01-08 Cylinder Head Replacement - Right Side - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ripmf666, this thread has received 0 replies and been viewed 1913 times.
post #1 of 1 (permalink) Old 12-27-2008, 04:22 AM Thread Starter
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Service Information
Document ID: 1794321
Tools Required
J 45059 Angle Meter
Removal Procedure
  1. Remove the thermostat housing crossover. Refer to Thermostat Housing Crossover Replacement .
  2. Remove the intake manifold. Refer to Intake Manifold Replacement - Right Side .
  3. Remove the exhaust manifold. Refer to Exhaust Manifold Replacement - Right Side .
  4. Remove the valve rocker arm shaft, pushrods, and valve bridges. Refer to Valve Rocker Arm, Shaft, and Push Rod Replacement .
  5. Remove the glow plugs. Refer to Glow Plug Replacement - Bank 1 .
  6. Remove the cylinder head bolts in the sequence shown.
  7. Discard the large M12 bolts.
  8. Remove the cylinder head.
  9. Remove and discard the cylinder head gasket.
  10. Clean the sealing surface of the engine block and the cylinder head. Notice: Clean all dirt, debris, and coolant from the engine block cylinder head bolt holes. Failure to remove all foreign material may result in damaged threads, improperly tightened fasteners or damage to components.
  11. Clean the cylinder head bolt holes in the engine block.
  12. For service to the cylinder head refer to the following:
Installation Procedure
  1. Notice: The left and right cylinder head gaskets are not interchangeable. Improper placement of the cylinder head gasket will block coolant and oil passages. Blocked coolant and oil passages will cause severe engine damage.
  2. Install the cylinder head gasket of the correct grade. Refer to Cylinder Head Gasket Selection Specifications .
  3. Install the cylinder head.
    Notice: This component uses bolts with a preapplied molybdenum disulfide coating for thread lubrication. Do not remove the coating or use any additional lubricant. Improperly lubricated threads will adversely affect the bolt torque and clamp load. Improper bolt torque and clamp load can lead to engine damage.
  4. Install the NEW M12 cylinder head bolts.
  5. Reuse the M8 cylinder head bolts. Notice: Refer to Fastener Notice in the Preface section.
  6. Tighten the cylinder head bolts in the following steps using the sequence shown:
    Tighten
    1. Tighten the M12 bolts a first pass to 50 Nm (37 lb ft).
    2. Tighten the M12 bolts a second pass to 80 Nm (59 lb ft)
    3. Tighten the M12 bolts a third pass to 60 degrees, using J 45059 .
    4. Tighten the M12 bolts a final pass to 60 degrees, using J 45059 .
    5. Tighten the M8 bolts to 25 Nm (18 lb ft).
  7. Install the valve rocker arm shaft, pushrods, and valve bridges. Refer to Valve Rocker Arm, Shaft, and Push Rod Replacement .
  8. Install the glow plugs. Refer to Glow Plug Replacement - Bank 1 .
  9. Install the right exhaust manifold. Refer to Exhaust Manifold Replacement - Right Side .
  10. Install the right intake manifold. Refer to Intake Manifold Replacement - Right Side .
  11. Install the thermostat housing crossover. Refer to Thermostat Housing Crossover Replacement .
  12. Road test the vehicle for normal operation.
  13. Inspect for coolant, oil, or exhaust leaks.
2008 General Motors Corporation. All rights reserved.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
Closed Thread
WTB: ARP 24V head studs JDH Whats Been Sold 3 12-31-2008 01:34 PM
head studs 700rmk 2003-2007 6.0L Power Stroke 31 12-30-2008 10:42 PM
01-08 Cylinder Head Replacement - Left Side ripmf666 GM Spec Info 0 12-27-2008 04:21 AM
01-08 Valve Rocker Arm, Shaft, and Push Rod Replacement ripmf666 GM Spec Info 0 12-27-2008 04:18 AM
01-08 Cylinder Head Gasket Selection Specifications ripmf666 GM Spec Info 0 12-27-2008 03:52 AM
HTML code is On
