Would like to see report on 04 6.0L-Thanx - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MT KingRanch, this thread has received 2 replies and been viewed 707 times.
post #1 of 3 (permalink) Old 09-16-2010, 12:49 AM Thread Starter
MT KingRanch's Avatar
VIN # 1FTSW31P84ED35827
Thanx for your time in advance-Jay
MT KingRanch is offline
post #2 of 3 (permalink) Old 09-16-2010, 01:56 PM
Standard Claims List For Model Year 2004
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 0 5K06 * * * * * * 11
AWS Claim Key: 858357 Trx Code: 04C07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2004 Doc #:392856A
Cust Comments: RECALL 04C07 TIRE INSPECTION.
Tech Comments: INSPECTED ALL 5 TIRES, ALL RANGE LOAD E, INSPECTEDOK
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 4 6D01 011001 3C3Z 3664417 AAA S52 30 2511
AWS Claim Key: 2113745 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2004 Doc #:399639A
Cust Comments: LEFT FRONT SEAT BOTTOM COVER HAS FLAWS
Tech Comments: VERIFIED CONCERN, REMOVED LU FRONT SEAT, LU FRONT SEAT TRIM ASSY, LU FRONT SEAT LOWER ASSY, LU FRONTSEAT UPPER ASSY, REPLACED LU FRONT SEAT COVER, RE INSTALLED PARTS, CHECKS OK
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 12 3A03 * * * * * * 7535
AWS Claim Key: 4777768 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2005 Doc #:412674A
Cust Comments: CUSTOMER STATES RECIEVED RECALL NOTICE #04B24 ON TRANSMISSION.
Tech Comments: 7548 PERFORM RECALL REMOVED TRANNY AND DISASSEMBLE TO INSPECT REVERSE PLANETARY FOUND TO BE OK INSTALL NEW PLANETARY AND REASSEMBLE REINSTALL REFILL AND TEST DRIVE TO VERIFY OPERATION OF TRANNY OK
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 15 * * * * * * * 8188
AWS Claim Key: 6220576 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:419058B
Cust Comments: 59B01 TEST DRIVE
Tech Comments: PERFORMED CUSTOMER ASSURANCE TEST DROVE
AWS Claim Key: 6220575 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:419058A
Cust Comments: CONPLETE RECALL FUEL HARNESS ADAPTOR
Tech Comments: 8188 RECALL 05S34 INSPECTED INJECTOR HARNESS FOR CHAFFING NO CHAFFING FOUND, THEN INSTALLED HARNESS REPAIR KIT TO HARNESS. THEN PUT ICP HARNESS CONNECTOR ON AND REMOVED OLD ICP HARNESS CONNECTOR. START ED UP AND OK
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 17 * * * * * * * 8853
AWS Claim Key: 6927044 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:421662B
Cust Comments: CUSTOMER STATES RECIEVED RECALL NOTICE #59B01 CUSTOMER ONE TIME ASSURANCE TEST DRIVE.
Tech Comments: 8858 ROAD TEST AND CHECK ALL PIDS AND BOOST OK
AWS Claim Key: 6927043 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:421662A
Cust Comments: CUSTOMER STATES RECIEVED RECALL NOTICE #05E15 EXHAUST PRESSURE SENSOR REPLACEMENT.
Tech Comments: 8858 CHECK AND PREFORM RECALL 05E15 REPLACE SENSOR AND WIRE HARNES END REPROGRAM PCM FLIC AND TCM TO 4U7A 12A650 BFG ROAD TEST OK
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 26 2E01 03XXXX 3C3Z 9N693 JA L65 D8 14339
AWS Claim Key: 9692195 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:437863B
Cust Comments: CUSTOMER STATES VEHICLE IS LEAKING FLUIDS.
Tech Comments: 14344 CHECK AND FOUND OIL LEAKING ON R H SIDE OF ENGI CHECK AND REMOVE CAM SENSOR AND REPLACE BOTH O RINGS CLEAN OF PARTS CHECK AND FOUND OIL LEAKING OUT FRONT OF ENGINE CHECK AND REPLACE O RING ON OIL PUMP RELEAVE VALVE CLEAN OF PARTS AND ROAD TEST NO LEAKS
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 26 2H01 030008 4C3Z 6K682 BA N12 42 14339
AWS Claim Key: 9692194 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:437863A
Cust Comments: CUSTOMER STATES VEHICLE HAS A POPPING NOISE THROUGH INTAKE.
Tech Comments: 14344 ROAD TEST, POPING NOISE AND NO POWER RUN ENGINE PREFORMANCE SHEET AND FOUND NO TURBO BOOST LOW 19 PSI CHECK AND FOUND EGR VALVE STUCK OPEN AT TIMES CHECK OASIS AND FOUND SSM 18362 CHECK AND REPLACE EGR VALVE CLEAR CODES AND ROAD TEST NO POWER CHECK NO TURBO BOOST RUN POWER BALANCE PAS RUN RELITIVE COMPRESSION PASS REPROGRAM 4U7A 12A650 BFH REMOVE TURBO AND M TIME CUT OUT TWO
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 36 2E03 030402 4C3Z 9E527 AA D42 42 18964
AWS Claim Key: 11455338 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2007 Doc #:453124A
Cust Comments: CUSTOMER STATES ENGINE RUNS ROUGH AND MISSES
Tech Comments: 18964 INJECTORS RAN COMPUTER TESTS FOUND CODES P0603,PO263,AND P00275. RAN POWER BALANCED AND VERIFIED CONCERN FOUND THAT CYLINDERS 1 AND 5 WERE NOT WORKING CORRECTLY. NEXT RAN A RELATIVE COMPRESSION TEST PASSED. RAN OASIS FOUND THAT CODE P0603 SAID TO REPROGRAM CONTROL MODULES TO LATEST CALIBRATION. REPROGRAMMED PCM,TCM, AND FICM TO LATEST CALIBRATION. NEXT REMOVED RIGHT
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 41 1H03 030008 * 9F452 * D42 55 21275
AWS Claim Key: 12041765 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 09480 - * Name: EIDE FORD-MERCURY-LINCOLN, INC. Ph: 701-2223500 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2007 Doc #:460572A
Cust Comments: CUSOTMER STATES ENGINE SMOKES BLACK AND LOW POWER EXHAUST TEMP GOES HIGH
Tech Comments: 21275 CAC HOSE AND EGR TEST DROVE VERIFIED CONCERN. NO POWER WHEN ACCELERATING. RAN COMPUTER TEST FOUND THAT CODES P0401,P0603 WERE IN MEMORY. RAN OASIS FOR CONCERN. CHECKED PIDS WHEN TEST DRIVING WATCHED BOOST PRESSURE COULD NOT GET PAST 12PSI AND COULD HEAR A AIR LEAK. INSPECTED HOSES FOUND THAT HOT SIDE CAC HOSE WAS TORE REMOVE AND REPLACED HOSE AND RETEST DROVE HAD MORE POWER BUT
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 49 2H02 030407 5C3Z 6F089 BA D50 42 25300
AWS Claim Key: 12624047 Trx Code: E72 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 07969 - * Name: ST. GEORGE FORD LINCOLN MERCURY Ph: 435-6743200 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2008 Doc #:45812801
Cust Comments: CHECK FOR LACK OF POWER
Tech Comments: 6F089 DIAG ENG REPL VGT ACTUATOR
1FTSW31P84ED35827 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-APR-2004 13-MAY-2004 158487 USA 56 1G04 030509 7C3Z 8678 B N11 42 30132
AWS Claim Key: 12970328 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 03214 - * Name: EAGLE COUNTRY FORD Ph: 406-4331810 St:MT Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2008 Doc #:01447901
Cust Comments: CUSTOMER STATES SERPENTINE BELT IDLER MAKING
Tech Comments: NOISE. FOUND SOURCE OF NOISE TO BE FROMIDLER PULLEY, REPLACED IDLER PULLEY, CHECKED FOUND TENSION ERTO BE STICKY/ROUGH, REPLACED TENSIONER, NO NOISE AT THIS TIME
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
MT KingRanch (09-17-2010)
post #3 of 3 (permalink) Old 09-17-2010, 01:47 AM Thread Starter
Thank you for taking the time for me.
Wow, this trucks been in for lots of issues, no wonder he traded at 27k mi. Well, has been running good for me for another 30k. Fingers crossed.
Guess that's why I bought a $1600 extended full power train warranty.
Can I Get a report please Hollywood Ford Oasis requests 1 01-27-2009 09:11 PM
Report Please BozoTheClown Ford Oasis requests 1 02-08-2008 12:46 AM
Report Please pmflaw Ford Oasis requests 1 02-08-2008 12:45 AM
Can I get an report please rhodeisland350 Ford Oasis requests 2 02-07-2008 12:54 PM
oil report imported_fast_and_furious 2003-2007 6.0L Power Stroke 1 04-27-2007 09:30 PM
