Thinking about buying this truck, OASIS Please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SickStroke6.0, this thread has received 4 replies and been viewed 848 times.
post #1 of 5 (permalink) Old 08-31-2010, 09:46 PM Thread Starter
SickStroke6.0's Avatar
VIN # 1FTSW21PX5EC62813
Thanks!
Blake
2003 Ford F-250 6.0l Powerstroke CC SB Lariat FX4
Engine-ARP Studs, RCD EGR Delete, 4" MBRP Exhaust, SCT Tuned by Innovative
Exterior-2.5" Leveling Kit, 18" XD Badlands, 325/60/18 Nitto Terra Grapplers
Interior-Edge Insight w/EGT
WTB: 6.0L Injector Cores
SickStroke6.0 is offline
post #2 of 5 (permalink) Old 09-01-2010, 06:39 PM
WARNING MESSAGES
BRANDED TITLE - ALL WARRANTY CANCELLED
00f3fiddy is offline
post #3 of 5 (permalink) Old 09-01-2010, 06:41 PM
the warranty history is down untill Saturday for month end.
post #4 of 5 (permalink) Old 09-05-2010, 02:35 AM Thread Starter
Alright, thanks man! Update me when you can.
Blake
post #5 of 5 (permalink) Old 09-07-2010, 03:24 PM
Standard Claims List For Model Year 2005
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 9 2C01 030603 3C3Z 11002 AA D02 42 16899
AWS Claim Key: 3526133 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:51410301
Cust Comments: PERFORM SERVICE PER BODY SHOP REQUEST CUST STS NO CRANK NO START
Tech Comments: DEFECTIVE STARTER ASSY CC 46 ADDRESS CONCERN DIAG PERFORM ELEC SYSTEM TEST & STARTER TEST REPLACE STARTER ASSY TEST DRIVE,WATER IN FUEL LIGHT WAS ON, DRAINED SEPERATOR,LIGHT STILL ON HAD TO REPLACE MODULE ASSY. RETEST OK
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 10 7K11 130101 6C3Z 10849 EC L69 42 10291
AWS Claim Key: 4241856 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2006 Doc #:51714501
Cust Comments: CUST STS LOW FUEL DISPLAYED WONT RUN
Tech Comments: STICHING 9275 SENDER, INACCURATE ICM 10849 ENGINE RAN OUT OF FUEL. PUSH TRK. INTO SHOP PRECHECKS FOUND NO FUEL IN FUEL TANK GAUGE READING 1 8 TANK 13%, ADDED 5 GALLONS FUEL NO MOVEMENT OF GAUGE, REMOVE FUEL TANK SENDER FOUND TO BE STICKING, REPL. SENDER , FUEL GAUGE NOW READS 37% GAUGE INACCURATE, REPL. ICM GAUGE READS CORRECT, NEC. TO PRIME FUEL SYSTEM TO GET ENGINE RUNNUNG,VERIFY60. REQUEST M
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 19 5O01 110201 6C3Z 3504 A N58 42 20967
AWS Claim Key: 6479769 Trx Code: E84 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 03938 - * Name: JACKY JONES FORD LINCOLN MERCURY, INC. Ph: 423-3375066 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:118035A
Cust Comments: CHECK NOISE IN STEERING WHEN TURNING
Tech Comments: REPLACE STEERING GEAR AND POWER STEERING PUMP
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 19 * * * * * * * 20967
AWS Claim Key: 6479770 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03938 - * Name: JACKY JONES FORD LINCOLN MERCURY, INC. Ph: 423-3375066 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:118035C
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 22 2E01 03XXXX 4C3Z 9B246 A D03 42 28354
AWS Claim Key: 7303234 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 03938 - * Name: JACKY JONES FORD LINCOLN MERCURY, INC. Ph: 423-3375066 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2007 Doc #:120545B
Cust Comments: C/S AFTER DRIVE FOR AWHILE, HARD TO START AFTER WARMED UP
Tech Comments: PERFORM TSB 061706
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 22 7Q01 110601 5C3Z 9C888 AAA A25 28 28354
AWS Claim Key: 7303235 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03938 - * Name: JACKY JONES FORD LINCOLN MERCURY, INC. Ph: 423-3375066 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2007 Doc #:120545C
Cust Comments: C/S CRUISE CONTROL DONT WORK
Tech Comments: REPLACE CRUISE SWITCH
1FTSW21PX5EC62813 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 16-MAY-2005 124461 USA 23 1H03 030804 4C3Z 9P456 AF L87 01 29528
AWS Claim Key: 7426706 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 07269 - * Name: JACKY JONES FORD OF HAYESVILLE, INC. Ph: 828-3896325 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2007 Doc #:09993101
Cust Comments: CUST STATES LEAKING COOLANT THROUGH EXHAUST
Tech Comments: PRESSURE TESTED COOLING SYSTEM REMOVED EGR VALVE COOLANT IN EGR COOLER REMOVED TURBO REMOVED INTAKE MANIFOLD REPLACED EGR COOLER REFILLED WITH COOLANT CHANGED OIL AND FILTER TEST DROVE RAN EEC TEST NO CODES
oasis report please thinking about buying this truck Smokeshow101 Ford Oasis requests 0 07-07-2010 12:02 AM
Thinking of buying, Oasis please? Mustang42 Ford Oasis requests 1 02-20-2008 03:14 AM
oasis request, brother buying truck, thanks. Bendog Ford Oasis requests 4 01-31-2008 04:19 AM
Thinking of buying-Oasis Please Mustang42 Ford Oasis requests 3 09-26-2007 10:25 PM
Thinking of buying a '05 6.0 (first diesel truck) Muskynut 2003-2007 6.0L Power Stroke 23 08-30-2006 01:54 AM
