Standard Claims List For Model Year 2008
1FTSW21R48EA20072 T/F7 F T/BC T/
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 3 * * * * * * * 5627
AWS Claim Key: 49849 Trx Code: 07S49 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 10670 - * Name: WOODHOUSE LINCOLN MERCURY, INC. Ph: 402-5921044 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2007 Doc #:0750811
Cust Comments: REPROGRAM PCM PER 07S49.
Tech Comments: REPROGRAMMED PCM.
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 6 7H01 120301 * 19703 * C02 42 13372
AWS Claim Key: 95450 Trx Code: E83 Labor Hrs: 5
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2007 Doc #:15466101
Cust Comments: CK FOR INTERMITTENTLY AC WILL JUST BLOW WARM
Tech Comments: VERIFIED CONCERN. CHECKED FOR POWER & GROUNDS. CHECKED AC CLUTCH AIR GAP. REMOVED FAN SHROUD AND ACCESSORY DRIVE BELT. REMOVED AC COMPRESSOR BELT. LOOSENED AC COMPRESSOR IN INSTALLED SHIM. RETESTED.
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 14 7H01 120301 7C3Z 19703 AA C05 01 29301
AWS Claim Key: 609793 Trx Code: E83 Labor Hrs: 4
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2008 Doc #:338124A
Cust Comments: CUST STATES WHEN YOU TURN ON THE A C INSIDE OF THE VEHICLE THE A C CLUTCH WILL NOT ENGAUGE UNLESS YOU GO TAP ON IT
Tech Comments: 29308 AC COMPRESSOR VERIFY CONCERN DIAGNOS AND FOUND COMPRESSOR SHAFT IS BROKEN INTERNALLY CAUSING CONCERN EVEN WHEN COMPRESSOR IS ENGAGED PRESSURES DO NOT CHANGE REMOVE RF INNER FENDER WELL AND REMOVE ORIFICE TO INSPECT FOR DAMAGE AFTER RECOVERING FREON WAS OK REMOVE COMPRESSOR TRANSFER CLUTCH ASSEMBLY . REINSTALL COMPRESSOR EVAC AND RECHAR GE WITH 4 OZS OIL AND 1.69 LBS
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 17 1F01 030301 8C3Z 8009 B L87 42 35781
AWS Claim Key: 1118338 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2008 Doc #:347622A
Cust Comments: CUSTOMER STATES THERE IS A COOLANT LEAK FROM THE RADIATOR THAT DEVELOPED LAST WEEK
Tech Comments: 35781 RADIATOR VERIFIED COOLANT LEAK PRESSURE TESTED FOUND LEAK COMING FROM SIDE TANK OF RADIATOR INTALLED NEW RADIATOR AND VENT KIT AND VERIFIED REPAIR
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 17 2E02 * * * * * * 35781
AWS Claim Key: 1118339 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2008 Doc #:347622D
Cust Comments: PERFORM RECALL #08C04
Tech Comments: 35781 PERFORMED RECALL
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 25 2G01 * * * * * * 50141
AWS Claim Key: 2785260 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2009 Doc #:1068243
Cust Comments: PERFORM RECALL 08B07
Tech Comments: REPROGRAMM MODULES PER RECALL
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 25 5O01 110201 7C3Z 3504 B H22 42 50141
AWS Claim Key: 2785259 Trx Code: P18 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2009 Doc #:1068241
Cust Comments: CUST STATES WHILE TURNING LEFT THE STEERING WHEEL LOCKED UP AND WOULDNOT TURN TO THE LEFT ANYMORE HAD TO GO THE THE RIGHT THE IT SEEMED TO RELEASE AND COULD TURN BACK TO THE LEFT
Tech Comments: CUDL CASE 1544362307 FOUND STEERING GEAR OUTPUT SHAFT MOVES IN AND OUT 1/2 INCH REPLACE STEERING GEAR CENTER WHEEL AND ROAD TEST
BD T/E A1 T/BE T/QL 22-JAN-2007 20-FEB-2007 153507 USA 25 6Y20 000000 * TAP1 * A99 82 50141
AWS Claim Key: 2798758 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 07192 - * Name: ANDERSON FORD LINCOLN MERCURY OF LINCOLN Ph: 402-4758821 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2009 Doc #:1068247
Cust Comments: TAP LOANER VEHICLE
Tech Comments: TAP1 LOANER VEHICLE 3 DAYS
