06 Fastener Tightening Specifications - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ripmf666, this thread has received 0 replies and been viewed 1203 times.
post #1 of 1 (permalink) Old 12-27-2008, 03:49 AM Thread Starter
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Service Information
2006 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Engine | Engine Mechanical - 6.6L | Specifications | Document ID: 1651785
Application
Specification
Metric
English
A/C Compressor Bolt
50 Nm
37 lb ft
Air Cleaner Outlet Duct Clamp
8 Nm
71 lb in
Air Conditioning Compressor/Power Steering Pump Bracket Bolt
46 Nm
34 lb ft
Air Inlet Tube Nut
25 Nm
18 lb ft
Battery Cable Bracket Bolt
12 Nm
106 lb in
Battery Cable Bracket Nut
8 Nm
71 lb in
Bypass Pipe Bolt
25 Nm
18 lb ft
Camshaft Gear Bolt
234 Nm
173 lb ft
Camshaft Position Sensor Bolt
10 Nm
89 lb in
Camshaft Position Sensor Exciter Ring Bolt
9 Nm
80 lb in
Camshaft Thrust Plate Bolt
22 Nm
16 lb ft
Charged Air Cooler Bolt
21 Nm
15 lb ft
Charged Air Cooler Clamp
8 Nm
71 lb in
Connecting Rod Cap Bolt - Angular Tightening Method
1st Step 64 Nm
1st Step 47 lb ft
2nd Step 30 degrees
2nd Step 30 degrees
3rd Step 30 degrees
3rd Step 30 degrees
Coolant Pipe Bolt and Nut
25 Nm
18 lb ft
Coolant Tube to Water Pump Nut
25 Nm
18 lb ft
Cooling Fan Pulley
41 Nm
30 lb ft
Crankshaft Balancer Bolt
1st Step 100 Nm
1st Step 74 lb ft
2nd Step 105 degrees
Crankshaft Bearing Cap Bolt
1st Step 98 Nm
1st Step 72 lb ft
2nd Step 132 Nm
2nd Step 97 lb ft
3rd Step 30 degrees
3rd Step 30 degrees
Crankshaft Bearing Cap Bolt - Angular Tightening Method
1st Step 100 Nm
1st Step 74 lb ft
2nd Step 90 degrees
2nd Step 90 degrees
Crankshaft Bearing Cap Side Bolt
70 Nm
52 lb ft
Crankshaft Position Sensor Bolt
10 Nm
89 lb in
Crankshaft Position Sensor Spacer Bolt
10 Nm
89 lb in
Crossmember Bolt
100 Nm
74 lb ft
Cylinder Head M12 Bolt - Angular Tightening Method
1st Step 50 Nm
1st Step 37 lb ft
2nd Step 80 Nm
2nd Step 59 lb ft
3rd Step 60 degrees
4th Step 60 degrees
Cylinder Head M8 Bolt
25 Nm
18 lb ft
Drive Belt Tensioner Pulley Bolt
50 Nm
37 lb ft
EGR to EGR Cooler Bolt
25 Nm
18 lb ft
EGR Bracket
25 Nm
18 lb ft
EGR Bracket Bolt
25 Nm
18 lb ft
EGR Bracket to Cooler Bolt
25 Nm
18 lb ft
Electrical Harness Bracket Bolt
10 Nm
89 lb in
Engine Block Coolant Plug
18 Nm
13 lb ft
Engine Block Ground Bolt
34 Nm
25 lb ft
Engine Mount Through Bolt to Frame
75 Nm
55 lb ft
Engine Mount to Block Bolts
58 Nm
43 lb ft
Engine Mount to Frame Bolt
65 Nm
48 lb ft
Engine Shield Bolt
20 Nm
15 lb ft
Exhaust Heat Shield Nut
10 Nm
89 lb in
Exhaust Manifold Bolt/Nut
57 Nm
42 lb ft
Exhaust Manifold Heat Shield Bolts
10 Nm
89 lb in
Exhaust Outlet Clamp
15 Nm
11 lb ft
Exhaust Outlet Heat Shield Bolts
10 Nm
89 lb in
Exhaust Pipe Bracket Nut
53 Nm
39 lb ft
Exhaust Pipe Clamp
53 Nm
39 lb ft
Exhaust Pipe Heat Shield Bolts
10 Nm
89 lb in
Exhaust Pipe to EGR Cooler Nuts
26 Nm
19 lb ft
Fan Pulley Bracket Bolt
50 Nm
37 lb ft
Flywheel Bolt - Angular Tightening Method
1st Step 79 Nm
1st Step 58 lb ft
2nd Step 60 degrees
2nd Step 60 degrees
3rd Step 60 degrees
3rd Step 60 degrees
Flywheel Housing Bolt
80 Nm
60 lb ft
Flywheel Housing to Upper Oil Pan Bolt
50 Nm
37 lb ft
Front Engine Cover Bolt
25 Nm
18 lb ft
Fuel Filter Bracket Bolt
30 Nm
22 lb ft
Fuel Injection Pipe Nut
41 Nm
30 lb ft
Fuel Injector Bracket Bolt
30 Nm
22 lb ft
Fuel Inlet Pipe Bracket Bolt
21 Nm
15 lb ft
Fuel Injection Pump Assembly to Cylinder Block Bolt
25 Nm
18 lb ft
Fuel Injection Pump to Bracket Bolt
28 Nm
20 lb ft
Fuel Injection Pump Drive Gear Nut
70 Nm
52 lb ft
Fuel Line Bracket Nut
21 Nm
15 lb ft
Fuel Temperature Sensor
22 Nm
16 lb ft
Fuel Pipes Bracket Bolt
25 Nm
18 lb ft
Fuel Pressure Relief Valve
100 Nm
74 lb ft
Fuel Rail Assembly Bolt
25 Nm
18 lb ft
Fuel Rail Balance Pipe Bolt
21 Nm
15 lb ft
Generator Bracket Bolt and Nut
50 Nm
37 lb ft
Generator Positive Cable Nut
9 Nm
80 lb in
Glow Plug
18 Nm
13 lb ft
Glow Plug Controller Bolt
10 Nm
89 lb in
Glow Plug Harness Bracket Bolt
10 Nm
89 lb in
Glow Plug Nut
2 Nm
18 lb in
Glow Plug Power Feed Nut
15 Nm
11 lb ft
Glow Plug Relay Assembly Bolt
10 Nm
89 lb in
Heater Outlet Pipe Bolt
25 Nm
18 lb ft
Heater Pipe Bolt
25 Nm
18 lb ft
Hood Hinge Bolt
25 Nm
18 lb ft
Idle Pulley Bolt
50 Nm
37 lb ft
23 Nm
16 lb ft
Intake Manifold Bolts/Nuts
25 Nm
18 lb ft
Oil Cooler Adapter Bolts
25 Nm
18 lb ft
Oil Cooler Adapter Nuts
25 Nm
18 lb ft
Oil Cooler Assembly Bolts
25 Nm
18 lb ft
Oil Cooler Adapter Stud
10 Nm
89 lb in
Oil Drain Plug
84 Nm
62 lb ft
Oil Fill Tube Bolt
25 Nm
18 lb ft
Oil Filter
24 Nm
18 lb ft
Oil Gallery Plugs
53 Nm
39 lb ft
Oil Level Indicator Tube Bolt
21 Nm
15 lb ft
Oil Level Sensor Bolt
10 Nm
89 lb in
Oil Level Sensor Harness Bolt
40 Nm
29 lb ft
Oil Pan Bolts/Nuts - Lower
10 Nm
89 lb in
Oil Pan Bolt - Upper
20 Nm
15 lb ft
Oil Pan Skid Plate Bolt
20 Nm
15 lb ft
Oil Pressure Sensor Unit
49 Nm
36 lb ft
Oil Pressure Relief Valve
39 Nm
29 lb ft
Oil Pump Bolt
21 Nm
15 lb ft
Oil Pump Driven Gear Nut
100 Nm
74 lb ft
Oil Pump Gear Cover Bolt
21 Nm
15 lb ft
Oil Pump Pipe and Screen Assembly Bolts and Nuts
25 Nm
18 lb ft
Piston Cooling Nozzle Eye Bolt
21 Nm
15 lb ft
Positive Cable Junction Block Bracket to Power Steering Pump Bolt
9 Nm
80 lb in
Positive Crankcase Ventilation Cover Screws
4 Nm
35 lb in
Positive Crankcase Ventilation Oil Separator Bracket Nut
25 Nm
18 lb ft
50 Nm
37 lb ft
50 Nm
37 lb ft
Rocker Arm Shaft Bracket Bolt
41 Nm
30 lb ft
Starter Motor Bolt
78 Nm
58 lb ft
Transmission Fill Tube Nut
18 Nm
13 lb ft
Thermostat Housing Bolts/Nuts
25 Nm
18 lb ft
Thermostat Cover Bolt
25 Nm
18 lb ft
Torque Converter Bolt
60 Nm
44 lb ft
Transmission Oil Cooler Clip Nut
9 Nm
80 lb in
Turbocharger Bolt
108 Nm
80 lb ft
Turbocharger Coolant Outlet Pipe Bracket Nut
10 Nm
89 lb in
Turbocharger Heat Shield Bolts
10 Nm
89 lb in
Turbocharger Oil Return Pipe Stud
10 Nm
89 lb in
Turbocharger Oil Supply Hose Eye Bolt
26 Nm
19 lb ft
Turbocharger Oil Return Pipe Bolts/Nuts
25 Nm
18 lb ft
Upper Oil Pan to Flywheel Housing Bolts
20 Nm
15 lb ft
Valve Adjusting Nut
22 Nm
16 lb ft
Valve Lifter Holdown Bracket Bolt
11 Nm
97 lb in
Valve Rocker Arm Cover Bolt - Lower
10 Nm
89 lb in
Valve Rocker Arm Cover Bolt - Upper
8 Nm (Two Times)
71 lb in (Two Times)
Water Outlet Bolts
25 Nm
18 lb ft
Water Pump Bolt
25 Nm
18 lb ft
Water Pump Inlet Pipe Bolts
25 Nm
18 lb ft
2008 General Motors Corporation. All rights reserved.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
Closed Thread
LB7 Engine Mechanical Specifications ripmf666 GM Spec Info 0 12-27-2008 01:21 AM
LLY Engine Mechanical Specifications ripmf666 GM Spec Info 0 12-27-2008 01:19 AM
05 LLY Engine Mechanical Specifications ripmf666 GM Spec Info 0 12-27-2008 01:17 AM
LBZ Engine Mechanical Specifications ripmf666 GM Spec Info 0 12-27-2008 01:14 AM
LMM Engine Mechanical Specifications ripmf666 GM Spec Info 0 12-27-2008 01:10 AM
HTML code is On
