Cummins ISM crankcase pressure - TheDieselGarage.com
Thread Details Posted by houndsville bob, this thread has received 7 replies and been viewed 13955 times.
Old 05-01-2010, 02:00 PM   #1
houndsville bob
Trying to determine cause of high bottom end pressure. Removing oil filler cap or dipstick this engine pushes out a lot of oil smoke and gets worse as it warms up. The blowby tube discharge appears to be clear. Engine CPL is 8557; Ser#35105225. Any advice/assistance will be greatly appreciated.
houndsville bob is offline   Reply With Quote
Old 05-01-2010, 05:58 PM   #2
Johnp3
What I would do is with an adapter, put air in the intake side of the engine and put in 30 lbs, remove the valve cover first and look there are three "V" shaped areas in the rocker box intake aluminum cover, they blow out the gasket there a lot of the time, Valve guides also a possibility. Other possibilities are the turbo, air compressor, and a bad cylinder.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
The Following User Says Thank You to Johnp3 For this addition to TDG:
houndsville bob (05-01-2010)
Old 05-02-2010, 02:31 AM   #3
itali83
Diesel Dubbah
itali83's Avatar
If your rocker box gaskets are bad and leaking that much boost into the crankcase, you will have a good oil leak just above the head, if not, most likely in the motor. They score liners like there no tomorrow, especially if it's had a bad injector in the past for any ammount of time and if it's a high horsepower motor. 99% of the ISM's I've had with high blowby, are because of worn cylinders, the fleet I work for has a lot of M-11's and ISM's. I'd put a water manometer on it to measure the ammount of blowby, anything around 18" or so of water we'll let go, but up over 20" she's tired. Measure it so you know exactly how much there is, not just by looking at it. I've done it and been amazed by how much I thought it was huffing out the oil fill and how little it really had by the guage.
'87 Autocar ATF 3406B 8LL 4:11's and tall rubber
itali83 is offline   Reply With Quote
The Following User Says Thank You to itali83 For this addition to TDG:
houndsville bob (05-02-2010)
Old 05-02-2010, 03:26 AM   #4
ynot
The other guy
Another quick all time Cummins check, for all their motors, is to run it at idle, hot, remove the oil fill cap and hold your hand over the oil fill. If it goes "pump-pump-pump", yank it apart. She's done... That's the only thing I ever do to test them anymore, and has never failed
ynot is offline   Reply With Quote
The Following User Says Thank You to ynot For this addition to TDG:
Old 05-03-2010, 02:57 PM   #5
fjh
Tonys check holds true for most engines look for puffing at the fill tube!
fjh is offline   Reply With Quote
The Following User Says Thank You to fjh For this addition to TDG:
houndsville bob (05-04-2010)
Old 05-03-2010, 05:53 PM   #6
Johnp3
If you do not have adapters and the equipment you can start it with the air intake open and restrict the flow, with the oil fill off. If if is sucking in air and now blow by then it is also the rocker box gasket. You can do it by taking off the cross over pipe and rolling the hose in to restrict. Just a thought.
Old 05-04-2010, 09:40 PM   #7
houndsville bob
Thanks for all the help and advice. Road tested truck 14 miles with a jug attached to the blowby tube and accumulated a half quart engine oil. Applied shop air to the compressor inlet quickly blew oil drops out the blowby tube and smoke out the filler cap and dipstick tube. Pulled compressor off today and am awaiting replacement. Hopefully a new compressor will take of the problem. At least I'll have one good piston out of 7!!! THANKS AGAIN!
bob
Old 05-06-2010, 12:06 AM   #8
itali83
Diesel Dubbah
itali83's Avatar
Thats wishfull thinking, you could have just unhooked the air compressor outlet tube to make sure the compressor was unloaded and seen if the blowby changed. I hope it is just your air compressor, but I've never seen one push that much oil, the single lungers don't even puch that much air out of the discharge line, let alone just have that much leak by.
Cummins Big Cam Fuel Pressure? trucker378 Medium and Heavy Duty 4 07-12-2009 10:06 PM
cummins L10, no oil pressure sdan27 Medium and Heavy Duty 7 05-30-2009 07:11 AM
Diesel in my crankcase swhit25 Duramax 2001-2004 (LB7) 5 02-29-2008 11:27 PM
Cummins fuel pressure Mack Doctor Jr. Medium and Heavy Duty 2 08-06-2007 04:44 AM
cummins oil pressure sending unit barnyard 5.9L Cummins (1998.5-2002) 10 07-16-2007 06:37 PM
