Oasis report please and thanks! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Thistledog, this thread has received 2 replies and been viewed 681 times.
post #1 of 3 (permalink) Old 09-07-2010, 11:53 AM Thread Starter
2007 F-350, VIN 1FTWW33P17EB18736.
May be too late, I already own it but would like to know what the manufacturer buy-back was for.
Many thanks,
Thistledog is offline
post #2 of 3 (permalink) Old 09-07-2010, 03:39 PM
Standard Claims List For Model Year 2007
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 4 2H01 030407 5C3Z 6K682 A D21 42 7513
AWS Claim Key: 423918 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2007 Doc #:06839751
Cust Comments: ENGINE STALLS WHILE DRIVNG, OCCURED FREEWAY DRIVING
Tech Comments: PERFORM DIESEL ENG PERF DIAG, CK OASIS, DIAG AS PER TSB 06 23 02, REPLACE PITTED TURBOCHARGER AND COOLER, CLEAN CAC HOSES FUEL PRESSURE LOW AT HIGHER RPMS, REPLACE FUEL PUMP, CLEAR DTCS, RETEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 5 2E03 030402 4C3Z 9E527 AA D42 42 9846
AWS Claim Key: 529677 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2007 Doc #:07061151
Cust Comments: VEHICLE RUNS ROUGH, FEELS LIKE TRANS NOT SHIFTING IN LOWER GEARS
Tech Comments: PERFORM DIESEL ENG PERF DIAG, PPT TEST DTC P2266, P2271, REPLACE FAILED INJECTORS ON CYL 1 AND 2, CLEAR DTCS, RETEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 6 7S22 180106 6C3Z 14A068 AC A85 42 14513
AWS Claim Key: 689551 Trx Code: E83 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2007 Doc #:07362451
Cust Comments: C S:PROBLEMS WITH POWER POINT PORT PUT NEW FUSE IN IT STILL DOES NOT WORK ALSO PLEASE CHECK THE CIGAR LIGHTER PORT DIAG CONCERN & ADVISE
Tech Comments: PPT TEST, REPLACE FUSE, STILL INOP, NEC TO REPLACE FAILED FUSE BOX ASSY, RETEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 8 3A06 070101 3C3Z 7A248 AA L73 D8 19609
AWS Claim Key: 895634 Trx Code: E84 Labor Hrs: 6.2
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2007 Doc #:07685451
Cust Comments: CUST STATES VEHICLE LEAKING TRANS FLUID
Tech Comments: OIL DYE TEST, REMOVE TRAANS TO INSPECT, OVERHAUL LEAKING FRONT PUMP, ADD FLUID TO CORRECT LEVEL, ROAD TEST AND REINSPECT OK
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 8 7C01 0109XX 6C3Z 17B676 AA M05 42 19609
AWS Claim Key: 889393 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2007 Doc #:07685452
Cust Comments: CUST STATES DRIVER SIDE OUTSIDE MIRROR ADJUSTMENT INOP. ( SEE MIKE )
Tech Comments: TEST POWER TO MIRROR SWITCH, REPLACE FAILED SWITCH ASSY
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 12 6E01 0110XX * 3863100 * T50 42 30154
AWS Claim Key: 1589442 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2007 Doc #:08679453
Cust Comments: LEATHER IS COMING APART ON THE CENTER CUPHOLDER IN THE REAR SEAT. ( SEE MIKE )
Tech Comments: OUTSIDE LABOR FOR REAR SEAT CONSOLE COVER
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 12 7T03 061003 6C3Z 2C006 AA E40 42 30154
AWS Claim Key: 1589440 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2007 Doc #:08679451
Cust Comments: CUST STATES TRAILER BRAKE CONTROLLER DOES NOT WORK. CUST HAS TO MANUALLY ADJUST.
Tech Comments: TRAILER BRAKE CONTROL MODULE SYSTEM TEST, REPLACE FAULTY TOW MODULE, RETEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 12 5R02 110601 5C7Z 3600 CBA S27 D4 30154
AWS Claim Key: 1589441 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2007 Doc #:08679452
Cust Comments: LEATHER ON THE TOP OF STEERING WHEEL IS FADING AND PEELING
Tech Comments: STEERING WHEEL REMOVE AND INSTALL OR REPLACE
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 13 1A01 030102 6C3Z 6049 A E29 42 33979
AWS Claim Key: 1808506 Trx Code: E84 Labor Hrs: 18
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2008 Doc #:08877351
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: INSPECT, PPT DTCS, PERFORM DIESEL DIAG FOR NO CONTRIBUTION, COMPRESSION TEST, PRESS TEST, FAILED BLOCK TEST, REMOVE CYL HEADS TO REPLACE LEAKING GASKETS, FOUND HEAD WARP AT 1 AND 3 CYL AREA, REPL HEADS, REASSEMBLE, RETEST AFTER REPAIR
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 13 2I04 NANANA YC3Z 12B533 AA E29 42 34304
AWS Claim Key: 1808507 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00123 - * Name: KEN GRODY FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2008 Doc #:08963051
Tech Comments: ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS, DTC P0670, FOUND FAILED GLOW PLUG CONTROL MODULE, REPL, RETEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 18 7D07 17XXXX F4CZ 13466 A L26 46 42601
AWS Claim Key: 2806432 Trx Code: RAV Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04381 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2008 Doc #:81011906
Cust Comments: REPAIR RIGHT BRAKE LIGHT
Tech Comments: REPLACE LIGHT BULB
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 18 2E01 030408 4C3Z 9B246 C D21 42 42601
AWS Claim Key: 2887064 Trx Code: RAV Labor Hrs: 9.9
Dlr Cd-Sub Cd: 04381 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2008 Doc #:81011904
Cust Comments: STALLS QUITS AT CRUISE ALL ENGINE TEMPS
Tech Comments: DTCS P2290, 2291 ICP LOW & WHILE CRANKING. DATA LOGGER, IPR RISES TO 38% BEFORE ENGINE START. PERFORM AIR TEST FOR HIGH PRESSURE OIL SYSTEM, REMOVE VALVE COVERS FOR INSPECTION PER TSB 08 08 09. REMOVED HIGH PRESSURE PUMP. REPLACED SCORED STC FITTING TO BRANCH TUBE. RESTORE & RETEST 21 MILES. EEC TEST P1000
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 18 3A11 070100 * 7003 * L73 42 42601
AWS Claim Key: 2887063 Trx Code: RAV Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04381 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2008 Doc #:81011903
Cust Comments: AUTO TRANS GENERAL LEAKS PAN GASKET
Tech Comments: ADDED TRANS DYE & ROAD TEST. RACK & INSPECTED. NO LEAKS FROM TRANS ATH THIS TIME ENGINE OIL IS BLOWING BACK ONTO TRANS PAN.
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 18 1D05 030008 3C3Z 6020 CA L65 D8 42601
AWS Claim Key: 2806433 Trx Code: RAV Labor Hrs: 7.6
Dlr Cd-Sub Cd: 04381 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2008 Doc #:81011907
Cust Comments: CHECK FOR ENGINE OIL LEAK AS PART OF COMPLAINT OF LINE 3. LEAKING FRONT COVER GASKET
Tech Comments: DYE TEST. FOUND LEAKING FRONT COVER GASKET. REPLACED FRONT COVER GASKET. ROAD TEST. NO FURTHER LEAKS FOUND.
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 18 6Y20 000079 * RAV * A99 82 42601
AWS Claim Key: 2806431 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 04381 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2008 Doc #:81011902
Cust Comments: PERFORM RAV SAFETY INSPECTION
Tech Comments: PERFORM RAV SAFETY INSPECTION
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 20 1D05 031003 * 6020 * L65 D8 42629
AWS Claim Key: 3435228 Trx Code: E72 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 05547 - * Name: HUNTINGTON BEACH FORD Ph: 714-8426611 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2008 Doc #:03533203
Cust Comments: FOUND ENGINE OIL LEAKS. CHECK AND ADVISE.
Tech Comments: C 6020 CC D8 6007D 0.5 6020A 7.1 VERIFIED OIL LEAK CONCERN.ADDED DYE TO SYSTEM.PINPOINTED LEA K TO FRON COVER & WASBLOWING BACK TO PAN AREA.REMOVED COVER ,GASKET NEW & HAS NO SEALANT AT JOINTS CAUSING LEAK.SEALED JOINTS & RE INSTALLED GASKET & COVER.RE TESTED OK.
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 29 2A01 031202 6C3Z 6C640 A N12 34 45496
AWS Claim Key: 4605330 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 20351 - * Name: BOB TURNER'S FORD COUNTRY Ph: 505-7666600 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2009 Doc #:48256301
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON ADVISE HEARD A POP SOUND
Tech Comments: IDS HOOK UP PO299, RAN KOER,KOEO PERFORMANCE DIAG. FOUND CAC HOSE HOT SIDE AT TURBO BLOWN OFF. INSTALLED NEW HOSE AND CLAMP, ROAD TESTED PID MONITOR MGP,VGT FOUND WITHIN SPECS ALL OK AT THIS TIME. PERFORMED VVT TEST
1FTWW33P17EB18736 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-OCT-2006 02-JAN-2007 171089 USA 30 7A01 140101 BXT 65 750 C25 42 46727
AWS Claim Key: 4729754 Trx Code: RAV Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05547 - * Name: HUNTINGTON BEACH FORD Ph: 714-8426611 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2009 Doc #:04742301
Cust Comments: CUSTOMER STATES VEHICLE HAS TO BE JUMP STARTED AFTER SITTING OVER NIGHT. O.K. DURING THE DAY AFTER BEING DRIVEN.ADVISE.
Tech Comments: PASS SIDE BATTERY TEST OK. DRIVERS SIDE BATTER FAILED TEST 0 STATE OF HEALTH AND 260CCA OUT OF 750CCA. ALT. VOLTAGE TEST IN NORMAL OPERATING RANGE. REPLACED DRIVERS SIDE BATTERY.
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
Thistledog (09-07-2010)
post #3 of 3 (permalink) Old 09-07-2010, 03:58 PM Thread Starter
00f3fiddy, you rock! Thank you so much for the quick response, I know it's not your day (or even pay) job so you're doing these lookups for us as a huge courtesy. The dealer here (no names) played stupid and passed me around from one bubba to the next, still no joy.
Thank you again, much appreciated!
oasis report please DETROIT6.0HD Ford Oasis requests 2 06-20-2009 03:36 AM
Oasis Report Please rk963 Ford Oasis requests 2 06-20-2009 12:13 AM
Oasis Report KMan87 Ford Oasis requests 1 06-11-2009 03:52 PM
Need OASIS report please... Emptydata Ford Oasis requests 2 02-10-2008 12:34 AM
oasis report please... BigRedFord Ford Oasis requests 1 06-15-2007 03:30 AM
