Diesel Truck Forum - TheDieselGarage.com - View Single Post - Debating on trucks, need report
View Single Post
post #2 of (permalink) Old 08-31-2010, 07:32 PM
00f3fiddy
Standard Claims List For Model Year 2005
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 6 1G03 030507 3C3Z 8620 DB E20 01 14008
AWS Claim Key: 1367591 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2005 Doc #:096764A
Cust Comments: SERPENTINE DRIVE BELT BROKE WHILE DRIVING
Tech Comments: 14008 FOUND BELT BROKEN A SEAM INSPECT PULLEYS ALL OK BELT SEPERATED AT SEAM REPLACE BELT
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 13 * * * * * * * 27143
AWS Claim Key: 3572013 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:102750A
Cust Comments: RECALL 05 E 15
Tech Comments: 27143 REPLACED THE EXHAUST BACKPRESSURE SENSOR AND REPROGRAMMED THE PCM. COMPLETED.
AWS Claim Key: 3572014 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:102750B
Cust Comments: RECALL 05 B 32
Tech Comments: 27143 W95 INSTALLED STICKER TO THE DEGAS BOTTLE.
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 14 1H02 120307 6C3Z 2A451 A C05 42 28024
AWS Claim Key: 4023174 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06494 - * Name: NEW SOUTH FORD Ph: 601-6936821 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2006 Doc #:13304902
Cust Comments: HEAT AND A C DO NOT SWITCH AT VENTS
Tech Comments: CHECKED CONTROL HEAD THIS WAS GOOD, FOUND VAC PUMP BAD R &R VAC PUMP
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 14 2E03 03XXXX 4C3Z 12B599 AARM D42 42 28024
AWS Claim Key: 4023175 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 06494 - * Name: NEW SOUTH FORD Ph: 601-6936821 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2006 Doc #:13304901
Cust Comments: RUNS ROUGH NO POWER
Tech Comments: RAN WDS CODE P0264 CHECKED ELEC FROM INJ TO FICM FOUND FICM BAD, R &R FICM. AND REPROGRAMED MODULE. TEST DROVE ENGINE HAD SMALL MISS DID BALLOON TEST INJ #7 AND #6 BAD. REPLACED #6 & #7 INJ RETEST SYSTEM PASSED ALSO REPLACED FUEL FILTER CUP SPRING WAS CRACKED
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 26 2E03 030402 4C3Z 9E527 AA D41 42 48426
AWS Claim Key: 7324828 Trx Code: S07 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 05861 - * Name: STARKVILLE FORD-LINCOLN-MERCURY, INC. Ph: 662-3231900 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2007 Doc #:00127001
Cust Comments: CHECK ENGINE MISFIRING AND SURGING
Tech Comments: PERFORMANCE DIAG PER GUIDE NO CODES CYLINDER BALANCE TEST MISS ON CYLINDERS TWO AND FIVE RELATIVE COMPRESSION TEST OK R AND I BOTH ROCKER COVERS AND REPLACE NUMBER TWO AND FIVE FUEL INJECTORS AND ON VALVE COVER GASKET AND RECHECK
1FTSX21P85EB35877 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 09-NOV-2004 02-FEB-2005 124016 USA 27 3A11 070100 * 7000 * A99 82 45166
AWS Claim Key: 7507275 Trx Code: P05 Labor Hrs: 0
Dlr Cd-Sub Cd: 05861 - * Name: STARKVILLE FORD-LINCOLN-MERCURY, INC. Ph: 662-3231900 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2007 Doc #:01180501
Cust Comments: CUSTOMER REQUESTING REFUND ON EMERGENCY REPAIRS
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
elozan1 (08-31-2010)
