Diesel Truck Forum - TheDieselGarage.com - View Single Post - Oasis request. Thanks in Advance!
View Single Post
post #2 of (permalink) Old 09-27-2010, 01:42 PM
00f3fiddy
Standard Claims List For Model Year 2005
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 1 2E03 03XXXX 4C3Z 12B599 AARM D41 42 1989
AWS Claim Key: 264972 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2005 Doc #:111135A
Cust Comments: C S ENGINE BUCKS WHILE TOWING AT 65 MPH IN OVERDRIVE CK AND ADVISE
Tech Comments: UNABLT TO VERIFY CONCERN.PERFORMED TURBOCHARGER BOOST TEST (PASSRD) AND FUEL INJECTOR CONTROL TEST. KOEO SELF TEST PASSED.PERFORMED KEEP ALIVE MEMORY RESET PROCEDURE, UPDATED FUEL INJECTOR CONTROL MODULE, RELEASED VEHICLE.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 1F06 030304 F6DZ 8100 A L87 42 7919
AWS Claim Key: 457712 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:02714352
Cust Comments: CUSTOMER STATES VEHICLE IS LEAKING COOLANT CHECK AND ADVISE
Tech Comments: DIAG COOLANT LEAK.PRESSURE TESTED COOLANT SYSTEM.NO LEAKS.PRESSURE TESTED COOLANT CAP.COOLANT CAP POP OFF AT 13 PSI.OUT OF SPECS.SPECS ARE 16 PSI.R&R RAD CAP.RETESTED OK.CONDITION CODE 42
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 3A10 070100 5C3Z 7005 AA P59 42 7919
AWS Claim Key: 457713 Trx Code: 2 Labor Hrs: 13.6
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:02714353
Cust Comments: CUSTOMER STATES TRANSMISSION SLIPS IN GEAR CHECK AND ADVISE
Tech Comments: COOLER LINES,REPLACE IN LINE FILTER, INTSALL TRANS. AFTER REPAIR AND TRANS. WORKS OK. LABOR 308..7000A 4.7 7000A11 0.2 7000A43 0.3 7095C 1.1 LABOR 054..7000AXQ 0.2 7000AZJ 0.3 7000A2 4.4 7000A2ZG 0.1 7000A3 0.2 7000A4 0.2 7000A13 0.6 7000F 1.3 PARTS#7005 7D234 7D164 7G178 7D483 7D406 7D402 7J1
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 7K11 130101 5C3Z 10849 RA A35 42 7919
AWS Claim Key: 457714 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:02714356
Cust Comments: CUSTOMER STATES ENGINE IS OVERHEATING WHILE DRIVING AT HIGH RPMS INSTALLSPO FROM RO 26617 TECH 138
Tech Comments: DIAG GAUGE IS SHOWING OVER HEATING.ROAD TESTED TEMP GAUGE GOES TO HOT VIEW ECT PID 209 F.RAN EEC TEST ON CONT CODE P0217.LOOK FOR ANY TSB OR SSM.FOUND TSB 05 01 02.PERFORM TSB.R&R INSTRUMENT CLUSTER.CLEAR CODE.ROAD TESTED RETESTED PASS.CONDITION CODE 42
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 1F03 030304 * 8287 * L87 24 9547
AWS Claim Key: 721642 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:113201B
Cust Comments: C S SMELLS COOLANT PUDDLE UNDER RADIATOR
Tech Comments: FOUND LOWER HOSE CLAMP LEAKING, RE TORQUED OK.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 2E06 030008 4C3Z 9E527 AA D50 42 9547
AWS Claim Key: 721641 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:113201A
Cust Comments: C S ENGINE SKIPPING AT ALL TIMES
Tech Comments: REPLACED NO. 5 CYLINDER INJECTOR, NFP.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 3 3A15 0701XX 4C3Z 7G383 AA P67 42 9547
AWS Claim Key: 721643 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:113201C
Cust Comments: DELAYED SHIFT FORWARD & REVERSE
Tech Comments: REPLACED PRESSURE CONTROL SOLENOID AND IN LINE FILTER, CHECKS OK.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 9 1F03 030304 B7A 8287 A L85 01 15214
AWS Claim Key: 1932342 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:119160D
Cust Comments: C S STATES LOOSING COOLANT HAVE TO ADD
Tech Comments: FOUND THE LOWER RADIATOR HOSE LEAKING AT THE PUMP CLAMP REPLACED CLAMP AND ANTIFREEZE
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 9 7K11 130101 * 10838 * A85 42 15450
AWS Claim Key: 1986167 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2005 Doc #:119266B
Cust Comments: OUTSIDE RENTAL PROVIDED.
Tech Comments: ENTERPRISE RENTAL CAR PROVIDED.
AWS Claim Key: 1971697 Trx Code: E83 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2005 Doc #:119266A
Cust Comments: C S HIT SOMETHING IN FRT END, NOW ENGINE SURING NO TACH, NO SPEEDO, ELECT WINDOWS INOP AND NO INTERIOR LIGHTS
Tech Comments: CHECKED FUSES AND WIRING TRACED COCNERN TO INSTRUTMENT CLUSTER PANEL MICRO PROCESSOR ORDERED CLUSTER ON BACKORDER CALL ZONE REP FOR ASSISTANCE APPROX 1 MONTH LATER REPLACEMENT CLUSTER ARRIVED INSTALLED I P CLUSTER AND ROADTEST OPERATING AS DESIGNED AT THIS TIME WHEM COMPARED TO A LIKE VEHICLE
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 10 1H03 030008 4C3Z 9F452 A D13 42 15574
AWS Claim Key: 1931128 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 07616 - * Name: METRO FORD Ph: 508-8221000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2005 Doc #:082931C
Cust Comments: WHEN AT HIGH SPEEDS THE VEHICLE BUCKS TURBO NOISY AND THE BOOST DROPS 2 3 PSI
Tech Comments: 15574 TEST TURBO WASRE GATE AND EGT NEEDS NEW TURBO WASTE GATE KICKS OPEN AT ODD TIMES LOW LOAD CAUSES BOOST DROP AND NOISE IN AIR BOX
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 10 1F01 030301 * 8005 * L87 82 15574
AWS Claim Key: 1931127 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07616 - * Name: METRO FORD Ph: 508-8221000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2005 Doc #:082931B
Cust Comments: CUST STATES HE LOOSES ANTI FREEZE MAY BEEGR VALVE
Tech Comments: 15574 TEST COOLANT IA ALL WATER AND LOW ADD ONE GAL WATER TEST DRIVE PRESS TEST FOR LEAKS SUSPECT HEAD GASKETS TALK WITH CUST DOES NOT WANT WORK DONE NEEDS TRUCK BACK
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 10 1F03 030304 * 8287 * L87 01 16121
AWS Claim Key: 2000824 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09991 - * Name: LUCINI FORD SALES, INC. Ph: 508-5835500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:013560A
Cust Comments: CUST NOTES VEH IS LEAKING OR USING COOLANT VEH ALSO RUNS HOT UNDER LOAD
Tech Comments: REPLACE BROKEN HOSE CLAMP
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 11 5W01 06XXXX 2L1Z 2B674 AA H20 42 18521
AWS Claim Key: 2576028 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2005 Doc #:121734D
Cust Comments: C S TRAILER BRAKE CONTROL INOP
Tech Comments: REPLACED BRAKE TRANSDUCER.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 11 2H01 030008 3C3Z 9T516 BA D42 42 18521
AWS Claim Key: 2576029 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2005 Doc #:121734A
Cust Comments: C S STATES ON HIGHWAY LOOSING POWER AND TRUCK BUCKING
Tech Comments: FOUND VGT OPERATION ERRATIC. REPLACED VGT AND OIL TUBE PER TSB 05 21 5.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 11 1C03 030008 5C3Z 6079 B L87 D8 18521
AWS Claim Key: 2576030 Trx Code: E84 Labor Hrs: 31.9
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2005 Doc #:121734B
Cust Comments: C S STATES LOOSING COOLANT KEEPS ADDING COOLANT BY THE GALLON
Tech Comments: FOUND CYLS 3,4,5,AND 6 LEAKING COMPRESSION INTO COOLING SYSTEM. CHECKED SURFACES WITH STRAIGHT EDGE,OK. FOUND CYL. HEADS DAMAGED. FOMOCO SAID TO REPLACE CYL. HEADS. REASSEMBLED WITH NEW HEADS, ROAD TESTED OK.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 14 2H01 030008 5C3Z 6K682 CA D42 42 22456
AWS Claim Key: 3490876 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:124945A
Cust Comments: CUSTOMER STATES ENGINE BUCKS WHILE DRIVING UP A HILL WITH A LOAD ON IT PULLING A TRAILER CHECK AND ADVISE
Tech Comments: FOUND TURBO LOSING BOOST, TESTED VGT, REPLACED TURBO.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 14 * * * * * * * 22456
AWS Claim Key: 3490879 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:124945D
Cust Comments: ALL 2005 MODEL YEAR VEHICLES EQUIPPED WITH 6.0L DIESEL ENGINES DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: COMPLETED RECALL.
AWS Claim Key: 3490877 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:124945B
Cust Comments: CERTAIN 2004 2005 VEHICLES EQUIPPED WITH 6.0L DIESEL ENGINES EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTROL MODULES RECALIBRATION
AWS Claim Key: 3490878 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:124945C
Cust Comments: ONE TIME CUSTOMER ASSURANCE TEST DRIVE
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 16 7H05 12XXXX 6C3Z 19980 AA C20 42 35443
AWS Claim Key: 4182536 Trx Code: E83 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:126812B
Cust Comments: CS CAB TEMP SENSOR GOES EITHER HOT OR COLD NO MEDIUM WHEN OUTSIDE TEMP IS LESS THAN 10 DEG OFF INSIDE TEMP
Tech Comments: PERFORMED EATC TEST AFTER TESTING THE TEMP SENSOR FOUND THE CONTROL UNIT OUT OF SYNC WITH SENSOR ORDERED NEW CONTROLLER INSTALLED PART NFP
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 21 1H03 030008 5C3Z 9F452 AA D42 42 45987
AWS Claim Key: 5626438 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:131226A
Cust Comments: CS VEHICLE IS SLUGGISH
Tech Comments: IDS RET CLEAR PASS KOEO INJ SELF TEST PASS KOEO SELF PASS KOER SELF P0299 P1408 P2263 R AND R THE EGR VALVE FOUND IT FULL OF SOOT AND STUCK OPEN REPLACED VALVE CLEANED MANIFOLD CLEARED CODES ROADTEST AND RETEST CLEAR OK DTCS
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 21 2E06 030402 4C3Z 9E527 AA D42 42 50805
AWS Claim Key: 5991240 Trx Code: S07 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2006 Doc #:131498A
Cust Comments: CUSTOMER STATES ENGINE SMOKES ON ACCELERATION AND CHECK ENGINE LIGHT IS ON CHECK AND ADVISE
Tech Comments: PERFORMED DIAGNOSTIC TESTS, PERFORMED INJECTOR BALANCE TEST, FOUND ALL INJECTORS DROP 25 TO 30 PERCENT RANDOMLY CALLED HOTLINE, PERFORM BUZZ TESTCYLINDER ORDER POWER BALANCE, STEPS 8 9 13 14 FOUND ALL INJECTORS AT 20 PERCENT NEEDS ALL 8 INJECTORS REPLACED. REPLACE ALL 8 AND REASSEMBLE AND ROADTEST CLEAR CODES AND RETEST OK NFP AT THIS TIME RELEASED VEHICLE.
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 23 7G01 120303 * 18505 * E23 42 54007
AWS Claim Key: 6414546 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061C
Cust Comments: CHECK BOTH BATTERIES AND THE CHERGING SYSTEM
Tech Comments: TESTED CHARGING SYSTEM OK TESTED BATTERIES LEFT OK RIGHT BAD ORGINAL BATTERIES, TECH SUGGESTS 2 NEW BATTERIES. CUSTOMER ADVISED. RENTAL PROVIDED FOR 18 DAYS
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 23 1A03 030008 5C3Z 6007 ZA E23 42 54007
AWS Claim Key: 6399997 Trx Code: E72 Labor Hrs: 18.6
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061A
Cust Comments: C S SYSTEM IS LOSING COOLANT
Tech Comments: FOUND EXCESSIVE WHITE AND BLUE SMOKE COMING OUT EXHAUST SYSTEM PERFORMED ENGINE DIAGNOSIS FOUND INTERNAL ENGINE DAMAGE FROM COOLANT INSIDE ENGINEWFOLLOWED PRIOR APPROVAL PROCEDURE, FIELD SERVICE ENGINEER INVOLVEMENT REQUIRED EXTENSIVE INTERNAL ENGINE DAMAGE CYLINDER HEADS WARPPED APPORVAL GIVEN FOR REPLACEMENT ENGINE FQR 6006 LONG BLOCK ENGINE NOT AVAILABLE COMPLETE ENGINE AVAILABLE REPLACED
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 23 6Y05 000001 * ESPRCR * A99 82 54007
AWS Claim Key: 6399995 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061F
Cust Comments: ESP RENTAL COUPON
Tech Comments: ESP RENTAL COUPON
AWS Claim Key: 6399996 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061G
AWS Claim Key: 6399994 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061E
AWS Claim Key: 6399993 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061D
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 23 2G01 031401 5U7Z 12A650 CVC D42 42 54007
AWS Claim Key: 6386805 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:133061B
Cust Comments: C S ENGINE IS RUNNING ROUGH
Tech Comments: FOLLOWED SYSTEM PERFORMANCE DIAGNOSIS FOUND EGR VALVE NOT BEING CONTROLLED BY PCM FOLLOWED PCM DIAGNOSIS TESTS, FOUND PCM SHORTED INTERNALLY. REPLACE PCM AND DOWNLOAD ALL INFORMATION FROM OLD PCM TO NEW PCM. ROADTEST AND RETEST OK NFP
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 26 2H02 030008 * 6F089 * D42 42 61011
AWS Claim Key: 7069597 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:135603A
Cust Comments: CUSTOMER STATES VEHICLE BUCKS WHILE DRIVING, WHEN PULLING A LOAD AND GOING UP A HILL CHECK AND ADVISE
Tech Comments: VERIFIED CONCERN, FOUND UNDER A LOAD THE TURBOCHARGER IS LOOSING BOOST THROUGHT THE AIR CLEANER P0299 TESTED VGT SOLENOID OK EGR OK FOUND THE UNISON RING AND FINS STICKING R AND R TURBOCHARGER INSTALLED VGT ROADTEST OK NFP
1FTWW31P65EA83322 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 29-SEP-2004 09-DEC-2004 111648 USA 40 1H03 030804 4C3Z 9P456 AF E23 42 95578
AWS Claim Key: 9537220 Trx Code: S07 Labor Hrs: 24.8
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2008 Doc #:146859A
Cust Comments: CS LOOSING COOLANT?? STEAMING OUT EXHAUST COOLANT LEVEL IS FINE
Tech Comments: FOUND THE EGR COOLER LEAKING. ALSO FOUND OIL LEAKING FROM THE CRANKCASE BED PLATE, HEADGASKET LOWER CORNER HEAD BOLTS RIGHT SIDE, LEFT AND RIGHT ROCKER CRADLE GASKETS AND THE CMP SESNOR O RINGS. R AND R ENGINE, RESEALED ENTIRE ENGINE, LOF, COOLANT. ROADTESTED RETESTED CHECKED WORK NFP.
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
sritter (09-27-2010)
