Please ! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by I Stand Alone, this thread has received 1 replies and been viewed 400 times.
post #1 of 2 (permalink) Old 07-28-2010, 01:34 PM Thread Starter
Images: 8
Please !
Vin # 1FDAW57P25EC57556
Thanks, Just a little worried about the dreaded 6.0
I Stand Alone is offline
post #2 of 2 (permalink) Old 07-28-2010, 05:27 PM
Standard Claims List For Model Year 2005
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 8 * * * * * * * 7915
AWS Claim Key: 3348979 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05344 - * Name: SHEEHY FORD Ph: 804-5987770 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:04157101
Cust Comments: 05B35 ECM RECALIBRATE
Tech Comments: 1 RECALIBRATE CONTROL MODULES PER RECALL 05B35
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 8 5V10 060601 5C3Z 2140 KB L63 D8 7915
AWS Claim Key: 3348978 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05344 - * Name: SHEEHY FORD Ph: 804-5987770 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2006 Doc #:04157102
Cust Comments: CHECK FOR BRAKE FLUID LEAK AT M CYL.
Tech Comments: CHECKED LEAK AT M CYL SWITCH. REPLACED MASTER CYLINDER AND BLED.
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 28 1H03 030804 4C3Z 9P456 AF L87 42 25546
AWS Claim Key: 8593363 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 08438 - * Name: BERGLUND FORD MERCURY Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:26174301
Cust Comments: CUSTOMER STATES WHITE SMOKE COMMING OUT EXHAUST BLEW INTAKE HOSE HAD BEEM REPLACE TOWED IN BY CUSTOMER CALLED ROADSIDE ASSITANCE
Tech Comments: DIAGNOIS CONCERN PRESSURE TEST COOLING SYSTEM EGR COOLER LEAKING INSTALL EGR COOLER WHEN EGR COOLER WENT BAD IT DAMAGED CAC COOLER ALSO INSTALL CAC COOLER
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 28 2A01 031202 * 6C646 * D50 D4 25546
AWS Claim Key: 8611541 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 08438 - * Name: BERGLUND FORD MERCURY Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:26174303
Cust Comments: CAC HOSE COLD SIDE BLEW HOLE CAUSING NO BOOST AND NOISE
Tech Comments: CUSTOMER REFUND CAC HOSE CAME APART OUT OF TOWN DEALER DID NOT HAVE TIME TO REPAIR CUSTOMER PURCHASED HOSE INSTALLED HIMSELF
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 32 2G88 000615 * NPF * L87 82 26840
AWS Claim Key: 9247144 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2008 Doc #:32660601
Cust Comments: LOOSING COOLANT WHEN DRIVING POSS BURNING INSIDE ENG CUST STATES THERE IS SMALL DROPS OF COOLANT ON GROUND
Tech Comments: SELF TEST WITH IDS CODE PO299 PINPOINT TEST REMOVE EGR VALVE AND CHECK INTAKE MANIFOLD FOR COOLANT NONE WAS FOUND CHECK SERVICE MESSAGES AND TSB 07 21 5 N P F DEGAS BOTTLE MAY HAVE BEEN OVERFILLED AND VENTED OUT WHILE TOWING SET COOLANT LEVEL TO PROPER LEVEL AND GIVE CUSTOMER A COPY OF SERVICE MESSAGE DESCRIBING CONDITION
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 33 2G88 000615 * NPF * L87 82 27528
AWS Claim Key: 9524210 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:18-FEB-2008 Doc #:37580001
Cust Comments: OWNER STATES LOSS OF COOLANT
Tech Comments: NPF WITH LOSS OF COOLANT PRESSURE TEST COOLING SYSTEM CHECKED FOR LEAKS NO LEAKS FOUND RAN OASIS CHECKED FOR SSMS AND TSBS MONITOR ECT AND EOT BOTH ARE AT 183 DEGREES HAD NO COOLANT SMELL ON THE 2 ROADTEST THAT WERE DONE IDS TEST KOEO PASSED KOEC PASSED KOER PASSED EGR VALVE TEST PASSED REMOVE EGR VALVE CHECKED FOR COOLANT IN INTAKE NONE FOUND
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 36 1B03 030204 3C3Z 6A642 AA L87 42 29122
AWS Claim Key: 9882569 Trx Code: E84 Labor Hrs: 6.5
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2008 Doc #:43817801
Cust Comments: OWNER STATES COOLANT DRIPS AFTER TRIP, AND AFTER DRIVING HAS COOLANT ODOR AFTER STOP.
Tech Comments: EGR COOLER LEAKING, OIL COOLER STOPPED UP ROAD TEST PRESSURE TEST COOLING MONITOR PIDS FOR ECT AND EOT REMOVE EGHR VALVE AND CHECK INTAKE FOR COOLANT AND REPLACE EGR AND OIL COOLER CHANGE OIL AND FILTER ROAD TEST
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 38 1G01 030305 * 8575 * E23 41 30963
AWS Claim Key: 10281065 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:50033901
Cust Comments: SEE HISTORY, OWNER STATES NOT LOSING COOLANT BUT TOWING SMAL L TRAILER TMEP GAUGE GOES TO HOT AND CK GAUGE WARNING COMES ON. LETTINGOFF ACCELERATOR TEMP GAUGE GOES BACK HALF WAY
Tech Comments: ROAD TEST SELF TEST WITH IDS N OCODES FOR OVERHEATING CUSTOMER STATES NO LOSS OF COOLANT BUT DEGAS BOTTLE SHOWS SIGNS OF VENTING AND IT APPEARS GREEN COOLANT HAS BEEN ADDED TO D GAS BOTTLE REMOVE AND TEMPERATURE CHECK THERMOSTAT AND REPLACE CHECK OPERATION OF VISCUS FAN CLUTCH MONITOR PIDS TO DETERMINE WHEN HIGH SPEED
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 38 1F06 030304 6C3Z 8A080 B L87 D1 30963
AWS Claim Key: 10281063 Trx Code: P05 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:50033904
Cust Comments: REFER LINE 1 REPAIR ENG COOLANT LEAK
Tech Comments: PRESSURE TEST COOLING SYSTEM, LEAK AT BOTTLE AND CAP REPL AND RETEST OK
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 38 1F05 030306 * 8A616 * E23 42 30963
AWS Claim Key: 10281064 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06707 - * Name: SHEEHY FORD LINCOLN MERCURY Ph: 804-7940500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:50033903
Cust Comments: REFER LINE 1 ENGINE OVERHEATING CONCERN
Tech Comments: CHECK OPERATION OF VISCUS FAN CLUTCH, INSUFFICIENT COOLING AT HIGH SPEEDS, REPL FAN CLUTCH AND RETEST OK
1FDAW57P25EC57556 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 07-MAR-2005 09-JUN-2005 127049 USA 40 1A02 030102 * 6051 * D50 42 31872
AWS Claim Key: 10465996 Trx Code: E72 Labor Hrs: 23.2
Dlr Cd-Sub Cd: 06696 - * Name: COLONIAL FORD TRUCK SALES, INC. Ph: 804-2323492 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2008 Doc #:036684A
Cust Comments: ENGINE LEAKING COOLANT
Tech Comments: 31872 CHECKED FOR LOSSING COOLANT OUT DEGAS BOTTLE PRESURE TESTED COOLANT SYSTEM PRESURE TESTED DEGAS CAP OKINSTALLED IDS ROAD TESTEDTO DIAG FAN CLUTCH OK REPROGRAMMED PCM PERFORMED BOOST TEST OK REMOVEDD AND LEAK TESTED EGR COOLER PASS TESTED OIL COOLER PASS CONTACTED HOTLINE FOR PRIOR APP.CODE PAA7V ADVISE REPLACED HEAD GASKETS REMOVED CAB REPLACED GASKETS PER TSB REASSEMBLED
00f3fiddy is offline
