I need a oasis report please and thanks!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hemiman, this thread has received 2 replies and been viewed 467 times.
post #1 of 3 (permalink) Old 08-28-2010, 02:34 PM Thread Starter
1FTWW33P74EA11119
Thanks to the source! I need to know what was done to my 6.0
hemiman is offline
post #2 of 3 (permalink) Old 08-30-2010, 04:15 PM
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
00f3fiddy is offline
post #3 of 3 (permalink) Old 08-30-2010, 04:16 PM
Standard Claims List For Model Year 2004
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 8 2E05 100106 3C3Z 9B249 AB G29 28 18163
AWS Claim Key: 757652 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2004 Doc #:02625601
Cust Comments: WATER IN FUEL LIGHT ON
Tech Comments: VERIFIED CONCERN. DRAINED SYSTEM AND LIGHT WOULD NOT GO OUT. WDS TESTED PIN POINT TESTED AND FOUND SHORT IN FUEL MANIFOLD REPLACED FUEL WATER SEPARATOR MANIFOLD
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 8 5A09 050201 1C3Z 4676 AA L88 D8 20216
AWS Claim Key: 1086342 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-MAY-2004 Doc #:02655301
Cust Comments: CHECK LEAK AT REAR AXLE
Tech Comments: VERIFIED CONCERN. FOUND PINION SEAL LEAKING REPLACED PINION SEAL
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 16 2H01 030008 3C3Z 6K854 DA E41 01 50694
AWS Claim Key: 3969044 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2005 Doc #:03018803
Cust Comments: CUSTOMER STATES THAT THEY CAN SMELL DIESEL FUMES IN THE CABIN AND THEY ARE REAL BAD OUTSIDE OF VEHICLE. CK AND ADV.
Tech Comments: VERIFIED CONCERN. PIPE COMING OFF OF REAR OF TURBO AND EXHAU ST PIPES LEAKING FUMES. PIPE CRACKED. NECESSARY TO REMOVE TURBO TO REPLACE EXHAUST PIPE. M TIME FOR NO LOP.
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 16 2E05 100106 3C3Z 9B249 AB G29 28 50694
AWS Claim Key: 3969045 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2005 Doc #:03018801
Cust Comments: CUSTOMER STATES THAT THE WATER IN FUEL LIGHT KEEPS COMING ON. PLEASE CHECK HISTORY AND ADVISE.
Tech Comments: PERFORMED ELECTRICAL TEST, PERFORMED PPT, FOUND HEATER MODUL E SHORTED. REPLACED HEATER MODULE.
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 18 4B03 080203 3C3Z 7C522 CC P01 63 56984
AWS Claim Key: 4228052 Trx Code: P05 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2005 Doc #:03087401
Cust Comments: CUSTOMER STATES THE CLUTCH IS SLIPPING. PLEASE CHECK AND ADVISE.
Tech Comments: PERFORMED CLUTCH OPERATION DIAGNOSIS. FOUND MASTER CYLINDER BYPASSING NOT ALLOWING CLUTCH TO RELEASE PROPERLY. REPLACED MASTER CYLINDER ASSEMBLY. AFTER INSTALLATION CLUTCH WAS SLIPPING BAD, REMOVED TRANS FOR INSPECTION AND FOUND CLUTCH DISCFLUID SOAKED AND PRESURE PLATE BADLY HOT SPOTTED. REPLACED ALL NECESSARY PARTS.
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 19 2E03 03XXXX 4C3Z 12B599 AARM D02 42 61154
AWS Claim Key: 4774619 Trx Code: E72 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2005 Doc #:03122802
Cust Comments: CUSTOMER STATES ENGINE WONT START CUSTOMER HAD VEHICLE TOWED IN. ENGINE STARTS NOW. CK AND ADV
Tech Comments: VERIFIED CUSTOMERS CONCERN. PERFORMED DIAGNOSTICS, RETRIEVED CODES U0105. RUN OIN POINT TESTS. PERFORMED TSB 041806. CHECKED WIRING FOR CHAFING. NO CHAFING FOUND. FUEL INJECTOR CONTROL MODULE IS SHORTED. REPLACED FICM AND REPROGRAMMED
1FTWW33P74EA11119 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 18-JUL-2003 22-SEP-2003 152771 USA 24 2E03 03XXXX 3C3Z 9C968 AA E29 42 84452
AWS Claim Key: 6784101 Trx Code: E72 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 07476 - * Name: ULTIMATE FORD GIDDINGS Ph: 979-5423171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2005 Doc #:03237701
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON ENGINE ACCELERATES ON ITS OWN AT TIMES, DIES AND RESTARTS.
Tech Comments: VERIFIED CUSTOMERS CONCERN. PERFORMED DIAGNOSTICS PER DIAG SHEET 1 12B. FOUND ICP PRESSURE TOO LOW. REMOVED AND REPLACED INJECTOR REGULATOR. INSPECTED INJECTOR PRESSURE SENSOR AND FOUND IT TO BE LEAKING OIL. REPLACED
OASIS Report on 97 F-250 ejpowerstroke97 Ford Oasis requests 1 01-06-2008 01:35 AM
Oasis report please liftruck Ford Oasis requests 1 12-04-2007 12:24 PM
Oasis Report please goodriddance Ford Oasis requests 2 11-10-2006 10:29 AM
Oasis report please imported_dbric36 Ford Oasis requests 1 11-01-2006 09:37 PM
oasis report please woody367 Ford Oasis requests 2 10-30-2006 05:50 AM
