Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jstreet, this thread has received 1 replies and been viewed 599 times.
post #1 of 2 (permalink) Old 09-17-2010, 01:31 AM Thread Starter
Oasis Please
1FTSW21P55EA51034
Thanks
J
jstreet is offline
post #2 of 2 (permalink) Old 09-17-2010, 01:29 PM
Standard Claims List For Model Year 2005
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 0 7S02 180102 * 14401 * L26 X2 1486
AWS Claim Key: 110411 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:13-OCT-2004 Doc #:079755A
Cust Comments: REPAIR PASS SIDE HEADLIGHT NOT WORKING
Tech Comments: 2393 WIRE VERIFIED CONCERN FOUND CONNECTOR C270F, WITH WIRE PUSHED OUT REMOVED FUSE BOX BENT PIN BACK , AND RE INSTALLED PIN IN CONNECTOR. WHICH IS CIRCUIT 181, AND IS A DG OG WIRE RETESTED AFTER AND ALL OK 9018
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 8 5U06 120307 4C3Z 2B925 AB C20 42 15674
AWS Claim Key: 1127067 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:09-JUN-2005 Doc #:088918A
Cust Comments: A C ONLY BLOWS FROM WINDOW VENTS
Tech Comments: 25226 DUE COULD NOT VERIFY CONCERN FOUND SSM 18223 ATTATCHED ORDERED REVISED VACUUM MOTOR 9018 REPLACED VACUUM PUMP RETESTED ALL OK. 9005
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 11 7S02 180102 * 14401 * C20 X2 17940
AWS Claim Key: 1560157 Trx Code: E83 Labor Hrs: 1.4
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:10-AUG-2005 Doc #:091422A
Cust Comments: CLIMATE CONTROL NOT WORKING ALSO NO DISPLAY
Tech Comments: 28872 LOOSE CONNECTOR WORKING FINE AT THIS TIME , CHECKED OASIS NOTHING PERTAINING , CHECKED FUSES OK , REMOVED DASH COVER AND INSPECTED CONNECTIONS AND FOUND CONNECTOR C228A WAS NOT CLIPPED IN PLACE RE ASSEMBLED DASH 9011
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 15 1F03 030304 5C3Z 8286 DB L87 42 24978
AWS Claim Key: 2795748 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:08-DEC-2005 Doc #:096240A
Cust Comments: LUBE OIL FILTER CK FLUIDS
Tech Comments: 40199 DUE SERVIVE#1 INSTALL LOWWER RAD HOSE LOWER RAD HOSE WAS CHAFFINHG ON BELT
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 16 2E06 100106 6C3Z 9G282 AA D02 42 27193
AWS Claim Key: 3363666 Trx Code: E84 Labor Hrs: 3.4
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:12-JAN-2006 Doc #:097453A
Cust Comments: ENGINE RUNS POOLY SMOKES BADLY HAS NO POWER
Tech Comments: 43788 FUEL PUMP TRUCK IS RUNNING FINE , EEC TESTED CODE P0404 IN MEMORY , CHECKED AND FOUND EGR BAD NEEDS PART ON PREQ , TET DROVE TRUCH WITH PDS WORKED FINE FOR 10 MINUITES THEN STARTED TO LOOSE POWER , EGR WAS UNHOOKED , GOT BACK IN SHOP AND CHECKED FUEL PRESSURE , ONLY 29 PSI , 45 MIN IS SPEC , CHECKED FUEL FILTERS CLEAN , CHECKED INLET RESTRICTION OK , NEEDS FUEL PUMP ON PREQ
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 16 7H05 120403 6C3Z 19980 AA C20 42 27193
AWS Claim Key: 3363667 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:12-JAN-2006 Doc #:097453B
Cust Comments: REPAIR CLIMATE CONTROL NOT WORKING
Tech Comments: TECH CHECKE DCLIMATE DISPLAY AND REPLACED AS UNIT AS PER SSM RECIEVED FROM TECHHOTLINE
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 17 7T03 000303 5C3Z 19H332 BA A85 42 29240
AWS Claim Key: 3697904 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:20-FEB-2006 Doc #:098925A
Cust Comments: REPAIR ELECTRIC BRAKES NOT WORKING
Tech Comments: 47058 CONTROLER ORDER TRAIL BRAKE CONTROL 9008 INSTALL TRAILER BRAKE CONTROLER 9008
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 17 * * * * * * * 31329
AWS Claim Key: 3792331 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03942 - * Name: PARADISE FORD Ph: 321-6322222 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2006 Doc #:08971352
Cust Comments: RECALL 05B32 DE GAS BOTTLE
Tech Comments: INSTALL LABLE ONTO DE GAS BOTTLE
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 18 1F06 030304 F6DZ 8100 A L87 42 34446
AWS Claim Key: 4589788 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-MAR-2006 Doc #:100303D
Cust Comments: COOLANT LOSS ADDED 2 GALLONS BLOWING OUT OF CAP
Tech Comments: 55436 TSB TEST DROVE WITH PRESSYRE GUAGE ON DEGAS BOTTLE PRESSURE NEVER WENT ABOVE 12 PSI AS PER TSB 06 3 8 , REPLACED CAP AND LOWERED COOLANT LEVEL 9011
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 18 * * * * * * * 34446
AWS Claim Key: 4589786 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-MAR-2006 Doc #:100303B
Cust Comments: PERFORM RECALL #05E15 EXHAUST PRESURE SENSOR REPLACEMENT ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: 55436 RECALLED PERFORMED RECALL 05E15 , NEEDS PART ON PREQ FOR RECALL 9011 INSTALLED EBP SENSOR 9011
AWS Claim Key: 4589787 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-MAR-2006 Doc #:100303C
Cust Comments: PERFORM RECALL #59B01 ROAD TEST
Tech Comments: 55436 RECALLED PERFROMED RECALL 59B01 ENGINE RUNS FINE 9011
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 31 2H01 030407 4C3Z 6K682 CBRM D42 42 61185
AWS Claim Key: 7900479 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: B3220 - * Name: BELLIVEAU MOTORS LTD Ph: 902-7690706 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:17-APR-2007 Doc #:01881704
Cust Comments: ADD ON LACK OF POWER.
Tech Comments: ADD ON VERIFIED CONCERN,PPT KA,TURBO NOT DEVELOPPING ANY BOOST AND IS NOISY.REMOVED TURBO AND DISASSEMBLED.FOUND TURBINE FIN BROKE AND ROTATED INSIDE HOUSING WHICH DAMAGED ENTIRE WHEEL.R&R TURBO,VERIFIED,OK.MT TIME NEEDED TO HEAT TO REMOVE TURBO PIPE BOLTS.NO OP CODE.
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 31 1H03 030804 5C3Z 9J460 A E29 42 61185
AWS Claim Key: 7900478 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: B3220 - * Name: BELLIVEAU MOTORS LTD Ph: 902-7690706 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:17-APR-2007 Doc #:01881703
Cust Comments: ADD ON CHECK ENGINE LIGHT IS ON.
Tech Comments: ADD ON VERIFIED CONCERN,EEC TEST,RETRIEVED/CLEARED CODE.PINPOINT TESTS,DIESEL DIAG SHEET.R&R EBP SENSOR,VERIFIED REPAIR,OK.
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 31 1A02 030102 * 6051 * D50 42 61185
AWS Claim Key: 7927083 Trx Code: E72 Labor Hrs: 19.9
Dlr Cd-Sub Cd: B3220 - * Name: BELLIVEAU MOTORS LTD Ph: 902-7690706 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:17-APR-2007 Doc #:01881701
Cust Comments: WHITE SMOKE UPON TAKE OFF THEN DISSAPATES.
Tech Comments: MT TIME NEEDED TO VERIFY CONCERN.CHECKED OASIS,FOUND TSB 06 21 2.DEGAS BOTTLE SHOWING SIGNS OF COOLANT LEAKAGE.FOLLOWED TSB,PRESSURE GOING ABOVE 18 PSI.REMOVED EGR VALVE,RAISED REAR OF TRUCK,FOUND COOLANT INSIDE INTAKE AFTER A FEW MINUTES,INDICATING DEFECTIVE EGR COOLER.DISASSEMBLED ENGINE TILL HEADS GASKETS,CLEANED AND R&R HEAD GASKETS.CHECKED HEAD FLATNESS,OK.REINSTALLED HEADS AND R&R EGR COOLER
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 45 1H03 030008 * 9F452 * D42 42 88831
AWS Claim Key: 10283242 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: B3220 - * Name: BELLIVEAU MOTORS LTD Ph: 902-7690706 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:09-JUN-2008 Doc #:02491002
Cust Comments: ADD ON CUSTOMER CONCERNED ABOUT A VEHICLE NOT RUNNING PROPERLY.
Tech Comments: ADD ON VERIFIED CONCERN,CHECKED OASIS,NO CONCERNS.DIESEL DIAG,EEC TESTS,RETRIEVED/CLEARED CODES.PINPOINT TESTS,EGR TESTS FAILED.R&R EGR VALVE AND REPROGRAMMED MODULES,VERIFIED,OK.
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 49 2E01 030408 4C3Z 9B246 C D03 43 95985
AWS Claim Key: 10440578 Trx Code: E72 Labor Hrs: 4.9
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:23-SEP-2008 Doc #:134460A
Cust Comments: STARTS HARD ONCE WARM
Tech Comments: 154473 TSB EEC TESTED TRUCK CODE P2291 LOW ICP WHILE CRANK ENGINE HOT VERIFIED CONCERN VERY LAZY TO START TSB 8 18 6 APPLIES NEEDS PARTS ON PREQ 9011 INSTALLED STC FITTING , TEST DROVE STARTS FINE HOT 9011
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 49 2H01 0300XX * 6K682 * L65 42 95985
AWS Claim Key: 10445737 Trx Code: S07 Labor Hrs: 0.1
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:23-SEP-2008 Doc #:134460E
Cust Comments: CHECK TUBO FOR OIL LEAK ALSO BOOST IS A ) MOST OF THE TIME
Tech Comments: 154473 O RINGS TURBO DRAIN O RINGS HAVE VERY SMALL SEEP NEEDS PARTS ON PREQ 9011 INSTALLED NEW O RINGS ON TURBO DRAIN TUBE VERIFIED REPAIR AFTER TEST DRIVE 9011
1FTSW21P55EA51034 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-SEP-2004 13-OCT-2004 4B3225 CAN 49 1H03 030008 3C3Z 9P458 AA L87 42 95985
AWS Claim Key: 10426772 Trx Code: E72 Labor Hrs: 0.2
Dlr Cd-Sub Cd: B3225 - * Name: TUSKET SALES & SERVICE LTD Ph: 902-6482600 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:23-SEP-2008 Doc #:134460B
Cust Comments: CHECK FOR COOLANT LOSS
Tech Comments: 154473 TUBE CHECKED FOR COOLANT LEAK FOUND BLUE EGR CCOLER TUBE LEAKING AT OIL COOLER ADAPTER NEEDS PARTS ON PREQ 9011 REMOVED EGR COOLER AND INSTALLED EGR COOLER PIPE AND ADAPTER IT WAS CRACKED AND BROKE APART WHILE REMOVING REASSEMBLED NO MORE LEAKS 9011
2000 F-350 supercrew 4x4. Banks new ram air, Autometer guages(Thanks GOS)Boost, pyro, trans temp. DP tuner F8.(Thanks Diane and Jody)
00f3fiddy is offline
The Following User Says Thank You to 00f3fiddy For this addition to TDG:
jstreet (09-18-2010)
