Oasis Report(s) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hntrjmpr1176, this thread has received 3 replies and been viewed 778 times.
post #1 of 4 (permalink) Old 07-28-2010, 12:53 PM Thread Starter
Oasis Report(s)
Hey, I was wondering if anyone could help me out with the OASIS Reports of two vehicles:
2005 F250
1FTSW21PX5EA47027
2003 F250
1FTNW21F63EB24624
Thanks!
hntrjmpr1176 is offline
post #2 of 4 (permalink) Old 07-28-2010, 05:35 PM
Standard Claims List For Model Year 2005
1FTSW21PX5EA47027 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-AUG-2004 10-SEP-2004 121549 USA 5 1F01 03XXXX * 6K775 * L68 33 15709
AWS Claim Key: 325388 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:21914501
Cust Comments: CUSTOMER STATES CK POWER STEERING LEAK
Tech Comments: CAC HOSE CLAMP LOOSE CHECK FOR POWER STEERING LEAK,FIND CHARGE AIR COOLER HOSE CLAMP LOOSE,TIGHTEN AND CLEAN RESIDUE OIL
1FTSW21PX5EA47027 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-AUG-2004 10-SEP-2004 121549 USA 8 1H02 120307 4C3Z 2A451 BA C19 41 22042
AWS Claim Key: 728342 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2005 Doc #:22426701
Cust Comments: CUSTOMER STATES AC WILL ONLY BLOW OUT DEFROST
Tech Comments: 41 STICKS BINDS PERF TST,DIAG,REPL VACUUM PUMP,RETST CK OK
1FTSW21PX5EA47027 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-AUG-2004 10-SEP-2004 121549 USA 13 3A15 0701XX 4C3Z 7G383 AA P66 41 35675
AWS Claim Key: 1996569 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2005 Doc #:23299101
Cust Comments: CUSTOMER STATES WHENS SLOWING DOWN SHIFTING IT SHIFTS REALLY HARD SLAMS INTO GEAR WHEN TOWING
Tech Comments: SOLENOID STICKING CHECK TRANS,RUN ECC TEST,NO CODES,RUN OUTPUT STATE CONTROL TEST,CHECK LINE PREASURE,REPLACE PCA SOLENOID,CHANGE FILTER AND FLUID,TEST DRIVE,RERUN QUICK TEST TO VERIFY REPAIR
1FTSW21PX5EA47027 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-AUG-2004 10-SEP-2004 121549 USA 33 * * * * * * * 101933
AWS Claim Key: 7851697 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 00454 - * Name: BEN ATKINSON MOTORS, INC. Ph: 334-2836815 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2007 Doc #:06098507
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR
Tech Comments: PERFORMED RECALL AS PER INSTRUCTIONS.
AWS Claim Key: 7851696 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00454 - * Name: BEN ATKINSON MOTORS, INC. Ph: 334-2836815 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2007 Doc #:06098508
Cust Comments: RECALL 59B01 ASSURANCE TEST DRIVE
Tech Comments: PERFORMED CUSTOMER ASSURANCE TEST DRIVE.
AWS Claim Key: 7851695 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00454 - * Name: BEN ATKINSON MOTORS, INC. Ph: 334-2836815 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2007 Doc #:06098509
Cust Comments: RECALL 05B32 DE GAS BOTTLE
1FTSW21PX5EA47027 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-AUG-2004 10-SEP-2004 121549 USA 42 7B02 140201 4C3Z 10346 AA D03 42 116452
AWS Claim Key: 9440964 Trx Code: SPW Labor Hrs: 1.7
Dlr Cd-Sub Cd: 00454 - * Name: BEN ATKINSON MOTORS, INC. Ph: 334-2836815 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2008 Doc #:06878501
Cust Comments: CUSTOMER REQUESTS CHARGING SYSTEM CHECK SEE RO#68771
Tech Comments: CHECK CHARGING SYSTEM. FOUND BATTERY OK. CHECK ALTERNATOR. FOUND ALTERNATOR WOULD ONLY CHARGE 12.44 VOLTS. REPLACED ALTERNATOR. NOW
00f3fiddy is offline
post #3 of 4 (permalink) Old 07-28-2010, 05:41 PM
Standard Claims List For Model Year 2003
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 3 7B02 140201 2C3Z 10346 BARM D02 42 3901
AWS Claim Key: 463383 Trx Code: 2 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03148 - * Name: BARBEE'S FREEWAY FORD, INC. Ph: 303-7573673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2003 Doc #:08934402
Cust Comments: CUSTOMER REQUESTS CHARGING SYSTEM CHECK HAD TO JUMP TO GET STARTED
Tech Comments: DIAG AND INSPECTION AND CHAARGING CIRCUITS TESTED FAILED. BATTERY LOAD AND CAPACITY TESTED FAILED. REPLACED 2 BATTERIES, #1 ACES CODE: HE3DQ AND DTC CODE: 9C414A #2 ACES CODE: HE5DQ AND DTC CODE: 9C7D4A. REPLACED
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 3 6Y05 000001 * MAINT * A96 82 3901
AWS Claim Key: 463384 Trx Code: 0715S Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03148 - * Name: BARBEE'S FREEWAY FORD, INC. Ph: 303-7573673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2003 Doc #:08934401
Cust Comments: CHANGE ENGINE OIL AND FILTER (DIESEL) QUALITY CARE MAINTANCE
Tech Comments: 1 CHANGED ENGINE OIL AND FILTER (DIESEL)
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 6 7S22 180106 F8SZ 14526 BA D02 42 8114
AWS Claim Key: 929075 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 03148 - * Name: BARBEE'S FREEWAY FORD, INC. Ph: 303-7573673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2003 Doc #:09316701
Cust Comments: TRK CRANKS BUT DOES NOT START
Tech Comments: HARD START NO START DIAG USING DIAG SHEET TEST STEPS 1 10 NO CODES RECEIVED, FOUND NO POWER TO IGNITION DUE TO FUSE REPAIRED CIRCUIT 325 DB OG AND REOUTED AWAY FROM FRAME. REPLACED FUSE AND RECHECKED OPERATION OK. ROAD TESTED OK.
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 8 6Y05 000001 * MAINT * A96 82 11254
AWS Claim Key: 1610618 Trx Code: 0715S Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03148 - * Name: BARBEE'S FREEWAY FORD, INC. Ph: 303-7573673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2003 Doc #:09751801
Cust Comments: CHANGE DIESEL OIL AND FILTER
Tech Comments: RECOMENDED MAINTENENCE PERFORMED DIESEL OIL AND FILTER CHANGE
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 10 6Y05 000001 * MAINT * A96 82 15000
AWS Claim Key: 2278391 Trx Code: 0715S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03148 - * Name: BARBEE'S FREEWAY FORD, INC. Ph: 303-7573673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2003 Doc #:10114501
Cust Comments: CHANGE DIESEL OIL AND FILTER QCM
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 17 2A01 031202 * 6C646 * L65 33 20747
AWS Claim Key: 4801808 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:05-MAR-2004 Doc #:63211701
Cust Comments: ENGINE OIL LEAK
Tech Comments: ENGINE OIL LEAK DIAG. TIGHTENED ALL INTAKE AND CAC HOSE CLAMPS.STEAM CLEANED ENGINE.
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 17 7A01 140100 * 10655 * C27 82 20747
AWS Claim Key: 4801807 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:05-MAR-2004 Doc #:63211702
Cust Comments: CUST STATES THAT BATTERY IS LEAKING
Tech Comments: NORMAL LEAKAGE FROM BATTERY CAPS.BATT.TESTED OK.CHECK CHARGING SYSTEM.30AMPS AT IDLE.110AMPS FULL CHARGING SYSTEM OK.NOT OVER CHARGING,CLEANED BATTERY AND TERMINALS.
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 28 2I04 030008 F7TZ 12B533 CA D03 42 35475
AWS Claim Key: 9601043 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2005 Doc #:67075101
Cust Comments: VERY HARD TO START COLD
Tech Comments: 7.3 HARD START TEST.INJ TEST.SCAN TOOL TEST.GLOW PLUG TEST RELAY FAILED.FUEL TEST.REPLACE GLOW PLUG RELAY.REPROGRAM PCM.RETEST
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 40 1B01 030201 F4TZ 6616 A L65 D1 46781
AWS Claim Key: 13053553 Trx Code: E72 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 01778 - * Name: STEVINSON'S GOLDEN FORD, INC. Ph: 303-2794521 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2006 Doc #:138978A
Cust Comments: CUST STTAES OIL LEAK AT FT OF ENG
Tech Comments: ADD DYE BLACKLIGHT TEST, FOUND OIL PUMP COVER LEAKING. DISASSEMBLED. REPLACED OIL PUMP COVER. REASSEMBLE, WASH OFF, ROAD TEST OK. ALSO HAD TO REPLACE RADIATOR PETCOCK END BROKE OFF DURING REPAIR
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 42 2E03 031401 XC3Z 12B599 AA D21 42 48799
AWS Claim Key: 13581581 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 01778 - * Name: STEVINSON'S GOLDEN FORD, INC. Ph: 303-2794521 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2006 Doc #:140703A
Cust Comments: CUST STATES DIES WHILE DRIVING,RESTARTS,CHECK ENG LIGHT IS ON
Tech Comments: ROAD TEST VERIFIED CONCERNS. FUEL PRESSURE OK. EEC TEST, PPT TEST. REPLACED FAILING CAM SENSOR. CLEARED CODES. ROAD TEST, CHECK ENGINE LIGHT BACK ON. PPT TEST, REPLACED IDM PER TEST. RESET KAM ANDCLEARED CODES. ROAD TEST OK. RETEST ALL PASS CODES
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 50 7S22 180106 2C7Z 14A068 AA L25 X2 59890
AWS Claim Key: 14661115 Trx Code: P05 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01778 - * Name: STEVINSON'S GOLDEN FORD, INC. Ph: 303-2794521 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2006 Doc #:146668A
Cust Comments: CUST STATES LOST BRAKE,TURN,REV,AND CONSOLE LIGHTS INOP CHECK AND ADV
Tech Comments: REVERSE, TURN, COMPASS INTERMITTANT. CHECKED FUSES18,27,34 IN CJB. ALL GOOD. CHECKED RELAYS. HAS INTERMITTANT TERMINAL CONNECTION INTERNAL IN CJB AT CONNECTOR C270A PIN 21, LB PK. NO DAMAGE TOPIN OR CONNECTOR. INSTALLED NEW CJB. RECHECK OK. MT, NO LABOR OPS FOR PART REPLACEMENT
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 51 2A01 030008 2C3Z 6N696 AA D42 69 60194
AWS Claim Key: 14705453 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 01778 - * Name: STEVINSON'S GOLDEN FORD, INC. Ph: 303-2794521 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2006 Doc #:147009A
Cust Comments: CUST STATES NO POWER ON COLD DRIVE AWAY CHECK AND ADV
Tech Comments: ROAD TEST VERIFIED EBP 48 PSI MOMENTARILY. FOUND EBP CONTROL VALVE BINDING AND OIL LEAK FROM EBP ACTUATOR. REMOVED TURBO, INSPECT CONTROL VALVE WOULD STICK IN CLOSED POSITION. REPLACED CONTROL VALVE. ALSO REPLACED EBP ACTUATOR PER TSB 4 20 2. REASSEMBLED. ROAD TEST OK. RETEST ALL PASS CODES.
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 65 * * * * * * * 70655
AWS Claim Key: 15819615 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03142 - * Name: LAKEWOOD FORDLAND, INC. Ph: 303-2322200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:18-FEB-2008 Doc #:07008602
Cust Comments: 07S57 CMP SENSOR INSPECTION
Tech Comments: PERFORM RECALL 07S57. REPLACE CMP SENSOR.
1FTNW21F63EB24624 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 24-OCT-2002 01-NOV-2002 156002 USA 88 * * * * * * * 85845
AWS Claim Key: 16599579 Trx Code: 09S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03142 - * Name: LAKEWOOD FORDLAND, INC. Ph: 303-2322200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2010 Doc #:10260504
Cust Comments: PERFORM UPDATE 09S09 CRUISE CONTROL
post #4 of 4 (permalink) Old 07-28-2010, 07:03 PM Thread Starter
Expert opinions??
Definitely considering the 2005. Any ideas on getting financing for a vehicle with higher mileage?? Credit Union wouldnt even touch it. Funny, they said if it was "newer," they would have no problem-no ****!! I am not trying to go over $300 per month. This is frustrating!
THANK YOU FOR LOOKING THESE UP!!!
Oasis report please Batch Ford Oasis requests 1 02-08-2008 12:48 AM
oasis report please #2 firedude26 Ford Oasis requests 2 02-04-2008 12:22 AM
Oasis Report Please SmokingIDI_7.3L Ford Oasis requests 2 01-09-2007 12:00 AM
oasis report carpe diem Ford Oasis requests 2 12-19-2006 03:24 PM
Oasis Report Please jamesb18cjdm Ford Oasis requests 1 12-19-2006 02:32 AM
