Bleeding fuel system - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (Pre 1994)
Thread Details Posted by RJC, this thread has received 7 replies and been viewed 2762 times.
Old 05-21-2010, 04:33 AM   #1
RJC
I have a 1993 5.9 3500 and I am new to diesel engines I changed out my fuel filter not knowing that I should have primed the new filter before I installed it. I have air trapped in the system and needing to know the best way to bleed the system. When I crank the engine it tries to fire up but cuts right out. Any suggestions would greatly be appreciated.
Thanks
RJC is offline   Reply With Quote
Old 05-21-2010, 02:58 PM   #2
JDolezal
JDolezal's Avatar
Thanks
Well did you prime the pump by the manual lever on the lift pump? if not do that. Your gonna need to crack your injector lines loose to bleed it, But i can not remember if it's all of them or the first one. (I'm sure someone else will chime in) Then start it. It's going to run like crap for a minute, but then as the air comes out of the fuel system tighten the back down. I know it sounds weird to hear but makes much more sense when you see it done.
91.5 Dodge 250, rclb, 4x4, Getrag, little extra fuel and timing, straight pipe
94 Dodge 2500, rclb, 4x4, NV4500, little extra fuel and timing, straight pipe
95 Dodge 2500, rclb, 4x4, auto, gasser.
02 Dodge 2500, rclb, 4x4, NV4500, Edge EZ, straight pipe
JDolezal is offline   Reply With Quote
Old 05-21-2010, 03:43 PM   #3
Philip
There are two steel lines on the fuel filter assy. The line closest to the injection pump has what looks like a small bolt in it. Loosen that small bolt about 1 turn. Then pump the lever on the side of the lift pump. When you see clear fuel coming from the bleeder screw. Tighten it back up. Pump the lever a few more times till your feel the lever getting hard to move. Lock the lever back into the upward postion. Then try to start the truck. You might get lucky.
If it doesn't stay running. Crack the 1st three injectors lines loose. Spin the engine over. As you see the injectors lines throwing high pressure fuel. Tighten them back up. Have the engine spining while your doing this. By the time you have the 3rd line tight. The engine should be running. If it is missing. Loosen the other lines off one at a time. Tighten them as you see high pressure fuel flow.
Leave #6 cylinder till last. If the engine isn't missing leave it alone. That one will oil the windshield down.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, HX40/16, G56 /SBC Con-OFE, 307's axles' 2" skyjacker lift, B&W flatbed
Philip is offline   Reply With Quote
Old 05-21-2010, 03:44 PM   #4
RJC
Yes I did prime the level on the pump and opened the low pressue vaule as suggested in the manuel. So should I go ahead and crack all the injector lines and try to fire up while it is cracked then tighten after all air is out?
Thanks
Old 05-21-2010, 03:50 PM   #5
JDolezal
JDolezal's Avatar
just crack the first one loose and she if it will run.....If if keeps running rough do the others also. I can't remember for sure If its the cummins or the old IH tractor engines that you need to crack all of them on.
Old 05-21-2010, 03:52 PM   #6
RJC
Hi Phil,
I just saw your reply just as I when I was responding to JDolezal. I did the lever prime and lossen the low pressure valve. I will try and loosen the 1st 3 injectors. Since I am here alone would I be able to crank and let air out then tighten down or would I need a second body to keep it cranking as I tighten?
Thanks
Old 05-21-2010, 04:50 PM   #7
RJC
I got her fired up. I did crack 3 lines, cranked it over unti i have fuel coming out, tighten them up and fired right up.
Thanks again for your replies.
Old 05-21-2010, 09:32 PM   #8
Philip
Glad to hear is running.
Bleeding vaccuboost 625fireman Heavy Duty 2 07-15-2009 02:17 PM
bleeding fuel lines jdreda Duramax 2001-2004 (LB7) 15 04-10-2009 02:11 AM
Brake Bleeding Burner718 General Ford Truck and Excursion 3 01-13-2008 05:06 AM
Brake Bleeding Burner718 1994-2003 7.3L Power Stroke 3 01-11-2008 02:38 AM
Bleeding coolant system? bigs rig 1994-2003 7.3L Power Stroke 6 10-31-2006 04:10 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
