#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ripmf666, this thread has received 0 replies and been viewed 15149 times.
post #1 of 1 (permalink) Old 08-10-2009, 05:46 AM Thread Starter
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Service Information
2007 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Bulletins By Category | Technical | Document ID: 2216135
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced Power Message, DTC P0101 Set (Perform Repair as Outlined) - (Dec 3, 2008)
Subject:Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced Power Message, DTC P0101 Set (Perform Repair as Outlined)
Models:2007-2009 Chevrolet Silverado 2500/3500 Series
2007-2009 GMC Sierra 2500/3500 Series
Equipped with 6.6L Diesel Engine (VIN 6 -- RPO LMM)
Condition
  1. Verify the condition by questioning the customer as to when the condition occurs (during or right after a snow storm).
  1. Using the new air cleaner cover, GM P/N 20821430, drill five 25 mm (1 in) holes in the cover as shown.
  2. Install the emission label, GM P/N 19180225, to the new cover.
  3. Remove the existing air cleaner cover and install the new cover with holes. Provide the customer with the original cover and instruct them to reuse for summer.
  4. Instruct the customer to install the grille opening section only (1st design, 2 piece cover) of the winter front. If the customer has a one piece cover (2nd design) or no cover at all, obtain the grille opening section only, GM P/N 25822811 (GMC) or 25822812 (Chevy). The air cleaner cover with holes and the grille opening cover must be installed to ensure a complete repair. This repair allows warm air to be circulated into the air cleaner, which melts the snow.
Parts Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7926*
Repair to Correct Snow Intrusion into Air Cleaner Box
0.4 hr
* This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
2009 General Motors Corporation. All rights reserved.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
Closed Thread
Check engine light Fat Kid 6.7L Cummins (2007.5-2011) 7 04-19-2008 04:03 AM
Check Engine light on d67rdave Duramax 2006-2007(LBZ & LLY) 16 10-04-2007 12:28 AM
Check Engine Light Noah 2003-2007 6.0L Power Stroke 1 08-18-2007 06:13 PM
Check engine light Don Stefanik 2003-2007 6.0L Power Stroke 3 02-19-2006 01:25 AM
Check Engine Light SHORTBUS 1994-2003 7.3L Power Stroke 12 09-27-2005 01:00 AM
HTML code is On
