oasis request please, thanks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redbull660, this thread has received 1 replies and been viewed 484 times.
post #1 of 2 (permalink) Old 08-08-2010, 09:30 PM Thread Starter
Here is the vin number 1FTWW31P35ED03001
Thanks, I really do appreciate it, Cory
redbull660 is offline
post #2 of 2 (permalink) Old 08-09-2010, 03:01 PM
Standard Claims List For Model Year 2005
1FTWW31P35ED03001 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2005 10-MAY-2005 156649 USA 1 7C05 180301 F8UZ 14N089 AA D50 42 448
AWS Claim Key: 1104549 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 08302 - * Name: COURTESY FORD SALES Ph: 307-8855684 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2005 Doc #:0281771
Cust Comments: COMPLAINT OF VEHICLE WONT START
Tech Comments: WDS NO CODES FUEL PUMP RELAY NOT OPERATING REPLACED RELAY BURN OPEN CIRCUIT DIAGNOSED RELAY PROBLEM TO FUSE BOX PANEL ASY REPLACE FUSE PANEL PASSE
1FTWW31P35ED03001 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2005 10-MAY-2005 156649 USA 20 2E03 030402 4C3Z 9E527 AA D50 42 57739
AWS Claim Key: 6979220 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 08302 - * Name: COURTESY FORD SALES Ph: 307-8855684 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2006 Doc #:00597001
Cust Comments: CUST STATES TRUCK RUNS POOR
Tech Comments: DIAG FOUND INJECTORS FAILED REPLACED FAILED INJECTORS RE CK OK
1FTWW31P35ED03001 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2005 10-MAY-2005 156649 USA 20 * * * * * * * 57739
AWS Claim Key: 6989510 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08302 - * Name: COURTESY FORD SALES Ph: 307-8855684 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2006 Doc #:00597002
Cust Comments: NEEDS RECALL 05B32
Tech Comments: PERFORMED RECLAL 05B32
AWS Claim Key: 6979221 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08302 - * Name: COURTESY FORD SALES Ph: 307-8855684 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2006 Doc #:00597003
Cust Comments: NEEDS RECLL 05S35
Tech Comments: PERFOREMD RECALL 05B35
1FTWW31P35ED03001 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2005 10-MAY-2005 156649 USA 27 2E01 03XXXX 4C3Z 9B246 A D02 42 68105
AWS Claim Key: 8276879 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 03213 - * Name: FREMONT MOTOR COMPANY Ph: 307-3324355 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2007 Doc #:111709A
Cust Comments: CUST STATES VEHICLE QUIT WHILE DRIVING, NOW ENGINE HAS CRANK, NO START
Tech Comments: EEC TEST,NO CODES. PERFORM HARD,NO START DIAG. PERFORM HIGH PRESSURE OIL LEAK, AIR CHECK, FOUND LEAKING AT BRANCH TUBE. REMOVE AND INSTALL REENFORCEMENT KIT. TEST DRIVE, OK.
1FTWW31P35ED03001 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2005 10-MAY-2005 156649 USA 28 2H01 030407 5C3Z 6K682 CARM N11 42 64449
AWS Claim Key: 9095150 Trx Code: S07 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 03103 - * Name: LARAMIE FORD-LINCOLN-MERCURY Ph: 307-7457315 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2007 Doc #:06479001
Cust Comments: CUSTUMER STATES VEHICLE MAKING FUNNY NOISE IN ENGINE
Tech Comments: VERIFY CONCERN FOUND NOISE INSIDE TURBO BEARING GOING OUT R+R CUSTOM AIR FILTER+EXHAUST, R+R HOT SIDE INNER COOLER R+R TURBO TEST DROVE ALL OK MILEAGE IS CONSISTANT WITH OTHER REPAIRS AT THIS DEALERSHIP SUSPECT ERROR ON CLAIM WITH HIGHER
00f3fiddy is offline
Oasis Request Please EJM Ford Oasis requests 1 01-14-2009 03:54 AM
MJM Oasis request mjm Ford Oasis requests 1 01-10-2009 12:52 AM
OASIS Request Wildland Ford Oasis requests 3 09-15-2007 07:31 PM
Oasis Request F350MX Ford Oasis requests 2 04-12-2007 11:37 PM
OASIS request - please snagnever Ford Oasis requests 1 09-20-2006 03:49 AM
