oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by survivorjr87, this thread has received 1 replies and been viewed 577 times.
post #1 of 2 (permalink) Old 08-20-2010, 12:44 AM Thread Starter
oasis report please
1FTSX20P07EA54165
thank you
survivorjr87 is offline
post #2 of 2 (permalink) Old 08-23-2010, 02:42 PM
Standard Claims List For Model Year 2007
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 4 7B02 140201 * 10346 * C26 42 22155
AWS Claim Key: 1021743 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2007 Doc #:01065251
Cust Comments: CUSTOMER STATES HAD TO JUMP START TRUCK AND HE CHARGED DRIVERS SIDE BATTERY CHECK AND ADVISE
Tech Comments: LOAD TEST BOTH BATTERYA ND CHARGED BOTH TEST GOOD, CHECK CHARGING SYSTEM AT 13.65 VOLTS.
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 5 7S22 180106 6C3Z 14A068 AC L26 X2 33607
AWS Claim Key: 1196823 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2007 Doc #:01126852
Cust Comments: CUSTOMER STATES RUNNING LIGHTS ON TRAILER INTERMITTANLY DO NOT WORK, WHEN TAPPING FUSE PANLE LIGHTS COME BACK ON CHECK AND ADVISE
Tech Comments: INSPECTED AND FOUND LOOSE CONECTION IN FUSE PANEL TO TRAILER LIGHT CIRCUIT..
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 7 1H03 030008 5C3Z 9F452 AA D42 41 51482
AWS Claim Key: 1447810 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2007 Doc #:01196551
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT CAME ON WHEN TRUCK WAS UNDER A LOAD LIGHT IS NOW OFF CHECK AND ADVISE.
Tech Comments: PREFORMED KOER AND FOUND CODE P0404 FOR EGR VAVLE. PREFOMRED PIN POINT TESTED AND FOUND EGR VAVLE VOLTAGE OUT OF SPEC..
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 10 2H01 030407 5C3Z 6K682 CARM D42 42 83800
AWS Claim Key: 2147642 Trx Code: S07 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-MAR-2008 Doc #:01355651
Cust Comments: CUSTOMER STATES CHECK ENG LIGHT ON, LOSS OF POWER AT ACCILERATION, CHECK AND ADVISE
Tech Comments: INSPECTED AND FOUND ENGINE MISSING WHEN COLD, AND FOUND HAS NO BOOST. INSPECTED AND FOUND LATER UPDATE AND FOUND TURBO FINES WELDED TO TURBO CAUSEING THE VANS NOT TO MOVE.
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 11 1H03 030008 5C3Z 9F452 AA D42 55 91460
AWS Claim Key: 2314522 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2008 Doc #:01397551
Cust Comments: CUSTOMER STATES LACK OF POWER, SMOKING
Tech Comments: PREFOMRED KOER AND FOUND CODE P0404 FOR EGR FLOW, PREFOMRED PIN POINT TEST AND FOUND EGR VAVLE STICKING.
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 12 1H03 030008 5C3Z 9F452 AA D42 42 96059
AWS Claim Key: 2483191 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08340 - * Name: STANLEY FORD - CHILDRESS Ph: 940-9370700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2008 Doc #:0212671
Cust Comments: C/S VEHICLE IS LOSING POWER AND BLOWING BLACK SMOKE
Tech Comments: REPL THE EGR PER TSB 07 21 09
1FTSX20P07EA54165 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-JUN-2006 24-MAY-2007 172421 USA 12 1H03 030804 4C3Z 9P456 AF L87 D8 101812
AWS Claim Key: 2600105 Trx Code: P98 Labor Hrs: 10
Dlr Cd-Sub Cd: 09511 - * Name: VISALIA FORD Ph: 559-6251000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2008 Doc #:01449651
Cust Comments: CUSTOMER STATES HAD EGR VALVE REPLACED IN TEXAS AND NOW LOSING COOLANT BUT NOT SEEING IT ON THE GROUND CHECK AND ADVISE
Tech Comments: PRESSER TESTED AND FOUND COOLANT LEAKING FROM EGR COOLER.
00f3fiddy is offline
Oasis Report Please F3600 Ford Oasis requests 7 01-18-2009 09:14 PM
Oasis Report Please! merlin5577 Ford Oasis requests 4 01-17-2009 08:39 PM
Oasis Report Please... Southtexas Ford Oasis requests 7 01-17-2009 08:34 PM
Oasis report please Bullett1 Ford Oasis requests 4 03-26-2007 05:50 AM
Oasis report please imported_gratcliffe Ford Oasis requests 2 03-02-2007 12:54 PM
