Just another Oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super_Crew_Cab, this thread has received 1 replies and been viewed 544 times.
post #1 of 2 (permalink) Old 08-28-2010, 07:57 PM Thread Starter
Super_Crew_Cab's Avatar
1FTSW21P76EA73022
Super_Crew_Cab is offline
post #2 of 2 (permalink) Old 08-30-2010, 04:30 PM
Standard Claims List For Model Year 2006
1FTSW21P76EA73022 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JUL-2005 06-SEP-2005 121680 USA 8 5K04 * * * * * * 17817
AWS Claim Key: 965928 Trx Code: 05B34 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:203418B
Cust Comments: 05B34 TIRE INSPECTION AND REPLACEMENT
Tech Comments: COMPLETED TIRES DO NOT FALL UNDER REPLACEMENT DOT NUM
1FTSW21P76EA73022 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JUL-2005 06-SEP-2005 121680 USA 8 * * * * * * * 17817
AWS Claim Key: 800063 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:203418A
Cust Comments: 05E16, CONTROL MODULE RECALIBRATION
Tech Comments: 17817 RECALL 05E16 COMPLETED
1FTSW21P76EA73022 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JUL-2005 06-SEP-2005 121680 USA 43 1A02 030102 * 6051 * D50 42 77479
AWS Claim Key: 7992539 Trx Code: E72 Labor Hrs: 9.3
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2009 Doc #:063161A
Cust Comments: CUST STATES VEH STARTED PUFFING SMOKE OUT WHEN AT IDLE, GOT WORSE,STARTED IDLING RUNNING ROUGH
Tech Comments: 77495 TEST DROVE VERFIED CONCERN, CHECKED COOLANT LEVEL LOW, PERFORMED TSB 08 11 03 PULLED CODES P0404, P0401, CHECKED EOT AND ECT HOT 4 DEG DIFF, REMOVED EGR VAVLE AND FOUND COOLANT IN INTAKE PRESSURE TEST EGR COOLER FAILED, REPLACED EGR COOLER, EGR VALVE, DEGAS BOTTLE, CAP, AND INSTALLED EGR BAFFLE, CLEARED CODES, FLUSHED RETEST DROVE OK 08 11 03A,B,C
1FTSW21P76EA73022 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-JUL-2005 06-SEP-2005 121680 USA 55 2E03 031403 4C3Z 12B599 ABRM D03 42 99487
AWS Claim Key: 8977526 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2010 Doc #:076167A
Cust Comments: CUST STATES THE ENGINE IS HARD TO START WHEN COLD, CUST PARKS IN GARAGE. IF PARK OUTSIDE MUCH WORSE
Tech Comments: VISUAL OK, OIL OK, EXHAUST OK, FUEL OK, FUEL PRESURE 51, 56, 0, 0 KOEO P0611, CONTINUOUS DTC P0611, INJECTOR SELF TEST P0611PID MONTOR LIST ALL OK, FOUND FICM NOT FIREING ALL INJECTORS REPLACED FICM AND REPROGRAMED PCM, FICM AND TCM TEST DROVE OK
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
Super_Crew_Cab (08-30-2010)
Oasis Request Thanks dieselram55 Ford Oasis requests 1 02-28-2008 01:02 AM
Oasis request jjcar Ford Oasis requests 1 02-02-2008 02:54 AM
OASIS Request gwh Ford Oasis requests 2 01-09-2007 09:18 PM
OASIS Request slow5liter Ford Oasis requests 1 01-03-2007 02:19 AM
Oasis request POWER STROKE 99 Ford Oasis requests 1 01-03-2007 01:56 AM
