Oasis Request 2003 F350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by midnight2004, this thread has received 1 replies and been viewed 665 times.
post #1 of 2 (permalink) Old 07-22-2010, 09:05 AM Thread Starter
Just about Broke
midnight2004's Avatar
2003 F350 6.0l Diesel 4x4
1FTSX31P53ED63127
Thanks!
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
AEM Brute Force HD Intake, GT4088 VGT Turbo, Spearco Intercooler, Custom EGR Cooler Delete,
H11 Head Studs, Fass 150/180, Custom Fuel lines, Custom Coolant Filter, Single 6" Stack, 2.5" Lift. 35x13.5 on 20's
midnight2004 is offline
post #2 of 2 (permalink) Old 07-28-2010, 05:57 PM
Standard Claims List For Model Year 2003
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 0 6A01 011801 * ENTRE * F20 P1 5
AWS Claim Key: 1522859 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 09443 - * Name: HOUSTON FORD, INC. Ph: 218-5874419 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:13745601
Cust Comments: REPAIR FOR RAIL DUST TYPE PARTICALS ALL OVER VEHICLE. TOP AND SIDES, FRONT & REAR.
Tech Comments: OSL TO PAULS LARGE GARAGE, INV 3518 USED CHEMICALS OVER ENTIRE VERTICAL AND HORIZONTAL SURFACES AND BUFFED AND POLISHED ENTIRE VEHICLE.
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 1 2E01 030008 3C3Z 9F838 EA D13 42 286
AWS Claim Key: 1889065 Trx Code: 2 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2003 Doc #:01976551
Cust Comments: CUST STATES THAT THE TRUCK IDLES ROUGH, STALLS, THE TRUCK RUNS ROUGH WHILE DRIVING, TACH BOUNCES
Tech Comments: COMPRESSON, OK. CK FOR UPDATE AND RECAL, NONE AVALIBLE AT THIS TIME. ROAD TEST, CODE DID NOT RESET, FORD IS STILL WORKING ON A FIX FOR THE ROUGH IDLE.
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 1 7S22 180106 F2UZ 14526 P L29 42 2408
AWS Claim Key: 1977501 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2003 Doc #:01985352
Cust Comments: ADD CUST ADDED TRAILER LAMP CIRCUIT IS INOP. RJJ 7 31 03
Tech Comments: X FUSE REPLACE
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 1 2D02 030008 3C3Z 12224 BA D21 42 2408
AWS Claim Key: 1977500 Trx Code: 2 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2003 Doc #:01985351
Cust Comments: CUST STATES AS DRIVE, ENG. REVS UP 300 RPMS MORE THAN AT RATE TRAVELING,THEN STARTS BUCKING & DIES,DOES STARTRIGHT BACK UP. ENG. LAMP IS ON.
Tech Comments: CLEARED CODES AND RETEST.
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 7 2G05 031405 * RECAL * D13 42 20280
AWS Claim Key: 4219248 Trx Code: E84 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:031677A
Tech Comments: WORK PERFORMED
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 7 6Q05 011901 3C3Z 17757 BA F39 05 20280
AWS Claim Key: 4219249 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:031677B
Cust Comments: CUST STATES THAT THE FRONT BUMPER IS RUSTING
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 11 6D01 011001 3C3Z 2862901 DAA S52 01 34864
AWS Claim Key: 6262915 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:24-MAY-2004 Doc #:034607A
Cust Comments: CUST STATES DRIVERS LEATHER SEAT COVER IS CRACKING ALL UP.
Tech Comments: WORK COMPLETED
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 37 * * * * * * * 89215
AWS Claim Key: 14134099 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:051618A
Cust Comments: 06E17 CUSTOMER STATES TO PERFORM RECALIBRATION PER RECALL
Tech Comments: PERFORMED RECALIBRATIONS PER RECALL 06E17
AWS Claim Key: 14183948 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:051618B
Cust Comments: 59B01 CUSTOMER STATES TO PERFORM ONE TIME TEST DRIVE PER RECALL
Tech Comments: PERFORMED TEST DRIVE PER RECALL 59B01
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 37 2E06 030008 3C3Z 9E527 AE D02 42 89215
AWS Claim Key: 14134100 Trx Code: E72 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:051618C
Cust Comments: CUSTOMER STATES THAT THE TRUCK WILL NOT START
Tech Comments: DIAGNOSED AND REPLACED THE FICM WIRING HARNESS ANDTHE LEFT SIDE INJECTORS
1FTSX31P53ED63127 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 04-JUN-2003 15-JUL-2003 158593 USA 38 2E01 030008 3C3Z 9F838 EA L65 D8 92989
AWS Claim Key: 14392683 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:052433A
Cust Comments: L65 CUSTOMER STATES THAT THERE IS AN OIL LEAK
Tech Comments: VERIFIED CONCERN. REMOVED TRANSMISSION AND REPLACED THE LEAKING ICP. REINSTALLED TRANS
you dont have to remove trans to replace ICP. Dont know what they were thinking!!
00f3fiddy is offline
4wd not engaging - 2003 F350 SRW shad9876 2003-2007 6.0L Power Stroke 1 03-27-2010 05:15 PM
2003 F-250 Oasis Request Shadow Ford Oasis requests 0 03-17-2008 03:11 PM
2003 F350 4x4 7.3 ontherks Whats Been Sold 2 09-17-2006 04:07 AM
OASIS Request for '02 F350 fgtex Ford Oasis requests 4 07-27-2006 05:51 AM
OASIS Request for '02 F350 fgtex Ford Oasis requests 0 07-24-2006 06:48 PM
