Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fedman, this thread has received 1 replies and been viewed 515 times.
post #1 of 2 (permalink) Old 07-29-2010, 05:57 PM Thread Starter
Oasis please
Just saw this at a local dealer and would like an Oasis if possible.
THANKS!
1FTWW33P26EC03549
08' F350 Lariat DRW
fedman is offline
post #2 of 2 (permalink) Old 07-29-2010, 07:06 PM
Standard Claims List For Model Year 2006
1FTWW33P26EC03549 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-NOV-2005 23-MAY-2006 111539 USA 23 2G05 031405 * RECALEM * L69 04 35972
AWS Claim Key: 5923279 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2008 Doc #:04678502
Cust Comments: CUSTOMER STATES THE FUEL RANGE TO EMPTY USED TO GO DOWN AS FAR AS 10 MILES TO EMPTY, NOW WHEN GETS TO 50 MILES TO EMPTY THE TRUCK RUNS OUT OF FUEL. INSPECT AND ADVISE.
Tech Comments: RECALIBRATION FOR P0460 INSPECTED FOR CUSTOMER CONCERN OF INACCURATE DISTANCE TO EMPTY DISPLAY. VEHICLE HAS APPROX 3 4 TANK SO CANNOT VERIFY CONCERN. SCAN TESTED FOR FAULT CODES AND GOT P0460. RECALIBRATED POWERTRAIN CONTROL TO LATEST LEVEL AS PER TSB 06 13 11
1FTWW33P26EC03549 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-NOV-2005 23-MAY-2006 111539 USA 23 7W11 0110XX 6C3Z 14D696 A S56 46 35972
AWS Claim Key: 5923280 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2008 Doc #:04678501
Cust Comments: CUSTOMER STATES THE DRIVER SEAT BASE HEATER DOES NOT FUNCTION. INSPECT AND ADVISE OF REPAIR REQUIRED.
Tech Comments: FAULTY LEFT FRONT SEAT BASE HEATER ELEMENT VERIFIED CUSTOMER CONCERN, LEFT FRONT SEAT BASE DOES NOT HEAT. TESTED CIRCUIT AND DIAGNOSED OPEN CIRCUIT IN HEATER ELEMENT. REMOVED AND REPLACED HEATER ELEMENT PAD. TESTED OK.
1FTWW33P26EC03549 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-NOV-2005 23-MAY-2006 111539 USA 44 2E03 031403 4C3Z 12B599 ABRM E29 42 58486
AWS Claim Key: 8791217 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 20524 - * Name: CARMODY FORD-MERCURY INC Ph: 518-6922246 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2009 Doc #:05685901
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT HAS BEEN COMING ON AND THE VEHICLE SEEMS TO SKIP, SPUTTER AND HESITATE. INSPECT AND ADVISE OF REPAIR REQUIRED. WORSE COLD STILL THERE WARM
Tech Comments: FAULTY FUEL INJECTOR CONTROL MODULE VERIFIED CUSTOMER CONCERN OF CHECK ENGINE LIGHT WITH POOR DRIVABILITY. SCAN TESTED, FAULT CODE P0611. CHECKED FICM POWER AND GROUNDS, ALL OK. MONITOR FICM VOLTAGE STARTING AND FOUND VOLTAGE DROPS OFF. CONTINUED WITH PINPOINT TESTS AND DETERMINED FICM FAULTY. REMOVED AND REPLACED FUEL INJECTOR CONTROL MODULE, UPDATED NEW FICM TO LATEST
No open recalls!!!!
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
fedman (07-29-2010)
