how to clear codes? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by ehopp88ss, this thread has received 9 replies and been viewed 11349 times.
Old 04-26-2010, 01:24 AM   #1
ehopp88ss
2004.5 Dodge Ram 2500
ehopp88ss's Avatar
how to clear codes?
hey guys.
so as some of you know i am in the process of making a cold air intake outta the stock one on my truck.
i also changed the fuel filter and was unsure if the o ring sealed so me being me i started it to see if it was indeed leaking (with the MAF sensor disconnected.
it set the check engine light. and codes po173 and po0073. i already looked the codes up on the sticky and i believe they are just from running it without the MAF.
is there a way to clear the codes on the dash (like a Cadillac)?
i already know how to access the codes (key on three times) but im not sure if theres a way to clear them.
thanks
erik
Erik
My Vehicles
2004.5 Dodge Ram 2500 4X4 QCLB, NV5600, 177K miles, 10000k HIDS, FASS 150, EDGE juice w/ attitude "HOT UNLOCK", VALAIR 650HP DD thanks to DAN'S DIESEL PERFORMANCE!
1988 Monte Carlo SS, 305 SBC, true dual 2.25" t-304 Stainless exhaust, T-Tops, custom red pryzmatique paint, 2 12" Alpine Type-R Subwoofers, 500 Watt Alpine amp, Alpine speakers inside, complete 2 year ground up restoration, 22K miles on rebuild
ehopp88ss is offline   Reply With Quote
Old 04-26-2010, 01:34 AM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Reconnet the MAP and check for codes. It will reset after so many key cycles once the problem is no longer detected. Other wise if you don't want to live with it you need a scan tool or someone with a tuner like smarty to clear the codes.
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
The Following User Says Thank You to neeltburn For this addition to TDG:
ehopp88ss (04-26-2010)
Old 04-26-2010, 01:36 AM   #3
ehopp88ss
ehopp88ss's Avatar
thank you sir. so it will clear itself eventually?
heres another question. so one of the codes it set was for a lean condition. could this be caused by the MAP sensor or could this be the symptoms of a failing lift pump?
thanks
erik
Erik
My Vehicles
Old 04-26-2010, 02:18 AM   #4
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
[quote=ehopp88ss;984881]thank you sir. so it will clear itself eventually?
Yes If there is not problem it will eventually go off, I my self am not paitient enough to wait for this. You could also have Autozone or a car parts place clear them.
The lean condition is not because it is not getting fuel it is because the O2 sensor in the air intake was not plugged in. This caused the ECM to know know how much fuel to put with the air coming in.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 04-26-2010, 04:31 AM   #5
ehopp88ss
ehopp88ss's Avatar
another question?
could me being a dumba** and starting it without the map sensor in cause it to run weird for a while?
i just took it out for a spin and she is running a little weird.
thanks
erik
Erik
My Vehicles
Old 04-26-2010, 03:42 PM   #6
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Did you prime the fuel system after you where done? You can do this by cycleing key 3-4 times and not starting the truck. If you didn't I would drain some fuel out of the water seperator and and try to reprime the fuel system.
I doubt this is the case at all but the o2 sensor and intake air temp sensor in the air intake can get damaged ( MAP sensor is in the head) make sure you have them clicked in good and they are not loose in the air intake. They should not be damaged but simply removing them once, just make sure the pins in the connection are all straight and locked on the sensors good. I wouldn't sweat it man, did you light clear yet? It's amazing how that little amber light makes you think something is wrong even if it isn't!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 04-26-2010, 05:08 PM   #7
ehopp88ss
ehopp88ss's Avatar
thanks for this amazingly detailed info.
my dad has a scanner, snap on i think not too sure but we cleared the codes last night and i drove it for about 2 hours last night and an hour to work and so far nothing has gone wrong. (knock on wood) haha
Erik
My Vehicles
Old 04-26-2010, 05:17 PM   #8
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Sounds like your golden then man!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 04-26-2010, 05:28 PM   #9
ehopp88ss
ehopp88ss's Avatar
i hope so. and the good thing about the light being off is that if the piece that i glued back on breaks and starts sucking air the light will go on and i'll know its broken.
Erik
My Vehicles
Old 04-28-2010, 02:18 AM   #10
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
if your a little unsure about your glue Erik you could throw a couple short screws into it to hold it in place, thats what i did, i got impatient and put screws into it and threw it back on the truck before the glue was entirely set
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
ehopp88ss (04-28-2010)
99-04 clear headlights x2 6L strokin Whats Been Sold 2 02-27-2009 10:39 PM
Clear cab lights for OBS Dualie General Ford Truck and Excursion 2 07-03-2007 01:10 AM
6.0 won't start... clear codes, then starts ekbearly 2003-2007 6.0L Power Stroke 1 08-26-2006 03:41 AM
Why you use a 1.4 not a 1.3 to shoot clear TooMuchBoost The Detailing, Paint & Bodyshop 7 04-09-2006 05:28 PM
