Diesel Truck Forum - TheDieselGarage.com - View Single Post - 6L specs and more.
View Single Post
post #7 of (permalink) Old 07-13-2010, 07:50 PM
gas/diesel eng rebldr
6L stickies
Thank U for sending the Block/Head spec.s {6.0L} ,is there any chance that MAYBE U could send some more Head Spec.s? *vlv.guide 'instl hgt.' & clearance[int & exh] * [int & exh] vlv.recess or Instl. Vlv.Height>which ever Ford supplies< * How about vlv.sprg. spec.s [Free Length , correct tension @ vlv.sprg.[int/exh] Closed Height & anything else might have missed ? If U can , it would HELP a Lot
THANK U
butch
Originally Posted by Bcarriveau View Post
This information listed is pulled from 2007 F2504x4 6L specs
Vehicle: Fluid Type Specifications
Automatic Transmission Fluid Type Specification
Ford Part Number - XT-6-QSP
Ford Specification - Mercon SP
Note: Ensure the correct automatic transmission fluid is used. Transmission fluid requirements are indicated on the dipstick handle. Check the container to verify the fluid being added is of the correct type.
BRAKE FLUID AND CLUTCH FLUID
Motorcraft High Performance DOT 3 Motor Vehicle Brake Fluid
Ford Part Number - PM-1
Ford Specification - ESA-M6C25-A or WSS-M2C62-A
Coolant
ENGINE COOLANT
Motorcraft Premium Gold Engine Coolant (yellow-colored)
Ford Part Number: VC-7-B
Ford Specification: WSS-M97B51-A1
FRONT AXLE LUBRICANT SPECIFICATIONS
Motorcraft SAE 80W-90 Premium Rear Axle Lubricant
Ford Part Number - XY-80W90-QL
Ford Specification - WSP-M2C197-A
REAR AXLE LUBRICANT SPECIFICATIONS
Ford 10.50 Inch Axle
Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Ford Part Number - XY-75W140_QL
Ford Specification - WSL-M2C192-A
DANA 80
Motorcraft SAE 75W-90 Premium Synthetic Transaxle Lubricant
Ford Part Number - XT-75W90-QGT
DANA S110/S130
Ford Part Number - XY-75W140-QL
NOTE: Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification EST-M2C118-A for complete refill of
limited slip Ford axles. Ford design rear axles contain a synthetic lubricant that does not require changing unless the axle has been submerged in water.
DANA 80
DANA S110/S130
NOTE: Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification EST-M2C118-A for complete refill of limited slip Ford axles. Ford design rear axles contain a synthetic lubricant that does not require changing unless the axle has been submerged in water.
Ford Part Number: PM-1
Ford Specification: ESA-M6C25-A or WSS-M6C62-A
Manual Transmission
Manual Transmission Fluid: - Motorcraft MERCON ATF
Ford Part Number: - XT-2-QDX
Ford Specifications: - MERCON
Power Steering
Power Steering Fluid: - Motorcraft MERCON ATF
Wheel Bearing
SPINDLE BEARING LUBRICANT
High Temperature 4X4 Front Axle and Wheel bearing Grease
Ford Part Number - XG-11 (FAD)
Ford Specification - ESTZ-19590-A / ESA-M1C198-A
Transfer Case
Transfer Case Fluid: - Motorcraft MERCON ATF
_________________________________________
Vehicle: Capacity Specifications
Coolant
Cooling System - 27.5 quarts (26.0L)
NOTE: Includes heater and 5.0 quarts (4.7L) in coolant recovery.
Front Axle Fluid Capacity Specification
Front Axle - 5.8 Pints ( 2.8 L. )
Rear Axle Fluid Capacity Specifications
10.50 inch Ring Gear - 6.9 Pints ( 3.3 L ) *
Dana 80
Conventional and Truetrac - 8.5 Pints ( 4.0 L ) *
Trac-Lok - 8.0 Pints ( 3.8 L ) *
Dana S110 and S130 - 14 Pints ( 6.6 L ) *
* NOTE: Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification EST-M2C118-A for complete refill of limited slip Ford axles. Ford design rear axles contain a synthetic lubricant that does not require changing unless the axle has been submerged in water.
Engine Oil
Engine Oil - 15.0 quarts (14.2L)
NOTE: Includes 1 quart (1.0L) in engine oil filter.
Fuel Tank Capacity
361 cm (142 in) or 396 cm (156 in) wheelbase- 115.5 liters (30.5 gallons)
348 cm (137 in), 401 cm (158 in) or 437 cm (172 in) wheelbase- 144 liters (38 gallons)
Narrow frame aft-of-axle tank standard equipment- 151 liters (40 gallons)
Narrow frame midship tank (optional)- 72 liters (19 gallons)
MANUAL TRANSMISSION FLUID
ZF 6-Speed Manual Transmission
Transmission w/o oil cooler - 5.81 quarts (5.5L)
Transmission oil cooler - 0.53 quarts (0.5L)
Automatic Transmission Fluid Capacity Specification
Mercon SP - 19.2 Quarts ( 18.0 L )
Transfer case
Transfer case fluid - 2.0 quarts (1.9L)
Engine Oil Pressure(low pressure)
Oil pressure - minimum - 82.7 kPa (12 psi) at 700 rpm, 165.5 kPa (24 psi) at 1,200 rpm and 310.3 kPa (45 psi) at 1,800 rpm with engine at operating temperature.
Fuel Pressure
6.0L diesel operating fuel line primary pump pressure- 310-379 kPa (45-55 psi)
Key on, engine running- 310-379 kPa (45-55 psi)
Key on, engine off- 0-379 kPa (0-55 psi)
Thermostat, Engine Cooling
Thermostat Opening Temperatures
Starts to open - 87-91C (189-196F)
Fully open - 104C (219F)
From user bismic
Coolant types
Coolant can be VC-7-A OR VC-7-B (B just has a "bittering agent").
Transmission temperature:
The panel gage will show the transmission temperature as fully warmed up at 50 *F. Between 100-220 *F the needle will remain in the same position on the gauge. At 230 *F it will move up slightly to the middle of the normal range. At 250 *F it will move to Yellow. The gage moves to red at 280 *F. This is supported on page 36 of the OBDII Theory and Operations manual. The tow/haul light will flash at 275 *F.
Engine Temperature Control:
Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor the sensor input and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF.
My understanding of fuel pressure:
Fuel pressure is regulated to 100 psig out of the HFCM.
Then a recirculation regulator opens at 60 psig to take the fuel back to the HFCM.
Oil Temp:
Oil temperature is usually 10-25 *F above coolant temp. Engine begins to defuel at 254 *F oil temp. Oil temperature should NEVER exceed the ECT by more than 25 *F.
___________________________________________
GLOW PLUG SYSTEM
Glow Plug Control Module
The 6.0L diesel engine uses a glow plug system that preheats air in the combustion chamber to improve cold engine starting.
The system consists of:
- glow plugs.
- glow plug control module.
- powertrain control module (PCM).
- engine oil temperature (EOT) sensor.
- barometric pressure sensor (BARO sensor).
The glow plug monitor system is part of the On-Board Diagnostics II (OBD II) System.
The glow plug system is electronically controlled by the powertrain control module. If the oil temperature is below 55(131F) the powertrain control
module will energize the glow plugs immediately after the key is placed in the ON position. Then, depending on the readings from the engine oil
temperature (EOT) sensor and the barometric pressure (BARO) sensor, the powertrain control module determines how long the glow plugs will be on.
Glow Plugs - PCM-Controlled
The glow plugs are located in the cylinder heads, under the glow plug wiring harness.
The glow plugs are self-regulating. If the engine oil temperature is above 55C (131F), the powertrain control module will bulb-check the
WAIT-TO-START lamp but not energize the glow plug relay.
The glow plug ON time varies from 0-120 seconds depending on battery voltage, engine oil temperature and barometric pressure.
The glow plug ON time is independent of the WAIT-TO-START lamp ON time.
The glow plug control monitor (GPCM) system is designed to find failed glow plugs or failed wiring in the glow plug system.
Engine
Displacement - 6L (365 cubic inch)
Bore - 95 mm(3.74in)
Stroke - 105mm(4.13in)
Firing order 1-2-7-3-4-5-6-8
Compression ratio - 18.0:1
Cylinder head and valve train
Cylinder head gasket 0.05mm(0.002in) per 51
surface flatness mm(2in)
0.10mm(0.004in) per
Total surface area
cylinder head thickness
Minimum - 95mm(3.74in)
Valve face angle - Exhaust 37.5 degrees
Intake 30 degrees
Valve seat width - Exhaust 1.80-2.56mm(0.071-0.101in)
Intake 1.48-2.24mm(0.058-0.088in)
Vlave seat runout - 0.0035mm(0.0014in)
Camshaft
Gear backlash - 0.179-0.315mm(0.007-0.012in)
Lobe lift - Intake 3.744mm(0.2261in)
Exhaust 5.832mm(0.2296in)
Allowable lobe lift loss - 0.51mm(0.02in)
Cylinder block
Cylinder bore diameter - 94.999-95.001mm(3.7401-3.7402in)
cylinder bore maximum out of round - 0.05mm(0.002in)
Head gasket surface flatness
0.10mm(0.004in) across the total area
0.05mm(0.002in) across and 150mm(5.9in)x150mm(5.9in) area
0.025mm(0.001in) across any 25mm(0.98in)x25mm(0.98in) area
gas/diesel eng rebldr is offline
