It would be great if that works?? but i know the pickups all have to be programmed to not regenerate
Old 04-05-2010, 04:24 AM   #9
budtoh3zo
Yup we have to be programmed if we dont program are trucks it goes into a constant regen. Also have to put all the sensors back into the exsust.
2008 F-350 Lariet 6.4L 170,000 km spartan tuned 275 daily
2006 yamaha Vmax
2003 F-350 XLT 6.0L just bought 215,000 km all stock for now.
2003 suzuki 1000 GSX-R
1993 F-250 460
1978 F-150 stock waiting for a paint job
Near GP alberta.
CC#58
budtoh3zo is offline   Reply With Quote
Old 04-05-2010, 04:53 AM   #10
pichu2
pichu2's Avatar
the problem that i see is that it wouldn't be a scale or a smoke inspector(yes). the problem with the new cat engines (you know the problem they had)is not the same like other engines. CAT every time it sells a motor(accert) it is checked by air resource, i dont know if it EPA too after sale. also it needs to be checked at least once a year. thats where i see that where your going to have a problem since they check. imagine if you refuse to go to a clean dpf.they(cat) can put the finger with carb, and another thing the CAT system is complicated. remember it needs a line of diesel after the turbo and then the DOC thats inside dpf in the front. just research caterpillar if your engine needs to be check 2 time ayear.for it to be good i think if they say you no need to just do it ,no matter what!!
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
EGR delete imported_Honda30 2003-2007 6.0L Power Stroke 5 10-30-2006 09:15 PM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
