Oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by poolman800, this thread has received 2 replies and been viewed 555 times.
post #1 of 3 (permalink) Old 08-29-2010, 11:33 AM Thread Starter
Oasis report please
3FTNW21F22MA04182. Thank you! Owe you a case of your favorite beverage!
poolman800 is offline
post #2 of 3 (permalink) Old 08-30-2010, 04:27 PM
Standard Claims List For Model Year 2002
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 11 7H01 120301 * 19703 * C02 42 665
AWS Claim Key: 2256842 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02453 - * Name: JOHNSON BROTHERS FORD LINCOLN MERCURY Ph: 254-7735258 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2002 Doc #:13987901
Cust Comments: OWNER REPORTS AC NOT VERY COLD ON WARM AFTERNOONS
Tech Comments: CC 53 AIR IN A C SYSTEM PERFORM A C PERF. DIAG. AND MEASURED HIGH & LOW SUDE PRESS URES, PERFORM LEAK DETECTOR TEST AND FOUND NO SIGNS OF
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 14 6L17 011202 2C3Z 25519A70 AAC T90 01 17830
AWS Claim Key: 3331281 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2002 Doc #:13531601
Cust Comments: CUST STATES OVERHEAD CONSOLE DOOR BROKEN
Tech Comments: SUNGLASSES DOOR BROKEN REPLACED OVERHEAD CONSOLE
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 16 7G03 120202 F81Z 18471 BA N58 42 21423
AWS Claim Key: 4301703 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2003 Doc #:13681902
Cust Comments: CUST STATES WHILE BACKING UP AND TURNING IT MAKES A POPPING NOISE
Tech Comments: NVH DIAG UNABLE TO VERIFY AT THIS TIME
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 16 5C02 050101 F81Z 4R602 HGE P67 42 21423
AWS Claim Key: 4301704 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2003 Doc #:13681901
Cust Comments: CUST STATES CHECK TRANS FOR SLIPPING
Tech Comments: ELEC TRANS DIAG PINPOINT TEST FOUND DRIVELINE SHUDDER UNDER HARD ACCEL CUSTOMER DECLINED REPAIR
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 54 2G02 0300XX F7TZ 12K073 A D21 42 76046
AWS Claim Key: 14989293 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01472 - * Name: GULLO FORD-MERCURY OF CONROE Ph: 936-7565500 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2006 Doc #:531185A
Cust Comments: ENGINE DIES WHILE DRIVING
Tech Comments: 76046 SENSOR FAILURE 6005F.2F1.1F1X1.1F2.1F18.5,12650D60.2 DIAG TEST CODES P0340,CLEAR AND RETESTED, VERIF Y FUEL PRESSURES,DURING TEST ENGINE DIED RETEST P0340,P0344. REPLACE CMP SENSOR, CLEAR CODES AND RETEST.
3FTNW21F22MA04182 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 21-AUG-2001 27-SEP-2001 152777 USA 105 * * * * * * * 162555
AWS Claim Key: 17815596 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2010 Doc #:067927B
Cust Comments: RECALL 07S57
Tech Comments: 162556 RECALL 30 PERFORMED 07S57 RECALL. INSPECTED THE CMP SENSOR AND FOUND IT TO BE OF THE OLD STYLE. REPLACED THE CMP SENSOR W A NEW REVISED SENSOR AS PER RECALL. ALL OK NOW. 07S57B .3
AWS Claim Key: 17815597 Trx Code: 09S09 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2010 Doc #:067927C
Cust Comments: PERFORM RECALL 09S09
Tech Comments: 162556 RECALL 30 PERFORMED 09S09 RECALL. INSPECTED THE CRUISE SWITCH AND FOUND IT TO BE LEAKING. REPLACED THE SWITCH W A NEW REVISED SWITCH AND JUMPER HARNESS KIT AS PER RECALL. ALL OK NOW. 09S09D .3
Bud Light. I'll Pm you my address. hahaha
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
poolman800 (08-31-2010)
post #3 of 3 (permalink) Old 08-31-2010, 03:39 AM Thread Starter
THANK YOU!!!
PM your address bro and Bud Light will be on its way! Looks like I'll need your services again. Had TWO '02 F250's with deposits placed before I could get to them, so totally frustrated. Thanks again!!!
Oasis report please liftruck Ford Oasis requests 1 12-04-2007 12:24 PM
can i get an oasis report please 86 1 tonhauler Ford Oasis requests 1 11-10-2006 02:13 AM
oasis report please flycut Ford Oasis requests 1 11-01-2006 09:40 PM
Oasis report please imported_dbric36 Ford Oasis requests 1 11-01-2006 09:37 PM
oasis report please woody367 Ford Oasis requests 2 10-30-2006 05:50 AM
