Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dwblanken, this thread has received 3 replies and been viewed 584 times.
post #1 of 4 (permalink) Old 08-15-2010, 08:39 PM Thread Starter
Report Please
Vin 1ftww31p55ec29368
This is a new truck to me and I would like to know some history on this thing.
Thanks much for any help,
Dale
dwblanken is offline
post #2 of 4 (permalink) Old 08-16-2010, 01:07 AM Thread Starter
Getting posts up to PM
post #3 of 4 (permalink) Old 08-16-2010, 01:07 AM Thread Starter
Getting p[osts up to PM
post #4 of 4 (permalink) Old 08-16-2010, 02:40 PM
Standard Claims List For Model Year 2005
1FTWW31P55EC29368 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 20-FEB-2005 12-AUG-2005 174540 USA 0 1C02 030902 3C3Z 6564 AA D50 01 28
AWS Claim Key: 2071262 Trx Code: 1 Labor Hrs: 30.2
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2005 Doc #:609698A
Cust Comments: BLOWS BLACK SMOKE AT FIRST THEN WHT SMOKE, BAD MISS
Tech Comments: 38 BENT VALVES IN BOTH CYLINDER HEADS ? VERIFIED CONCERN, RAN OASIS FOUND NOTHING PERFORMED DI PERFORMANCE SHEET STEP 1 4 FOUND CODES PO266, P0272, P0284 ALL CONTRIBUTIO N CODES, REMOVED INSTAKE TUBE AND AIR FILTER HOUSING, REMOVED FICM, CRANKCASE BREATHER, TURB O, TURBO PEDASTAL OIL FILTER HOUSING, LEFT VALV E COVER AND GASKET, REMOVED AND INSP ALL PUSH RODS AND ROCKER ARM
1FTWW31P55EC29368 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 20-FEB-2005 12-AUG-2005 174540 USA 4 7T03 050300 5C3Z 2C204 BA H19 28 9266
AWS Claim Key: 2930893 Trx Code: 1 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2005 Doc #:618252A
Cust Comments: ABS LIGHT IS ON
Tech Comments: 9268 ABS LIGHT ON. EEC TEST, C1155, C1233, U1900. PINPOINT TESTS. DCL DISPLAY, NORMAL READINGS. ROAD TESTED W WDS, NO LF WHEEL SPEED SIGNAL. TESTED CIRCUIT, FOUND OPEN CIRCUIT IN LF WHEEL SPEED SENSOR. R&R LF WHEEL, CALIPER AND BRACKET AND ROTOR. REPLACED SENSOR. CLEARED CODE. ROAD TESTED, NO LIGHT ON NOW. RETESTED EEC, PASSED.
1FTWW31P55EC29368 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 20-FEB-2005 12-AUG-2005 174540 USA 7 6N04 010802 5C3Z 16720 CB B66 05 17520
AWS Claim Key: 4260049 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2006 Doc #:623155E
Cust Comments: PAINT FALLING OFF ALL FORD O S EMBLEMS, FENDERS TIMES 2 XLSUPERDUTY, TAIL GATE F350 SUPERDUTY
Tech Comments: 17520 SUBLET TO VANS AUTO BODY, RR ALL 3 EMBLEMS$50.0 EMBLEMS PEELING PAINT IN THE LETTERS,BLACK PAIN T
1FTWW31P55EC29368 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 20-FEB-2005 12-AUG-2005 174540 USA 7 * * * * * * * 17520
AWS Claim Key: 4260048 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2006 Doc #:623155C
Cust Comments: DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL SADJ.
Tech Comments: 17520 WF ADJUSTED COOLANT LEVEL AND INSTALL DE GAS LABEL
AWS Claim Key: 4260047 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2006 Doc #:623155B
Cust Comments: PROGRAM 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: 17520 O5B35 WF PERFORM PCM,FICM AND TCM REFLASH.
1FTWW31P55EC29368 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 20-FEB-2005 12-AUG-2005 174540 USA 20 1H03 030008 * 9F452 * E29 55 62800
AWS Claim Key: 7616498 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 08680 - * Name: BICKFORD MOTORS, INC. Ph: 360-5682122 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2007 Doc #:642977A
Cust Comments: CK ENGINE LIGHT ON, MISS PULLING TRAILER HAS NEW FUEL FILTER.
Tech Comments: 62800 PAPWR FUSE AND EGR VALVE 0 PERFORM ROAD TEST.VERIFY CONCERN.PERFORM PERF.SHEET.CODE P1633 KAPWR FUSE CONCERN.PERFORM TSB 5 11 14.CHECKED FUSE.REPOSITION FUSE VERIFY REPAIR. VERIFY MISS.PERFORM EGR TEST.FAILED.PERFORM.TSB 6 19 6.EGR VALVE STICKING INTERMITTEN.CLEANED RETESTED,FAILED.REPLACED EGR VALVE.PERFORM POST EEC TEST ALL PASS.
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
dwblanken (08-17-2010)
Oil Report MOPSD250 2003-2007 6.0L Power Stroke 5 10-29-2009 02:27 PM
Report Please R.Taylor Ford Oasis requests 3 02-07-2008 02:10 AM
Report please. nitrodiesel Ford Oasis requests 1 02-06-2008 01:30 AM
Report Please :) 2fun4u Ford Oasis requests 1 05-09-2007 03:10 AM
report plz rshrubber Ford Oasis requests 4 07-06-2006 05:43 PM
