Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by spedyr6, this thread has received 1 replies and been viewed 402 times.
post #1 of 2 (permalink) Old 09-06-2010, 03:00 AM Thread Starter
Oasis Please
I just introduced myself in the intro forum. In short, bought my first diesel 2 weeks ago and I know nothing about them except from the forums. Its used and I discovered from a car fax that I am the third owner (not including a few dealers). The mileage is low 45k and its in great condition, but I am concerned about any warranty work, recalls (radiator, seat bracket) and these computer updates I have read about. Figured this is a good place to start.
VIN# 1FTSW21R28EB06769
Thank you.
2008 F250 Super Duty 6.4 Auto
spedyr6 is offline
post #2 of 2 (permalink) Old 09-07-2010, 03:35 PM
Standard Claims List For Model Year 2008
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 6 7D07 170202 E6DZ 13466 B L26 42 5851
AWS Claim Key: 335426 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2008 Doc #:32228204
Cust Comments: PASS REVERSE LIGHT IS OUT
Tech Comments: REPLACE BULB
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 9 2G01 031401 * 12A650 * D42 42 10547
AWS Claim Key: 693433 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:15-APR-2008 Doc #:33046401
Cust Comments: ENGINE STARTED BLOWING HEAVY WHITE SMOKE AND ENGINE LOST POWER. NOTICED FUEL MILEAGE HAD DROPPED TO 4MPG. WAS NOT IN REGENERATION MODE. NO WARNING LIGHTS CAME ON. ENGINE WAS RECENTLY START
Tech Comments: TEST ENGINE CONTROLS. REPROGRAM PCM AND RETESTED OK
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 11 2E02 * * * * * * 11622
AWS Claim Key: 1033742 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2008 Doc #:33587002
Cust Comments: CAMPAIGN 08C04 FUEL TANK STOPPER BRACKET INSTALL
Tech Comments: COMPLETE RECALL
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 11 7D07 17XXXX * 13465 * L26 42 11622
AWS Claim Key: 1042359 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2008 Doc #:33587003
Cust Comments: CUSTOMER STATES HIS TRAILER LIGHTS WILL NOT WORK WHEN HOOKED UP TO TRUCK HOWEVER TRAILER LIGHTS WORKED WHEN HOOKED TO OTHER VEHICLES, CUST STATES PROBLM W TRK?
Tech Comments: 06 21 08 CUST STATES HE HOOKED TRLR. UP TO OTHER VEH S THIS WK ND AND LTS WORKED OK BUT NOT ON THIS 08 F250 SD CHECK AND REPLACE FUSE
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 11 6E01 * * * * * * 11622
AWS Claim Key: 1033743 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2008 Doc #:33587001
Cust Comments: CAMPAIGN 08C01 FRONT DRIVERS SEAT BACK INSPECT REPAIR
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 16 2G01 * * * * * * 12675
AWS Claim Key: 1852018 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02901 - * Name: DON MEYER FORD-MERCURY, INC. Ph: 812-6637621 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2008 Doc #:133986A
Cust Comments: CERTAIN 2008 MODEL YEAR F SUPER DUTY VEHICLES EQUIPPED WITH 6.4L ENGINE REPROGRAM THE PCM AND IC
Tech Comments: REPROGRAMMED PER 08B07
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 16 1F01 * * * * * * 12675
AWS Claim Key: 1852019 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02901 - * Name: DON MEYER FORD-MERCURY, INC. Ph: 812-6637621 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2008 Doc #:133986B
Cust Comments: CERTAIN 2008 MODEL YEAR F SUPER DUTY VEHICELS EQUIPPED WITH A 6.4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION
Tech Comments: INSTALLED KIT PER 08B06
1FTSW21R28EB06769 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 24-APR-2007 26-JUL-2007 147136 USA 30 1H03 030804 8C3Z 9D475 D E29 69 40617
AWS Claim Key: 5146665 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 08599 - * Name: TILLAMOOK MOTOR COMPANY Ph: 503-8424475 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2009 Doc #:06587701
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: DIAGNOSED, CODE P1335 PRESENT. PERFORM 6.0L DIAG INCLUDING PINPOINT TEST, LED TO STUCK EGR VALVE. ATTEMPT TO EXTRACT VALVE, SEIZED SOLID INTO HOUSING. HAD TO REPLACE COMPLETE HOUSING. HAD TO REMOVE VERTICAL EGR COOLER FOR ACCESS, REINSTALL COOLER. CLEARED CODES. TEST DROVE, RUNS OK. RECHECK CODES, ALL CLEAR AT THIS TIME.
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
spedyr6 (09-07-2010)
