| Thread Details Posted by T Red, this thread has received 10 replies and been viewed 8585 times. |
#1 |
Pump diagram for 855 cummins
Does anyone have a diagram for the PT pump? Or is there a place I can download a pump manual?
Thanks, Tim |
| Sponsored Links | |||
Advertisement | |||
#2 |
Bump , if you have no luck on this forum try http://www.heavyequipmentforums.com/...splay.php?f=28
there is a guy on that one that has some old cummins books
Canadian Club member 27 '88 379 exhd 3406C 15 40s 10 pete unimounts '93 K3500 6.5 4L80 4" exh '62 gmc shortbox 454 super t10 big brakes JD 820 black dash 12V92 waitin' for a truck (mega ratrod) ![]() pettibone s20 3306 pc |
#3 |
I have some Diagrams, but they are old. I was looking for them as well, and i found it in a library in my city and they didn't let me check out the book. I copied them, if you send me a fax number or i can scan them and then email it to you. I don't know if you'll need them because the pump is old and its a PT.
#4 |
Diesel Dubbah
What do you want to know, they are pretty simple, I just resealed one last week and was surprised at how little was in there.
'87 Autocar ATF 3406B 8LL 4:11's and tall rubber
#5 |
PB SHOP FOREMAN
they are pretty simple....like ital said. what exactly are you looking for?
SHOP FOREMAN FOR PETERBILT IN THE GREAT STATE OF TENNESSEE.....28YRS JOURNEYMAN TECH |
#6 |
This is on a 1979 290.
I really just like to know how things work. So it's not imperative that I find a diagram. I have an old diagram from probably the 60's. When I'm accelerating through the gears at a certain rpm and load I guess the boost from the turbo signals the pump to pump more fuel. The increase in power is very noticeable. I'm just curious whats going on. It would be nice to have the boost a little sooner. |
#7 |
Diesel Dubbah
Thats the AFC valve doing it's thing, holding back fuel until it sees boost to burn it cleanly. Pry the tin cover thats behind the throttle arm off, there is a screw that stares you in the face, back the lock nut off and screw it in some, try it. That'll give you better throttle responce.
#8 |
Euro Sparky/ Wrencher
Ici l'image de la pompe de PT ressemble
here the image of the PT pump look like ![]() Merci,Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?) |
#9 |
Imagine my surprise to see the one and only French Electrician on the diesel forum. I don't post much (as SmithBuilt) but have seen your posts over on the MH forum.
Thanks for the diagram. It appears that pump does not have the AFC. Thanks itali83 I will try that. Tim |
| The Following User Says Thank You to T Red For this addition to TDG: | french277 (04-12-2010) |
#10 | |
Par la voie le diagramme j'ai posté ici il n'y avait pas AFC ainsi la valve AFC sera trouvée entre la valve coupée et le corps de pompe cependant il y a quelques modèles qui ont l'AFC sera sur la couverture ronde où Max et la vis de vitesse inoccupée seront placés aussi. Yep., you got it correct it is the only true French Electrician and I do work on a bit of larger diesel engine more common found on larger generator units. by the way the diagram I posted here it did not have AFC on it so the AFC valve will be found between the shut off valve and the pump body however there are some models that have the AFC will be on the round cover where the max and idle speed screw will be located as well. Merci,Marc
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1988 3406b Injector pump diagram | rharveysr | Heavy Duty | 7 | 01-10-2010 01:55 AM |
| new guy needs serpentine diagram for 5.9 cummins | georgechekay | Introductions | 2 | 11-18-2007 03:34 PM |
| '95 12v Cummins p-pump | Fordpowrstroke7 | Whats Been Sold | 6 | 09-26-2007 07:38 PM |
| 1st Gen Cummins wiring diagram | 01duramax6spd | Whats Been Sold | 0 | 02-13-2007 04:01 PM |
| P-pump diagram | Timbeaux38 | 5.9L Cummins 12 Valve (1994-1998.5) | 18 | 06-23-2006 04:11 AM |
| New To Site? | Need Help? | TDG Specials |
