oasis please, thanks for the help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bubbagump, this thread has received 1 replies and been viewed 398 times.
post #1 of 2 (permalink) Old 08-17-2010, 05:56 PM Thread Starter
VIN# 1FTSX31P54ED08856
bubbagump is offline
post #2 of 2 (permalink) Old 08-17-2010, 09:20 PM
Standard Claims List For Model Year 2004
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 10 3A03 * * * * * * 12502
AWS Claim Key: 5336177 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 09916 - * Name: LARRY HILL FORD, INC. Ph: 423-4725454 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:117928C
Cust Comments: PERFORM 04B24 REVERSE PLANETARY GEAR
Tech Comments: PERFORM RECALL 04B24
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 10 2G05 031405 * RECAL * D21 07 12502
AWS Claim Key: 5336176 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: 09916 - * Name: LARRY HILL FORD, INC. Ph: 423-4725454 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:117928A
Cust Comments: ENGINE STALLED
Tech Comments: TEST EEC IV DIAG WITH NGS PERFORM PINPOINT TEST INSTALL PID MONITOR INSPECT FOR WIRE CHAFTING NONE FOUND REPROGRAM PCM RETEST ROAD TEST
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 10 2E05 100106 3C3Z 9B249 AB D21 42 13059
AWS Claim Key: 5552863 Trx Code: E84 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 03943 - * Name: GAINESVILLE FORD Ph: 352-3765371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAY-2005 Doc #:00218901
Cust Comments: ENGINE DIESEL CUSTOMER STATES ABS LIGHT STARTS BLINKING, CHECK GAUGE LIGHT COMES ON, VEHICLE STARTS SHUTTING OFF AND WILL RESTART AFTER AB
Tech Comments: DOES NOT OPERATE PROPERLY DIAG HARD START PIN POINT TEST WATER SEPERATOR REPLACE MANIFOLD ASSEMBLY INSPECT PCM FICA TCM CALIBRATION OK POWER BALANCE AND INJECTOR BALANCE TEST PASS RETEST
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 11 1H03 030008 4C3Z 9F452 A D21 42 13706
AWS Claim Key: 5704187 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 09916 - * Name: LARRY HILL FORD, INC. Ph: 423-4725454 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2005 Doc #:118685A
Cust Comments: REPEATEDLY STALLING
Tech Comments: TEST EEC IV DIAG WITH NGS PERFORM PINPOINT TEST INSTALL PID MONITOR COE P0401 REPLACE EGR VALVE RETEST ROAD TEST
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 16 1H03 030008 4C3Z 9F452 A D50 42 23876
AWS Claim Key: 7661775 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 00387 - * Name: MARSHAL MIZE FORD, INC. Ph: 423-8752023 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2005 Doc #:414634A
Cust Comments: CK WHY BLOWING CAC HOSE OFF AND RUNNING SLUGGISH
Tech Comments: 23876 9F452 42 N CMDTC P0401 P0478 WP ROAD TEST VISUAL INSPECTION PERFORME THE PERFORMANCE DIAG SHEET EEC TEST CMDTC P0401 & P0478 PINPOINT TEST REPLACE THE EGR VALVE & CURVED BLUE CAC HOSE PROGRAM THE PCM TO THE LATEST UPDATE CLEAR ALL DTC ROAD TEST & RECHECK
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 17 2E03 030008 4C3Z 9A543 AARM D21 42 27720
AWS Claim Key: 8232021 Trx Code: E84 Labor Hrs: 21.8
Dlr Cd-Sub Cd: 00387 - * Name: MARSHAL MIZE FORD, INC. Ph: 423-8752023 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:417629A
Cust Comments: TOWED IN DIED AND WILL NOT RESTART
Tech Comments: 27720 9T288 01 9C968 49 9A543 D8 WP INSTALLED WDS PERFORMED PERFORMANCE DIAGNOSTICS CODES P0336,0340,0402,2285,&2623. PERFORMED PPT PERFORMED BASE ENGINE OIL PRESSU RE TEST OK PERFORMED HIGH PRESSURE LEAK TEST CAN HEAR AIR IN BOTH VALVE COVERS REMOVE BOTH OIL RAILS AND INSPECT ALL INJECTORS FOR TOPS BLOWN APART ALL INJECTORS OK REASSEMBLE AND RE TEST FOR LEAKS SOUNDS LIKE AT
1FTSX31P54ED08856 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 18-APR-2004 19-AUG-2004 121687 USA 17 * * * * * * * 27720
AWS Claim Key: 8232024 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00387 - * Name: MARSHAL MIZE FORD, INC. Ph: 423-8752023 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:417629D
Cust Comments: RECALL 59B01
Tech Comments: 27720 RECALL WP PERFORMED CUSTOMER ASSURANCE TEST DRIVE TO VERIFY REPAIR
AWS Claim Key: 8232022 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00387 - * Name: MARSHAL MIZE FORD, INC. Ph: 423-8752023 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:417629B
Cust Comments: RECALL 05S34
Tech Comments: 27720 RECALL WP PERFORMED RECALL PER INSPECTION INSTALL FICM REPAIR KIT AND ICP CONNECTOR
AWS Claim Key: 8232023 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00387 - * Name: MARSHAL MIZE FORD, INC. Ph: 423-8752023 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:417629C
Cust Comments: RECALL 05E15
Tech Comments: 27720 RECALL WP PERFORMED EBP SENSOR REPLACEMENT AND CONNECTOR REPLACEMENT AND RECALIBRATE MODULES
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
bubbagump (08-18-2010)
