01-08 Exhaust Manifold Replacement - Right Side (6.6L Engine) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ripmf666, this thread has received 0 replies and been viewed 1631 times.
post #1 of 1 (permalink) Old 12-27-2008, 04:24 AM Thread Starter
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Service Information
Document ID: 1382462
Exhaust Manifold Replacement - Right Side (6.6L (LLY) Engine)
Removal Procedure
  1. Raise the vehicle enough in order to work through the wheelhouse opening. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Front End.
  3. Remove the exhaust manifold heat shield bolts.
  4. Remove the exhaust manifold heat shield.
  5. Remove the right exhaust pipe to the exhaust manifold bolts (3, 4, and 5).
  6. Remove the exhaust manifold bolts and nuts in the proper sequence.
  7. Remove the exhaust manifold.
  8. Remove the bolt for the oil level indicator tube bracket in order to remove the exhaust manifold gasket.
  9. Remove and discard the exhaust manifold gasket.
  10. Clean and inspect the exhaust manifold. Refer to Exhaust Manifold Cleaning and Inspection in Engine Mechanical - 6.6L (LLY).
Installation Procedure
  1. Notice: Refer to Fastener Notice in the Preface section.
  2. Install the exhaust manifold gasket to the cylinder head.
  3. Install the bolt for the oil level indicator tube bracket. Tighten
    Tighten the bolt to 21 Nm (15 lb ft).
  4. Install the exhaust manifold.
  5. Install the exhaust manifold bolts/nuts.
  6. Using the sequence shown, properly tighten the exhaust manifold bolts. Tighten
    Tighten the bolt/nuts to 38 Nm (28 lb ft).
  7. Install the exhaust manifold heat shield.
  8. Install the exhaust manifold heat shield bolts. Tighten
    Tighten the bolts to 8 Nm (71 lb in).
  9. Install the exhaust pipe gasket. Align the tab on the gasket to face outward.
  10. Install the exhaust pipe bolts (3, 4, and 5). Tighten
    Tighten the bolts to 53 Nm (39 lb ft).
  11. Install the wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Front End.
  12. Lower the vehicle.
2008 General Motors Corporation. All rights reserved.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
Closed Thread
WTB Stock CR exh manifold Macktruckdriver Whats Been Sold 4 02-01-2009 07:39 PM
08 twins and manifold! caryt Whats Been Sold 1 01-25-2009 03:09 PM
01-08 Cylinder Head Replacement - Right Side ripmf666 GM Spec Info 0 12-27-2008 04:22 AM
01-08 Cylinder Head Replacement - Left Side ripmf666 GM Spec Info 0 12-27-2008 04:21 AM
01-08 Valve Rocker Arm, Shaft, and Push Rod Replacement ripmf666 GM Spec Info 0 12-27-2008 04:18 AM
HTML code is On
