P0700 - TheDieselGarage.com
Thread Details Posted by Trip, this thread has received 1 replies and been viewed 1471 times.
Old 04-20-2010, 11:48 PM   #1
Trip
Trip's Avatar
Angry P0700
Ok injector is in the truck, ypipe fixed wheel bearing and new tires done trans temp gauge sender done... now this I was cruising down a somewhat normal flat street @around 50Mph and 14-1500rpm and the truck downshifts to around2000 rpm I think that's odd no big deal still cruising make a left and accelerate once up to 55 or so stupid Engine lamp comes on I believe this light never goes out never it is the trucks way of telling me that it knows I am here. So I detour and grab my PC run AE and it says P0700 Transmission control system, DTC says internal transmission fault. No freeze frame or any thing where do I go from here any one deal with this should I stop driving it around. I need a transmission guru. I HATE ATUOMATICS
I don't understand them I don't want to just start throwing parts at it. I brought up one of the screens that allow you to watch what its doing and occasionally like every 3-5 seconds AE would say no read or something along those lines.
Thanks guys
03 F-250 Lariat 4X4 6.0L- NEW ID PROGRAMED FICM 105,000 (sitting on shelf while I figure out whats going on with the turd...furd) wheel berring 103,000 Dfuser coolant filter104,000, EGR plug104,000mi, y-pipe109,800mi,bootlegged 3.5" straight pipe110,000, rotors and pads on all 4 points 110,400mi, 35X12.50R17 Toyo M/T@ 111,300 ICP sensor 115,000
taken over at 103,000mi June-2009
WALNUT (anti-ACORN) member#23
Trip is offline   Reply With Quote
Old 04-21-2010, 06:41 AM   #2
Trip
Trip's Avatar
Ok so I was reading thru some old post's that I had, in the past I have had a P0500 speed sensor A along with the P0700 where is this located?I did not throw a code this time for it but it has thrown in the past maybe this is where my problem is at.
and just to add to it I did back out of the Enhanced POWERTRAIN and went to the trans program on AE and there were no other codes.
P0700 Code squeeky GM Transmissions 2 01-20-2009 09:20 AM
allison P0700, P0708 code's, need some help sparkchaser221 GM Transmissions 5 02-25-2008 03:24 PM
