Requesting an Oasis Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kovatch, this thread has received 1 replies and been viewed 752 times.
post #1 of 2 (permalink) Old 08-07-2010, 07:33 PM Thread Starter
My VIN # is as follows:
1FTNW21P23EB54261
I appreciate your help with the request.
Kovatch is offline
post #2 of 2 (permalink) Old 08-09-2010, 03:02 PM
Standard Claims List For Model Year 2003
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 0 4C01 090101 * 5230 * L66 33 16
AWS Claim Key: 316634 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2002 Doc #:135902A
Cust Comments: EXHAUST RATTLING
Tech Comments: 16 MISSING SECURING NUTS 4X4 VERIFY CONCERN FOUND HANGER SECURING NUTS MISSING INSTALL NUTS & TORQUE TO SPECS RECHECK OPERATION OK
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 6 2G05 * * * * * * 11249
AWS Claim Key: 4334361 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:154915E
Cust Comments: RECALL 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT.
Tech Comments: 11249 REPROGRAM PCM FLIM TCL
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 6 2E01 * * * * * * 11249
AWS Claim Key: 4334360 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:154915D
Cust Comments: RECALL 03B05 INJECTION CONTROL PRESSURE (ICP) SESNOR REPLACEMENT.
Tech Comments: 11249 REPLACE ICP CHANGE OIL AND FILTER
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 6 6J14 0114XX 3L3Z 25218A42 AA L15 41 11249
AWS Claim Key: 4334359 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:154915B
Cust Comments: CUST STATES RIGHT REAR DOOR POWER LOCK INOP.
Tech Comments: 11249 REMOVE DOOR PANNEL REPLACE LOCK ACTULATOR
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 6 7T09 191001 * 14B205 * P66 28 11249
AWS Claim Key: 4443411 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:154915A
Cust Comments: CUST STATES VEHICLE WILLNOT COME OUT OF 4X4 HIGH. WHEN TRYING TO SHIFT INTO 4X4 LOW IT WILL NOT ENGAGE, STAYS IN HIGH. LIGHT ON STEADY.
Tech Comments: 11249 CHECK OUT WILL NOT SWITCH OUT OF FOUR BY FOUR HIGH. CHECK SWITCH OK ECC TEST CODE P1820 PIN POINT TEST E E1,E2,E12,E13,E14,E15. REPAIR 782 BR WH WIRE BROKEN AT C144. CLEAR CODE RETEST OK
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 6 2E05 100106 3C3Z 9B249 AB E29 49 11249
AWS Claim Key: 4443412 Trx Code: 1 Labor Hrs: 8.1
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2004 Doc #:154915C
Cust Comments: CUST STATES WATER IN FUEL LIGHT IS ON AT ALL TIMES, ENGINE IS LAGGING AND HAS NO POWER. CUST REPLACED FUEL FILTER AT 10,000 MILES.
Tech Comments: 11249 WDS TEST CODES P0232, P0266. TRYED TO DRIAN WATER FOR LIGHT TO GO OFF. DID NOT REMOVE SIDE COVER HEATER MELTED INSIDE REPLACE COVER. RETEST WATER IN FUEL LIGHT WENT OFF. STILL RAN BAD AND HAD CODES P0232.P0266 HOOK UP FUEL PSI GAUGE VERY LOW REPLACE FUEL PUMP AND REPLACE BOLTH FILTERS RETEST GOOD FUEL PSI. CLEAR CODES RETEST P0266 TEST INJECTORS NUMBER TWO SHOWED OPEN REMOVE LEFT
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 9 6J13 011404 * 7822134 * B09 33 17406
AWS Claim Key: 5695318 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2004 Doc #:159359A
Cust Comments: PASSENGER SIDE REAR DOOR WILL NOT OPEN AT ALL. PLEASE CHECK.
Tech Comments: 17406 RR TRIM REPAIR LOCK ROD OFF ACTUATOR
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 10 2E03 030008 4C3Z 12B599 AARM D36 42 20621
AWS Claim Key: 6473359 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2004 Doc #:161609A
Cust Comments: CUST STATES ENGINE IS STALLING AND WILL NOT RESTART. CRANKS. WAIT 20 30 MINS ENGINE RESTARTS. DRIVE 1 MILE ENGINE STALLS.
Tech Comments: 20621 INTERMITTENT STALL ROAD TESTED CHECK AND ADD OIL WDS TEST NO CODES INJECTOR BUZZ TEST OK KEY ON ENGINE RUN TEST CODE U0105 FOR INTERMITTENT LOSS OF FICM COMMUNICATION CHECKED FOR BAD RELAY OK PINPOINT TEST PER PC ED ALSO CHECKED FOR SHORTED WIRING TO FICM MODULE AND REPLACE MODULE REPROGRAM MODULE USING WDS AND RETESTED FOR CODES NONE ROAD TESTED BY SHOP FOREMAN AND RETESTED
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 10 3A10 070701 * 7005 * K01 28 20621
AWS Claim Key: 6473358 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2004 Doc #:161609B
Cust Comments: CUST STATES VEHICLE WILL NOT COME OUT OF 4X4.
Tech Comments: 20621 OPEN CIRCUIT TEST 4X4 SYSTEM USING NGS ACCESSED PIDS TO VERIFY MODULE IS RECEIVING PROPER SIGNAL FROM SWITCH OK CODE P1820 FOR LOW TO HIGH RELAY IN GEM PINPOINT TESTED RELAY CIRCUIT 782 TRACED CIRCUIT TO OPEN CIRCUIT AT C144 REPAIRED WIRING AND RETESTED CLEARED CODES OK
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 20 * * * * * * * 35661
AWS Claim Key: 10247049 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2005 Doc #:173981F
Cust Comments: RECALL 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION.
Tech Comments: 35661 RECALL REPLACE GROUND STUD PER RECALL
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 20 5G04 040105 2C3Z 5484 AA N59 33 35661
AWS Claim Key: 10247048 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2005 Doc #:173981D
Cust Comments: CUST STATES CLUNKING RATTLE IN THE FRONT OF THE VEHICLE OVER BUMPS.
Tech Comments: 35661 REPLACE STABILIZER BAR BUSHINGS CUSTOMER TO RETURN TO HAVE BALL JOINTS REPLACED
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 20 2G02 030008 3C3Z 12A690 AA L65 01 36816
AWS Claim Key: 10425181 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2005 Doc #:174714A
Cust Comments: CUST STATES ENGINE IS LEAKING ENGINE OIL. S O P. 3.18.05 35661 MILES RO # 173981.
Tech Comments: 36816 LEAKING WASH DOWN LEAK TEST USING UV DYE REPLACED LEFT GLOW PLUG BUSS BAR THAT WAS LEAKING ROAD TEST AND RETEST FOR LEAKS OK
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 25 2G02 030008 3C3Z 12A690 AA L65 D8 45261
AWS Claim Key: 11837568 Trx Code: E88 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:19-AUG-2005 Doc #:180679B
Cust Comments: CHECK AND ADVISE ENGINE IS LEAKING OIL.
Tech Comments: 45261 LEAKING WASH DOWN DYE TESTED AFTER ROAD TEST ON HIGHWAY REPLACED LEFT GLOW PLUG BUS BAR DUE TO O RINGS LEAKING
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 33 * * * * * * * 58625
AWS Claim Key: 13649412 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:189847G
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE PROGRAM 59B01
Tech Comments: ROAD TESTED FOR PROGRAM 59B01
AWS Claim Key: 13649411 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:189847F
Cust Comments: RECALL 06E17 CONTROL MODULE RECAL.
Tech Comments: 58625 RECAL PCM AND ROAD TEST
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 52 2E01 030008 3C3Z 9F838 EA D02 42 87006
AWS Claim Key: 15715120 Trx Code: E72 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2007 Doc #:212254A
Cust Comments: CUST STATES ENGINE IS HARD TO START IN THE AM. ENGINE FIRES BUT RUNS VERY ROUGH UNTIL OPERATING TEMPATURE.
Tech Comments: 87006 6.0 DIESEL HARD START DIAG KOEO AND KOER TESTS CODES P2285 P0404 AND P0405 PERFORMED PINPOINT TEST INJECTOR ELECTRICAL TEST GLOW PLUG SYSTEM OPERATION TEST OK FUELPUMP PRESSURE OK AT ABOUT 50 PSI POWER BALANCE INDICATES MISFIRE ON CYLINDERS 2 3 5 AND 7 PID DATA MONITOR ICP VOLTAGE OUT OF RANGE KOEO AT .04VOLTS RNR TURBO HEAT SHIELD TO ACCESS ICP FOUND IT LEAKED OIL
1FTNW21P23EB54261 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2002 25-AUG-2003 144010 USA 52 2G02 030707 8C3Z 12K073 A L65 D1 87006
AWS Claim Key: 15715121 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2007 Doc #:212254C
Cust Comments: CUST STATES ENGINE OIL LEAKING FROM BACK OF ENGINE.
Tech Comments: 87006 OIL LEAK DIAG FOUND OIL LEAKING OUT OF CRANK AND CAM SENSORS ALSO OUT OF LEFT BANK GLOW PLUG BUS BAR REPLACED BUS BAR AND REPLACED CAM AND CRANK SENSORS DEGREASED ENGINE AS BEST AS POSSIBLE
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
Kovatch (08-10-2010)
Requesting an Oasis Report 04lariatfx4crewcab Ford Oasis requests 2 06-19-2009 02:11 PM
Requesting OASIS report Scotty Ford Oasis requests 2 01-29-2009 09:26 PM
Requesting OASIS report please MileHigh Ford Oasis requests 1 02-01-2008 01:50 AM
Requesting Oasis Report, Please laduckdog Ford Oasis requests 2 05-16-2007 02:35 AM
requesting an oasis report fyreman94 Ford Oasis requests 1 03-30-2007 02:48 AM
