Need Oasis report 2005 F350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by daston, this thread has received 3 replies and been viewed 1473 times.
post #1 of 4 (permalink) Old 08-23-2010, 10:41 PM Thread Starter
The vin is 1FTWW31P65EC30268 and thank you for your help.
daston is offline
post #2 of 4 (permalink) Old 08-25-2010, 07:35 PM
Standard Claims List For Model Year 2005
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 9 5T03 110402 5C3Z 7210 BAA P51 28 6069
AWS Claim Key: 3050698 Trx Code: 2 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD LINCOLN MERCURY Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2006 Doc #:31393301
Cust Comments: CUSTOMER STATES TOW HAUL WONT DISENGAGE,CHECK AND ADVISE.
Tech Comments: FOUND SHIFTER WIRE S OPEN CIRCUIT. R&R SHIFTER AND RECHECK. ALL CHECK OKAT THIS TIME.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 9 7W15 011902 3F2Z 15K859 BA A85 42 6069
AWS Claim Key: 3050697 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD LINCOLN MERCURY Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2006 Doc #:31393302
Cust Comments: CUSTOMER STATES PARK AID WONT ENGAGE IN REVERSE.CHECK AND ADVISE.
Tech Comments: FOUND BACK UP SENSOR INOP. DTC 1700 R&R BACK UP SENSOR AND RECHECK OK AT THIS TIME.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 18 * * * * * * * 10849
AWS Claim Key: 5988617 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD LINCOLN MERCURY Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2006 Doc #:063816D
Cust Comments: RECALL 05B32
Tech Comments: TECH ROAD TEST ASSURANCE
AWS Claim Key: 5988616 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD LINCOLN MERCURY Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2006 Doc #:063816C
Cust Comments: RECALL 05E16
Tech Comments: WE PERFORME RECAL OF PCM AND ROAD TEST
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 20 2H02 030008 * 6F089 * E29 42 11575
AWS Claim Key: 6370960 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD LINCOLN MERCURY Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2006 Doc #:066433A
Cust Comments: CUST STATES SERVICE ENGINE SOON LIGHT IS ON.
Tech Comments: VERIFIED.FOUND CODE P0299.RAN OASIS FOUND TSB 06 23 02.REPLACED TURBO PER TSB CLEARED CODE.RECHECK OK
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 47 7N02 011105 6C3Z 7823394 AA G07 42 35580
AWS Claim Key: 10775710 Trx Code: 0701D Labor Hrs: 1
Dlr Cd-Sub Cd: 09134 - * Name: GILROY FORD LINCOLN MERCURY Ph: 408-8471111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2009 Doc #:125362A
Cust Comments: REAR SLIDER IS INOP
Tech Comments: VERIFIED CONCERN.FOUND CABLE BOUND,MOTOR FAILED.INSTALL NEW REAR SLIDING WINDOW ASSEM.OK
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 54 2H01 030407 5C3Z 9G489 AARM E29 49 45626
AWS Claim Key: 11177757 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2009 Doc #:192551A
Cust Comments: CHECK AND REPORT ON CHECK ENGIEN LIGHT ON
Tech Comments: ENGINE LIGHT ON STEADY. HOOK UP IDS AND PERFORM SELF TESTS. KOEO PASSS, CONT P0299 TURBO BOOST. FIND TSB 09 12 2. BEGIN DIAG AS PER PCED PPT KA PER TSB. PPT KA 1 5. IDS BASED EGR TEST, PASS. VVT TEST, ERRATIC VGT OP. REMOVE TURBO, DISASS, INSP. FOUND UNISON RING GROOVE BADLY WORN & CENTERHSG RUSTY. REPL UNISON RING & CHRA. CLEAN REAR HALF OF TURBO. REASS, REINSTALL. CLEAR CODES.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 55 1B03 030204 3C3Z 6A642 CA E23 55 47402
AWS Claim Key: 11236278 Trx Code: E72 Labor Hrs: 11.3
Dlr Cd-Sub Cd: 04240 - * Name: THE FORD STORE MORGAN HILL Ph: 408-7828201 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2009 Doc #:0403332
Cust Comments: CUST STATES TEMP PEGS TO HOT WHEN HEATERS ON
Tech Comments: CONFIRMED COMPLAINT, PERFORMED INSPECTION AND FOUND COOLING SYSTEM LOW ON COOLANT AROUND 1 AND 1/2 GALLONS. ADDED WATER AND PERFORMED VACUUM TEST AS PER TSB 09 8 3 AND FOUND EGR COOLER ON CAR TEST FAILED. REMOVED EGR COOLER AND PERFORMED PRESSURE TEST FOUND EGR COOLER LEAKING AIR PRESSURE. REPLACED EGR COOLER
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 56 2A01 031202 6C3Z 6C640 A L65 D8 48337
AWS Claim Key: 11284043 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2009 Doc #:193762A
Cust Comments: CHECK AND REPORT ON OIL LEAKING FROM CAB
Tech Comments: 48344 INSPECT LEACKAGE AT CAC CONNECTION AT TURBO, PARTS REQUEST. REPLACED SMALL CAC TUBE, STEAM CLEANED.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 56 1B02 030401 3C3Z 9C065 AA E41 D8 48337
AWS Claim Key: 11284044 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2009 Doc #:193762B
Cust Comments: CHECK AND REPORT ON EXHAUST LEAK INTO CAB
Tech Comments: 48344 INSPECT FOR EXHAUST LEAKS, OK, INSPECT FOUND FUEL PRESSURE REGULATOR LEAKING, TEST DROVE FOR EXHAUST SMELL OK, PARTS REQUEST FOR REGULATOR SEAL. REPLACED REGULATOR SEAL, RECHECKED OK.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 60 2E01 03XXXX * 9B246 * D02 42 53214
AWS Claim Key: 11426513 Trx Code: E72 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2010 Doc #:196192B
Cust Comments: CHECK AND REPORT ON CRANK NO START
Tech Comments: 04C PERFORM NO START DIAG PERFORM VISUAL INSP CK ENG OIL LVL INT EXH REST PASS SUFFICIENT CLEAN FUEL PASS FUEL SYS DEL PASS ELECT FUEL PUMP INLET REST PASS, NO CODES. DATA LIST, 300 PSI OF ICP. HIGH PSI OIL SYS AIR PSI CK, NO CHANGE, REPL IPR. NOW HEAR CHANGE AT VLV CVRS. REMOVE BOTH VLV CVRS, INSP, FOUND DUMMY PORTS WITH DAMAGE O RINGS INSTALL NEW PORT PLUGS. RECHECK. ROAD TEST.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 64 5Q02 110203 5C3Z 3A717 CA L63 D8 58594
AWS Claim Key: 11564537 Trx Code: 0968D Labor Hrs: 2
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2010 Doc #:198806A
Cust Comments: CHECK AND REPORT ON BRAKE FLUILD LEAK.IT LOOKS LIKE ITS LEAKING ON THE DRIVER SIDE FRONT.
Tech Comments: 58594 INSPECTED CONCERN FOUND LEAKING P S HOSE , REMOVED AND REPLACED HOSE CLEAN AREA, ADDED FLUID AND RECHECKED TO VERIFY REPAIRS
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 65 5Q02 110203 5C3Z 3A717 CA L68 42 59356
AWS Claim Key: 11560836 Trx Code: SPW Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04240 - * Name: THE FORD STORE MORGAN HILL Ph: 408-7828201 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2010 Doc #:0477902
Cust Comments: P/S HOSE JUST INSTALLED LEAKING AT FITTING
Tech Comments: PRESSURE HOSE STARTED TO LEAK FROM THE FITTING ,PERFORMED SPW AND REPLACED THE P/S PRESSURE HOSE ADDED FLUID AND ROADTESTED CONCERN FIXED
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 65 5I01 110204 5C3Z 3A674 BRM H22 42 59356
AWS Claim Key: 11560835 Trx Code: 0968D Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04240 - * Name: THE FORD STORE MORGAN HILL Ph: 408-7828201 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2010 Doc #:0477901
Cust Comments: LOST BRAKES AND POWER STEERING
Tech Comments: VERIFIED P/S PUMP CREATED EXCESS PRESSURE CAUSING THE P/S PRESSURE HOSE TO LEAK FLUID FROM THE P/S PUMP SIDE FITTING,INSTALLED P/S PUMP AND REPLACED THE P/S PRESSURE HOSE,RAODTESTED
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 65 5N01 110101 BC3Z 3A131 B N23 30 59493
AWS Claim Key: 11572598 Trx Code: 0968D Labor Hrs: 3.7
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2010 Doc #:199381A
Cust Comments: CHECK AND REPORT WHEN THE CUSTOMER HITS A SPEED BUMP THE STEERING WHEEL SHAKES REALLY BAD.
Tech Comments: 59493 ROAD TEST AND COFIRN PROBLEM, CHECK OUT FRONT END, FOUND LONG & SHORT DRAG LINK WORN AND STEERING DAMPER LEAKING AND TRACK BAR BALL JOINT WORN, DROP P&A. R R TRACK BAR BALL JOINT AND R R LONG & SHORT DRAG LINK AND R R STEERING DAMPER, ROAD TEST VEH, VEH DRIVE OK, NO MORE VIBRATION WHEN HIT BU,MP AT THIS TIME, SET CLEAR VISION.
1FTWW31P65EC30268 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-FEB-2005 17-APR-2005 172403 USA 65 5Q02 110203 5C3Z 3A717 CA L68 D8 59610
AWS Claim Key: 11584510 Trx Code: SPW Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2010 Doc #:199531A
Cust Comments: CHECK AND REPORT ON POWER STEERING LEAK.
Tech Comments: 59610 CONFIRM P S STEERING LEAK AT HIGH PRESSURE HOSE FROM P S PUMP TO HYDRO BOOSTER,ONE OF ORING PUSH OUT, CANT SERVICE BY REPLACE FITTING, R R P S RESSURE HOSE AND BLEED P S STEERING SYSTEM AND STEAM CLEAN VEH FOR A LONG TIME, DUE TO P S FLUID LEAK EVERY OF ENGINE, ROAD TEST VEH, VEH STEER OK AND RECHECK FOR LEAK, NO SINCE OF LEAK.
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
daston (08-25-2010)
post #3 of 4 (permalink) Old 08-25-2010, 08:12 PM Thread Starter
thank you very much....I knew it smelled like a lemon.
daston is offline
post #4 of 4 (permalink) Old 08-25-2011, 10:55 PM
Hey dont know if you are still able to get an oasis report but thought it would be worth a shot. Ive narrowed my search down to these two f250's and was hoping you could run the vin's thanks.
3FTNX21F61MA08473
1FTSX21P56EC32004
6.0 vs 7.3?? is offline
Oasis Report, 2001 F350 mp_soldier Ford Oasis requests 1 01-06-2008 01:40 AM
OASIS Report Please - 2005 F-250 05Powerstroker Ford Oasis requests 1 01-06-2008 01:39 AM
Oasis Report 99 F350 Buicksx2 Ford Oasis requests 1 01-06-2008 01:34 AM
oasis report ford f350 glennhaefner Ford Oasis requests 2 01-06-2008 12:48 AM
Oasis Report for 2005 King Ranch Please Ken1 Ford Oasis requests 2 09-12-2006 12:10 PM
